N54tech.com | BMW N54 N55 135 335 535 Turbo Performance Forum
(#51)
Car: 135i, 335i, X5D
Tuner: BMS
Default 05-25-2009, 09:32 PM
Not overly thrilled with the elbow placement... but still more testing to do! The "sound box" location may be better.
az335iat's Avatar
az335iat az335iat is offline
Minor Diety
Car: 2009 335i AT
Tuner: JB
Cool 05-25-2009, 09:46 PM
Just one other thought. Most of the airflow will follow the outside radius of the elbow. The inside radius will tend to be a relatively low velocity area. While the SB may prove to be a better injection point, that is not an option for 335i people. One more cent.
Tuner: BMS
Default 05-25-2009, 09:50 PM
Really, what I need is a real thermocouple... I'm finding the IAT sensor leaves a lot to be desired.
az335iat's Avatar
Minor Diety
Car: 2009 335i AT
Tuner: JB
Cool 05-25-2009, 09:54 PM
What would be easier to interface with, a TC or RTD? Where are you thinking of locating it?
Tuner: BMS
Default 05-25-2009, 10:06 PM
The location is the problem. Right now with the elbow mounting point I'm seeing only half the IAT improvement compared to the previous location, but a similar timing advance improvement. You wouldn't think ~12" of intake tract would make much difference. So either my previous temperature readings were skewed due to the spray being too close to the IAT sensor, or that is a vastly superior location for cooling. Relocating the nozzle to the short side of the elbow would be a good idea for flow if nothing else.
Former_Boosted_IS Former_Boosted_IS is offline
Car: 4 Wheels
Tuner: Tuners are Good
Default 05-26-2009, 03:07 AM
I agree there! I told you that thing is slow to react and may be a bit erratic at times.
az335iat's Avatar
Minor Diety
Car: 2009 335i AT
Tuner: JB
Cool 05-26-2009, 06:04 AM
I think you may be correct in that the spray, it self, may have been hitting the IAT sensor in the previous location.
I was not suggesting moving the nozzle to the inside bend of the elbow, but rather, to a location that points
the spray away from any walls of the elbow, if possible.
I am going on a business trip for about a month and will not even have access to the internet or email. Good luck with this project.
e90AW335I's Avatar
e90AW335I e90AW335I is offline
Banned
Car: N54, 2011 Mustang 5.0
Default 05-26-2009, 07:14 AM
Like this?
Right now the meth sprays in the directions of the green arrow. With the new placement (red dot) the spray would be towards the throttle body rather then toward the elbow itself.
Tuner: BMS
Default 05-26-2009, 09:11 AM
The nozzle sprays straight down. Locating it to the short side of the bend (180 degrees from red dot) may be a little better.
e90AW335I's Avatar
Banned
Default 05-26-2009, 09:14 AM
I meant to draw it straight down but my MS paint skills aren't what they used to be.
anthony@rissracing anthony@rissracing is offline
www.rissracing.com
Car: E60 M5 & E92 335
Send a message via AIM to anthony@rissracing
Default 05-26-2009, 10:04 AM
Amazing numbers Terry great job!
Anthony Gutierrez
CEO/Co-Founder
www.RissRacing.com
Tuner: BMS
Default 05-26-2009, 09:54 PM
Still not feeling the elbow mounting point. So I'm going to give a 7 gph and 10 gph nozzles a shot in the old location, and try to monitor timing advance per cylinder to look for any distribution issues.
For you 335i guys out there, buying a spare charge pipe may be the best solution.
Terrance28's Avatar
Terrance28 Terrance28 is offline
Car: BMW 335i
Tuner: JB3
Send a message via Yahoo to Terrance28
Default 05-27-2009, 12:55 PM
What about those who don't have the stock charge pipe anymore?
E92 335i Crimson Red|JB3 2.0|Stett Intercooler W/N2o Bung|AFE DCI|Stett Charge pipe W/Meth Bungs|Synapse BOV|Devil's Own Stage1 Kit|Dynotune N2o Stage1 Kit W/Progressive controller & NX noid|ATI Gauge Pod|VEI Boost,A/F Gauge|Cyba Scoops|RR OCC|19" M6 Reps|Aero Lip|Color Matched Grills|Eibach Pro kit|Momo Knob|M3 Spoiler|Carbon8 PD Hood|Vynil Roof|Shadowline Trim|ACS Roof Spoiler|Carbon Interior|MFD M3 skirts|Raceland DP|BMS V3 DP Fix|Magnaflow Race exhaust|
Down4it's Avatar
Down4it Down4it is offline
Tuner: Burger Tuning
Default 05-27-2009, 01:01 PM
Those people should learn to keep all their stock parts... Also you can have a bung welded into the aftermarket charge pipe and still be good to go... I have the stock charge pipe, the RR diverter pipe, and the AA bov charge pipe, i am going to put a bung for the nozzle in each one except for the stock...
S281E
Tuner: BMS
Default 05-27-2009, 01:54 PM
You can mount it in your BOV pipe. Even easier!
Car: 4 Wheels
Default 05-27-2009, 02:13 PM
STETT Performance is making a charge pipe specifically for meth. It will have two nozzle bungs welded in and you can choose between a diverter valve setup or a BOV setup. All hardware needed will be included.
Down4it's Avatar
Default 05-27-2009, 02:23 PM
Why 2 bungs?
S281E
Tuner: BMS
Default 05-27-2009, 02:25 PM
Fast and furious baby...
E82tt6 E82tt6 is offline
Tuner: BMS
Default 05-27-2009, 02:50 PM
It's all about the Nawzz
midlife's Avatar
midlife midlife is offline
maniac
Car: e93
Tuner: BMS FTW !
Default 05-27-2009, 03:26 PM
terry: do you still think you cannot use a small NOS dry shot without long term motor consequences ??
if your car isn't scary - it's just not fast enough !
JB3 2.0 beta / BMS Tuning Gauge / RPI IC / UR non catted DPs / UR CAI / Quiaife LSD / Snow Methanol Injection / VK Oil Cooler / Forge DVs
Riss Catch Can / M3 Rear Sway Bar / M Sport Steering Wheel / Paddle Shifting 6AT / Logic 7 / Dunlop Direzza Z1 235/255
Tuner: BMS
Default 05-27-2009, 03:30 PM
You probably could get away with it, especially with a meth + small dry shot environment. But not sure how safe its going to be...
Car: 4 Wheels
Default 05-27-2009, 05:32 PM
Originally Posted by Down4it
Why 2 bungs?
Snow is a good example of using a 2 nozzle setup. If your goal is to spray 550 ml/min, then you can spray the 375ml/min and a 175 ml/min. From what I understand thus far it allows a more precise spray and greater drivability. I am wondering if it operates in the same method as large fuel injectors in the sense that very large fuel injectors do a poor job when dumping small amounts of fuel.
OverBoostinBimmers's Avatar
OverBoostinBimmers OverBoostinBimmers is offline
Wannabe Banned
Car: 09 E82 135i
Tuner: myself
Send a message via AIM to OverBoostinBimmers Send a message via MSN to OverBoostinBimmers Send a message via Yahoo to OverBoostinBimmers
Default 05-27-2009, 06:49 PM
T,
What is your Meth/Water Ratio? Wouldn't it help if you added more alcohol over water to evaporate faster?
***Please note, i am NOT FibreOptix, i am just selling all of FibreOptix's leftover stock at really good prices!!!***
Car: 4 Wheels
Default 05-28-2009, 06:51 AM
I wanted to elaborate a bit more on the 2 nozzle setup. I am in the process of installing a Snow Performance Stage 3 Meth kit. The stage 3 controller allows the use of a two nozzle setup. The pump will feed a "T" connector that will then feed 2 nozzles of my choice. I am using a 375 ml/min nozzle and a 175 ml nozzle. The large 375 ml/min nozzle has a solenoid controlled by the stage 3 controller that will start to spray when the system enters "power mode". Because the controller can adjust the flow through the solenoid I have an incredible amount of control in when I want to spray 100% meth. This to me seems the way to go.
Tuner: BMS
Default 05-28-2009, 10:00 AM
Originally Posted by OverBoostinBimmers
T,
Right now 75/25, but I ordered a bunch of 50/50 mix for testing. My new nozzles came in as well, so hope to find some time tomorrow or this weekend to test them.
