Banned
Car: 135i, 335i, X5D
Tuner: BMS
JB3 1.3 beta 8D_REV4 -
05-01-2009, 04:06 PM
This is the final 1.3 version!
Map switching directions:
Insert keyfob and press start button to turn ignition on (lights on dash, but engine not running). Press and hold the gas pedal down to the floor for 4 or more seconds, and then release pedal. This puts the JB3 in to listen mode. If you start the engine at this point you will be on map 0. For performance maps press the gas pedal to the floor and quickly release one time for each map you would like to select. For example for map 3 press and release the gas 3 times, and start the engine. Your map setting will be saved until changed. If you forget what map you are on, turn engine off and reset the map selection. With new installs or when burning a chip map 3 is always selected by default. So you only need to pay attention to this guide if you would like to disable the JB3 or change maps.
JB3 v1.3
BETA_8D_REV4 Map Guide
Map 0:
-- Disables JB3, all signals pass through
Map 1:
-- Low boost map, boost levels of 11-13psi depending on mods and weather
-- Self adapts to modifications like intake, downpipes, exhaust, etc
-- 91 octane RM2 or higher required. The higher the octane, the more power.
Map 2:
-- Performance map, boost levels of 12-14psi depending on mods and weather
-- 91 octane RM2 or greater required. The higher the octane, the more power.
Map 3:
-- Identical to map 2 with additional low end response (aka lagfix)
Map 4:
-- Hotter Performance map, boost levels of 13-15psi depending on mods
and weather
-- 93 octane RM2 or greater required. The higher the octane, the more power.
Map 5:
-- Identical to map 4 with additional low end response (aka lagfix)
Map 6:
-- Designed to optimize bolt on performance
-- Richer midrange air/fuel ratios to sustain additional torque
-- May trigger hidden tuner detection codes. Purchase a Bavarian
Technic cable from BMS to scan for and delete any hidden codes before service.
Map 7:
-- Identical to map 6 with additional low end response (aka lagfix)
Map 8:
-- Race map
-- 97 octane RM2 or greater required. The higher the octane, the more power.
-- Modifications like intake, downpipes, and intercooler strongly suggested
-- Lagfix enabled
-- May trigger tuner detection codes
Map 9:
-- More aggressive race map
-- 100 octane RM2 or greater required. The higher the octane, the more power.
-- Intake, downpipes, and intercooler required
-- Lagfix enabled
Map 10-14 (A-D):
-- For use with modified JB3 boards only
Map 15 (F):
-- For use with tuning gauge only
Tuning gauge parameters for those of you with the tuning gauge. Remember these settings only take effect when you are on map 15(F).
LB: Base boost level. Note: Map 6 is set to 11.
HP: Additional boost above 4500rpm. Added on top of LB. Note: Map 7 is set to 5.
AF: Air/fuel ratio. 0=stock levels, F=max rich. Note: Maps 6+ are set to F, 1-5 are set to 1.
PD: Pedal Input / Boost Gain. Higher = faster boost build up, more chance for overshoot. Note: All maps set to 6.
SD: Solenoid prespool (lagfix). Higher = more prespool, more chance for overshoot. Note: Map 7 is set to 6, map 6 set to 0.
AD: Air intake temperature boost decay. Higher = more decay. Note: Map 7 is set to 8. Race maps set to 0.
Tuner: Me ! LoL..
05-01-2009, 04:14 PM
nice! can't wait to try it..is map 8&9 supposed to be the old 7&8 ?
Mods ? Nope its all stock..
Banned
Tuner: BMS
05-01-2009, 04:15 PM
Yes, identical!
Tuner: Me ! LoL..
05-01-2009, 04:18 PM
Awesome!
Car: 135i Coupe
Tuner: BMS
05-01-2009, 04:23 PM
very nice indeed!
|| 135i || 6MT || Sports Package || Pod/USB || PROcede Tuned ||
|| Best 1/4 run: 11.772@117.30MPH || 1.644 60' || DA: 1773 ||PROcede Rev.2 v4 5-15 Maps || Slip ||
05-01-2009, 04:43 PM
Damn - just put in Rev3 last night, now I have to take it out again!
05-01-2009, 05:10 PM
New record (for me) - burned it, disconnect the battery (extra hard in an E93), put in the chip and all buttoned back up - 25 minutes - post to post!
Slow Car Owner
05-01-2009, 05:11 PM
Perfect timing! I get to put in Rev4 when my Tuning Gauge comes tomorrow!!! Terry, will this fix or alleviate the loss of boost when shifting >6.2k RPMs on the 6MTs?
Jet Black | 6MT | 20% Tint
Best ET 12.446@111.23 /w 1.89 60ft (15psi meth not working) Best Trap 115.3
Car: BMW 335i
Tuner: JB3
05-01-2009, 05:31 PM
I see map 7 will be my favorite map. BT tool FTW, it looks like map 7 will be stronger than map6 on 1.22.
 E92 335i Crimson Red|JB3 2.0|Stett Intercooler W/N2o Bung|AFE DCI|Stett Charge pipe W/Meth Bungs|Synapse BOV|Devil's Own Stage1 Kit|Dynotune N2o Stage1 Kit W/Progressive controller & NX noid|ATI Gauge Pod|VEI Boost,A/F Gauge|Cyba Scoops|RR OCC|19" M6 Reps|Aero Lip|Color Matched Grills|Eibach Pro kit|Momo Knob|M3 Spoiler|Carbon8 PD Hood|Vynil Roof|Shadowline Trim|ACS Roof Spoiler|Carbon Interior|MFD M3 skirts|Raceland DP|BMS V3 DP Fix|Magnaflow Race exhaust|
Car: E60 M5/ 335i
Tuner: BMS
05-01-2009, 05:41 PM
Interesting... Looking forward to the finalized 1.3 before I upgrade where I am now rev3.
Terry, do 4,5,6 you listed go for map 1-4 aswell?
05-01-2009, 05:54 PM
lol Terry you send me REV4 or the last one?
Dont make it angry
Banned
Tuner: BMS
05-01-2009, 06:14 PM
Goes by file name!
Makes no reps or warrants
Car: 08.335i 06.M3
Tuner: BMS
05-01-2009, 07:25 PM
Hell yeah. I was starting to itch!
2006 SG ZCP M3 6MT TCKline/Ground Control-SS Stepped-Crackpipe-Borla-4.10
2008 AW E90 6MT Quaife-3.46-PSS10-Code3IC-RissDP-BBSCH-245/275 RE11-JB3 2.0β
Administrator
Car: E82 135i
Tuner: BMS
05-01-2009, 08:55 PM
Want some Vagisil?
woohoo. Great job T!
Car: 08.335i 06.M3
Tuner: BMS
05-01-2009, 09:35 PM
Originally Posted by BSM 335I
Want some Vagisil?
Good one. Not quite what I had in mind though.
Car: 08 E92 335i
Tuner: JB3
05-01-2009, 10:48 PM
Just burned the maps will put it in tomorrow. Great Job T. Rev4 here we come
designed by AU335
Tuner: BMS
05-02-2009, 12:27 AM
Been running Map 7 on 8Dr4 for most of this week and it's really smooth, I think the lagfix is set just right as well. Now I just need to get myself some ******* DP's and a bigger IC
135i M Sport 6MT: Alpine White / Black Boston Leather, Nav Pro + Assist & Online, Voice Control, Bluetooth, Prof Hi−Fi, USB, Lumbar & Heated Seats, Xenons, Cruise, Sun Protection Glass
Mods: JB3, BMS Tuning Guage, BMS DCI, AR CL DPs, Helix FMIC, STETT Charge Pipe with TiAL BOV, CDV Mod, Michelin PS2's
Car: BMW 335i Coupe
Tuner: Burger Motorsports
05-02-2009, 01:02 AM
will be putting this in tonight and start beating the **** out of my car tomorrow!!
BMW 335i Coupe Mods: Burger Motorsports JB3 2.0/ Quaife ATB LSD / RR Ceramic Coated C@tless Downpipes / Helix Stepped Core Intercooler / VK Motorwerks Oil Cooler / AFE Intake / STETT Charge Pipe / Forge DVs / MFD Air Scoops / RR Oil Catch Can / Aero Lip / M3 Lip Spoiler / RD Angel Eyes / GP Thunder 7500K Fog Lights / Red Brake Calipers / Matte Black Grilles / Lower Bumper Matte Black Grilles
Band
Tuner: Terry und BMS
05-02-2009, 02:50 AM
I can't wait to get back from Iraq and drive Bleautiful once more!
Car: 07 e90 335i
Tuner: BMS
05-02-2009, 12:51 PM
Installed 8D4 today and been driving on map 7 with just an intake. So smooth. No lights, and no codes as of an hour ago.
2010 BMW 335i E90
JB3 v2.0 (beta) | CYBA SCOOPS | INJEN DCI | BSH OCC | M3 SPOILER | REAR FOGS | TINTS
2007 BMW 335i E90 (GONE)
Aspiring Meth Addict
Car: 335i LeMans M Sport
Tuner: BMS!!!
05-02-2009, 12:56 PM
Awesome! Can't wait to get it loaded!!
New Ride: 2010 LeMans M Sport Coupe, 6MT, All Show, Goes Slow...
Sold: 2007 Montego Coupe, 6MT, This and That...
Best ET: 12.34
Best MPH: 112.65
05-02-2009, 04:12 PM
So what was the lagfix increased too. From 40% to what?
Slow Car Owner
05-02-2009, 04:20 PM
Should I just waste the 30 minutes putting this into my current JB3 when my boost gauge is coming on Monday?
Too good for 1st gear ;)
Car: 1 Series
05-02-2009, 04:27 PM
by the time you wait for an answer you could be torquen up the roads right now...
Banned
Tuner: BMS
05-02-2009, 04:32 PM
~50%
| Thread Tools |
| Display Modes |
Copyright © 2007 - 2010, N54Tech.com | BMW N54 / N55 Engine Forum
