Default BMS JB Stage 1 for 1.8T, 2.0T 210hp, 220hp and 230hp - 06-14-2015, 09:08 AM
THIS PART IS LEGAL FOR USE ONLY IN COMPETITION RACING VEHICLES AS DEFINED UNDER CALIFORNIA LAW, AND IS NOT LEGAL FOR USE IN ANY OTHER MOTOR VEHICLE. California law defines a "racing vehicle" as "a competition vehicle not used on public highways." (Calif. Health & Safety Code 39048) This part may only be used on competition racing vehicles operated exclusively on a closed course in conjunction with a sanctioned racing event. Competition-only motor vehicles may not be driven to a racing event on a public highway and must be transported on a trailer or other carrier. USE OF THIS PART IN ANY OTHER VEHICLE MAY SUBJECT YOU TO FINES AND PENALTIES FOR VIOLATION OF FEDERAL AND/OR STATE LAW, WILL VOID YOUR WARRANTY FROM BURGER MOTORSPORTS, LLC, AND CAN VOID YOUR VEHICLE'S WARRANTY. It is your responsibility to comply with all applicable federal and state laws relating to use of this part, and Burger Motorsports, LLC hereby disclaims any liability resulting from the failure to use this part in compliance with all applicable federal and state laws.
UPDATED 25.09.2015
We have finally reached a point where we have released our JB Stage 1 offering.
The unit is called a stage 1 or JB1 as it is called on the VW forums because it is a simpler unit compared to the yet to be released JB4 and does not signify stage tuning as one is use to when it comes to flash tuning.
These units are now available and a ready for order at http://burgertuning.com/vw_volkswage...JB1_tuner.html
The JB1 is a true plug and play tune offering safe and adjustable gains. It can be installed and removed in minutes.
Install instructions:
Install instructions can be found here: http://burgertuning.com/instructions...G_EA888_G3.pdf
The JB Stage 1 is suitable for the EA888 Gen 3 motors with Golf 1.8T and 2.0T covering 210, 220hp and 230hp version for the North American and ROW market with dual injection.
The unit ships with a base setting in map 1 that increases the boost by +4.75psi over stock that is safe to be used with 91US octane and 95 Euro. The typical power gains on this setting are 35whp and 45ft lb. With higher octane on a bolt on car we have seen average gains of 45whp and 65ft lb in Map 1. All of this whilst keeping the engines stock fail safes in place.
User interface software:
For users that have opted to purchase the optional BMS Data Cable you will need to download and install the user interface at this link http://www.n54tech.com/flash_files/jb4_interface.zip . The software is only compatible with Windows so for Mac a Virtual machine needs to be used.
Here is a video of how to install the User Interface Software, connect to the unit and make changes. Please note the JB1 uses the universal JB4 inteface.
Directions on how to connect and change firmware:
Directions on installing the interface and connecting to your JB can be found here
http://www.n54tech.com/forums/showpo...21&postcount=1
Firmware is what runs the JB1 unit. As we release updates or new firmware version this can be uploaded to your unit free of charge.
Map selection:
In order to change the map in the picture below under the logging tab you can pick the required map. Select the map and click add.
Mapping
Upon shipping the following maps are active:
Map 0: Stock with complete pass through i.e. the JB1 does nothing
Map 1: Less aggressive boost profile map, this supports 91 octane at the base boost setting as well as bolt ons. If higher octane is used the boost can be increased as well as with bolt ons. We found that with intake, ** and 93 the boost can be pushed to +5.5psi. The method of doing this is in the second picture below. A E35 ethanol mix has been tested with this map and its fully compatible to run at boost levels up to +5.5psi when complimented with FBO (full bolt on mods). For anything higher than +5.5psi race fuel is required.
Map 3: Map three allows the JB1 to be the methanol controller working as a fail safe cutting boost if lack of meth flow is detected. You will require a Coolingmist FSB and a BMS Methanol kit to get this working. For meth support email georg@stgeorge.co.za directly.
Map 6: User adjustable boost profile (see below) Active on units that ship 29.09.2015 and after. If you have previously purchased your unit before reading this please email me george@burgertuning.com to receive a copy of the firmware.
Map 1 Boost setting:
Below is a diagram of where the user adjustment is made for boost over stock. Add in the value and click save.
On older interface software it will appear like below.
Map 6 Boost selection
For map 6 you will need to connect to the unit and select map 6. If you have previously purchased your unit before reading this please email me george@burgertuning.com to receive a copy of the firmware. On units that ship from 29.09.2015 there is no need. If your unit has a exposed blue wire you will need to email.
Below is where you enter the values for map 6. It works similar to map 1 so the value is the additional boost over stock.
Dedicated Map 6 discussion thread here: http://www.golfmk7.com/forums/showthread.php?t=12325
The below map is being currently being tested. It will be released with a firmware update that you can load with your data cable at no extra cost.
Map 4: This map can be considered a low torque map suitable for circuit use and want something more conservative.
The unit can log boost on the two sensors, dme boost as well as the rail pressure. The balance of the engine parameters and settings in the picture are exclusive to the yet to be released JB4 but it gives you a idea of what is to come.
Support queries can be posted here on the BMS support forum using email at george@burgertuning.com .
2015 VW Golf 1.4TSI
2017 Audi 8V RS3
Default 06-14-2015, 09:29 AM
Here is a dyno of a bolt on GTI with **, intake and 91 after the JB Stage 1 has been added with a +5.0psi setting.
2015 VW Golf 1.4TSI
2017 Audi 8V RS3
Default 06-16-2015, 04:17 AM
Here is a dyno on a dynojet with intake, ** and JB Stage 1 on 93.
2015 VW Golf 1.4TSI
2017 Audi 8V RS3
Forced Air's Avatar
Forced Air Forced Air is offline
Got Boost?
Car: 2010 135i
Default 06-16-2015, 08:25 PM
Looking good!
2009 BMW 135i MT, Jet Black, ///M Sport, Premium - JB4|JB4 Backend Flash|BMS DCI|Raceland cattless ***|BMS Chargepipe|TiAL BOV|Golf Tee|Tint|Breyton GTS-R Wheels|Nitto NT05s
SOLD - 2010 BMW 135i AT, Alpine White, ///M Sport - JB4|BMS DCI|Macht Schnell 3" cattless ***|Golf Tee|33% Tint|Nitto NT555s|///M Pedals
2015 MkVII GTI MT, Pure White - Forge BOV|Nitto NT555s --DD / Wifey's Car--
TMR's Avatar
TMR TMR is offline
Default 06-22-2015, 07:43 PM
Yo T! Did i tell you i have a 2015 A3 2.0?
Default 06-24-2015, 01:58 PM
Awesome, quattro of fwd?
2015 VW Golf 1.4TSI
2017 Audi 8V RS3
TMR's Avatar
TMR TMR is offline
Default 06-26-2015, 12:51 AM
I have a quattro. Im interested in getting the JB4, would love to integrate meth.
Default 06-26-2015, 08:16 AM
The Stage 1 has meth integration.
We put a baby DO3 on the car which has intake, **, intercooler and ran some octane. The baseline was a decent 292whp at 6psi over stock. With the meth flowing it gained 5whp and quite a bit more torque with 5psi over stock. Now that we know its functioning properly I am going to log on the road with a decent mix and jet size and go back for a glory run. Both dynos where done with no cooling.
2015 VW Golf 1.4TSI
2017 Audi 8V RS3
Default 06-27-2015, 04:10 PM
Another dynojet sheet: Burger Motorsports Stage 1, 42DD Catted Turboback, Forge Twintercooler, Injen intake on 93 octane.
2015 VW Golf 1.4TSI
2017 Audi 8V RS3
TMR's Avatar
TMR TMR is offline
Default 06-27-2015, 08:13 PM
How can i get one?
Default 06-28-2015, 03:49 PM
How can i get one?
http://www.burgertuning.com/volkswagon_vw.html
2015 VW Golf 1.4TSI
2017 Audi 8V RS3
BoostAddict BoostAddict is offline
Car: e46 323i/ 04.5 Turbo 350Z
Default 08-07-2015, 01:41 PM
Do you have a range of the model years that these fit?
www.BoostAddictions.com
Custom Engine Calibrations and Performance Parts
996 Turbo
Default 08-09-2015, 08:43 AM
Yes, we have listed them on the sales page. http://www.burgertuning.com/jb_vw_stage_1_tuner.html
2015 VW Golf 1.4TSI
2017 Audi 8V RS3
Trickcruiser's Avatar
Default 09-03-2015, 06:07 AM
Any plans of adding TDI options?
Default 09-03-2015, 04:34 PM
Not at this stage. Sorry.
2015 VW Golf 1.4TSI
2017 Audi 8V RS3
awpgti awpgti is offline
Car: 2015 VW GTi
Default 09-05-2015, 01:13 PM
Can't wait for the new firmware with new maps!!
sebmour sebmour is offline
Car: 2016 VW GSW 1.8 TSI and 2008 BMW 135i
Default 10-27-2015, 01:32 PM
I just installed this and drove about 70km. I don't feel the gain...
I have a 2016 VW Golf 1.8T sportwagen (170hp/200tq)
Is it compatible with my car?
Plug A isn't needed? I didn't find the plug for it.
Cheers,
Default 10-27-2015, 05:11 PM
Cheers,
It is compatible with your car. Did you get a data cable for it? If so can you email me screen shots of logging page and user adjustment page to george@burgertuning.com
Plug A is not needed on the 1.8T.
2015 VW Golf 1.4TSI
2017 Audi 8V RS3
Default 10-27-2015, 05:22 PM
I do have a DATA cable but unfortunately I don't have any windows computers at home. I'll need to find one.
When I get them, I'll send them to you.
Thank you for your help George.
Chadd! Chadd! is offline
Car: 09 335i
Default 11-09-2015, 12:43 PM
Any chance you'll do something for the EA888 gen 2? Just picked up a 2016 a4 and coming from a jb4 n54 I'd to stay with bms
Default 11-09-2015, 03:57 PM
We have had quite a bit of demand on the gen 2. We should start working on a solution for a mild power bump in January on it.
2015 VW Golf 1.4TSI
2017 Audi 8V RS3
Car: 09 335i
Default 11-09-2015, 05:24 PM
Hell yeah! Mine is e85 compatible so it should be interesting ; ). If you need a tester, I'd be more than happy to do it!
Default 11-12-2015, 05:03 AM
Stock car on 93 with JB1. The car was then moved to map 0 (stock) and allowed to cool for long to give a fair stock result.
38whp and 54 ft lb over stock.
2015 VW Golf 1.4TSI
2017 Audi 8V RS3
Default 11-19-2015, 09:35 AM
Some nice gains from this JB1 user. Car is stock with JB1, map 1 +5.0psi on 91. Shows a 45whp gain.
2015 VW Golf 1.4TSI
2017 Audi 8V RS3
marcoac14 marcoac14 is offline
Car: BMW 320i
Default 12-20-2015, 05:45 PM
Hi George,
Is this compatible with the new A3 1.8T (MQB)? The car is euro spec but exported to Brazil and I'm not sure if there's any software changes to cope with our fuel or whatever.
