Default M5/M6/X5M/X6M S63TU JB4 Directions & Firmware - 06-13-2015, 10:19 AM
This is the central thread for all things related to the s63tu JB4 system. Including updates, directions, firmware, etc.
Note we've recently released a new s63tu JB4 v2 board that has the BCM (boost control module) built in. When looking at your firmware version if it ends in //5 then you have the orignal board, and if it ends in //6 you have the V2 board. V2 boards started shipping around 12/1/2017. Whichever system you have the BCM wires (or module) are optional and primarily intended for higher boost maps 2+.
JB4 Interface: Latest Interface Download. When updating your interface you may need to first go to "add remove programs" and "remove" your previous JB4 interface.
If you need directions on how to connect a laptop to your JB4 to update firmware or how to datalog Click here.
Installation is the same as the Stage1 connecting to the TMAP sensors on the intercooler (DO NOT PLUG THEM IN TO THE MAF ON THE TOP OF THE ENGINE!) per the Stage1 installation guide: http://www.burgertuning.com/instruct...e1_install.pdf
In addition the CANbus OBDII wire must be connected per the directions in the 2nd post. And if equipped the BCM module is installed per the 3rd post.
s63tu JB4 MAP GUIDE:
Map 0: JB4 disabled
Map 1: 4-5psi over stock additive. Suggested for most pump gas applications with and without BCM.
Map 2: 22psi peak absolute. BCM required. In some cases we've found this map maxes out the factory fuel trims. In those cases only map1 or map3 can be used without meth injection.
Map 3: 18psi peak absolute.
Map 4: Stock map w/ CANbus enabled
Map 5: //M map ramping boost up to redline (BETA)
Map 6: Custom target map
Map 7: 25psi peak (e.g. race gas, BCM required)
Map 8: Progressive meth map. Peak boost based on meth additive. 0 = 19psi, 75 = 30psi. BCM suggested.
Note without BCM all maps, especially the higher target maps, will under target on boost.
S63TU Firmware:
Firmware is posted at the bottom of this post. Note there are two separate board types and loading the wrong firmware for the board will result in check engine lights and no boost until the firmware is corrected. V1 systems (firmware version ending in //5) must use the JB4_S63TU_V1_xxx firmware. While V2 systems with integrated BCM (firmware version ending in //6) must use the JB4_S63TU_V2_xxx firmware.
V1_1_7_T1:
V2_2_1:
1) Redesigned the CANbus engine for much faster logging rates of all parameters resulting in smoother performance and better logging. By default the S63TU JB4 ships in "slow speed" CANbus mode (FutureUseD bit#4 = 1), which will run around 6hz from CAnbus on the new firmware. You can also try disabling this bit which will run 10hz from CANbus. If your vehicle can't handle the higher speed you'll see RPM drop out in logs. I'd be curious to know how many cars still require the slower speed with the new update.
2) Removed option for ulta-high speed logging (previously on bit7) as its no longer relevant.
3) Changed fuel pressure high and low to log full time.
4) Added load and calculated torque logging parameters for those running back end flash maps.
T2) Fixed bug with X5M/X6M triggering alarm when doors are locked.
V2_2_1_T5
1) Added startup gauge sweep when JB4 is enabled
2) Added in dash WMI flow gauge, timing gauge, and AFR gauge on speedo ring
3) Minor adjustments to PID/boost control system
*S63TU FutureUseD BIT Settings
bit0 - Disable in dash BC button controls
bit1 - Disable wastegate adaption
bit2 - Reconfigure BC button for X5M/X6M models
bit3 - Turn on boost gauge on fuel (for cars without BC button access)
bit4 - Slow down CANbus sample rate (default ON, required for most 2013-2014 models)
bit5 - Enable duty bias by RPM learning profile (under development)
bit6 - Vehicle equipped with flash map (under development)
bit7 - Unused
Dash settings as of OBDII v1.2 firmware:
'OBDII In Dash Menu
'0 map menu, map shown on tach (TACH shows Map)
'1 Active Sound MUTE. (OFF tach = 0, ON tach = 1000)
'2 Boost gauge on fuel, scaling in dash is 0 to boost safety setting, turns on when gas pedal is pressed 50% or more and turns itself off when you resume low throttle use. (OFF tach = 0, ON tach = 1000)
'3 LED MAX brightness mode. For those with factory LED headlights this option brightens HALO during nighttime operation. (OFF tach = 0, ON tach = 1000)
'4 Delete Fault Codes.
'5 1st gear boost limiter. (Tach = boost cap / 3)
'6 2nd gear boost limiter. (Tach = boost cap / 3)
'7 3rd gear boost limiter. (Tach = boost cap / 3)
Current dash settings as of OBDII v2.1_T5 firmware:
'OBDII In Dash Menu
'2 Boost gauge on fuel, scaling in dash is 0 to boost safety setting, turns on when gas pedal is pressed 50% or more and turns itself off when you resume low throttle use. Tach = 0: OFF; Tach = 1000: Boost on fuel only; Tach = 2000 Boost on fuel, WMI flow on speedo ring; Tach = 3000 Boost on fuel, Ign timing on speedo ring; Tach = 4000 boost on fuel, AFR on speedo ring.
'5 Adjust speedo for metric dash (tach = 0 SAE, tach = 1000 Metric)
'6 1st gear boost limiter. (Tach = boost cap / 3)
'7 2nd gear boost limiter. (Tach = boost cap / 3)
'8 3rd gear boost limiter. (Tach = boost cap / 3)
Basic overview of the wheel controls:
Default Settings for V1 and V2 systems:
Dyno Testing:
Stock turbo dyno testing results in 720whp!: http://www.n54tech.com/forums/showthread.php?t=31433
Upped the ante to 770whp stock turbo: http://www.n54tech.com/forums/showthread.php?t=35151
PURE Turbo dyno testing -- 850whp!!: http://www.n54tech.com/forums/showthread.php?p=485448
Pump gas dyno testing: http://www.n54tech.com/forums/showthread.php?t=34058
Copyright Notice:
JB4 Software is Copyright © 2006-2016 by Burger Motorsports Incorporated. All rights are reserved. De-compilation, disassembly, reverse-engineering, alteration, and redistribution in any form without the prior written consent of Burger Motorsports Inc. is prohibited.
If your current firmware ends in //5 you need V1, if your current firmware ends in //6 you need V2. Loading the wrong firmware for the board will result in various sensor fault codes that won't clear until firmware is corrected.
Default 06-13-2015, 10:32 AM
Adding in BCM wiring to existing S63TU JB4:
If you have a V2 upgrade kit you'll have a BCM wiring harness with several wires on it. The wires plug in as follows:
Black wire goes to pin#10
Red wire goes to pin #22
Blue wire goes to pin #11
Brown wire goes to pin #23
Green wire goes to pin #19
Purple wire goes to pin#20
If you have a V1 upgrade kit and are adding in the external BCM control box with a single blue wire, it goes in pin#1.
General Install Directions for extra JB4 wires:
1) Route and attach the OBDII cable as shown in the full JB4 install guide referenced in the first post.
2) If desired route and attach the BCM cables as shown in the BCM supplemental install guide in the next post. Note that while BCM(V1) solenoid wires are interchangeable, the V2 (integrated BCM) are specific to each TMAP sensor harness. If you installed the rainbow tmap patch on the passenger side intercooler per the directions then the BCM wire with brown and blue wires goes to the solenoid that is closest to the passenger side. The rainbow patch TMAP and blue/brown wire BCM wire should be on the same engine bank, and the brown patch and green/purple BCM wire will be on the same engine bank.
Default 06-13-2015, 01:51 PM
BCM Installation guide. photos shown are a V1 BCM. Integrated V2 BCM wires plug in the same way only noting which wire is attached to which solenoid per above post.
Lots of addl photos are needed here. Some basic directions to get the ball rolling. Note the BCM pairs should not be mixed up. With earlier ones we plug them in to each other and with new ones we also add a zip-tie so you know which pair is which. If you mix them up the net result will be too much boost in one bank and not enough in the other. Bank2 boost is shown as "IAVG" in JB4 logs.
Also note we suggest installing the JB4 first, ensuring the vehicle operates normally/code free, only then moving on to the BCM install, to reduce the variables should you need to troubleshoot.
1. Disconnect negative battery terminal.
2. Insert the BCM BLUE wire in to the JB4 DB25 connector position #1.
3. Connect the ground fork to the shock tower or any other suitable chassis ground.
4. To reach the wastegate connectors you're going to need to loosen and pull aside the passenger side intercooler.
5. Remove the passenger side "charge pipe" from the top of the intercooler, loosen the hose clamp securing the intercooler to the throttle body, and any bolts securing the intercooler in place
6. Unplug the two large water hoses. A quart or two of coolant will leak out. I used tap water later to refill but OEM IC coolant would probably be a better long term fluid.
7. Rotate the intercooler out of the way exposing the two boost solenoids. Plug the BCM module in to each being careful to keep the male/female pairs separate. They are not interchangeable. When plugging the connectors in to the solenoids ensure the pins are fully posted in to the connector. A loose pin here will result in stock like vehicle performance (full boost in one bank and low boost in the bank with the loose connection).
8. Put it all back together but don't refill the IC yet in case you made a mistake and need to take it apart again.
9. Reconnect battery and start the car a few times to ensure there are no fault codes coming up. Assuming those look OK top off the IC coolant fluid.
Some addl photos here: http://www.n54tech.com/forums/showpo...1&postcount=56
lfelunden's Avatar
Car: 335i e92
Default 06-13-2015, 01:53 PM
I'm not sure where we'll take the product tuning wise. For the short term, it's a way to add some features and logging. But not a way to add much addl power. That may change if we decide to add in addl sensors & controls.
Since so many are running flash tunes now with no idea what is going on with their engines, plagued by misfires, etc, this will be a nice way to datalog and fine tune those setups.
Having boost mapped by gear will also improve launching traction, and the boost gauge in dash is also a nice feature. Not to mention active sound delete, LED max brightness, etc.
So actually no difference on the tuning side regarding owners of the bms stage 1, only logging feature right? So still tuning my tmap sensor and that's it? I thought there would be fuelling too.
Default 06-13-2015, 01:57 PM
Correct no fueling changes. That would require flex fuel wire connectors to the fuel rail which can be installed but are a pita to reach. On the plus side since there is so much CANbus data coming in now like engine speed, pedal position, AFR, timing in multiple cylinders, etc, the tuning itself can be more refined.
We can make it smoother and safer but peak boost can't be raised much above what was being run on the Stage1 as the wastegate duty cycle is limited. So to get power up we're going to have to figure out a way to get some level of boost solenoid control. That is what I'm working on now. But again the prospects are not great, as the solenoid connectors are difficult to reach.
We may conclude it's best to use the JB4 as a support tool for fine tuning and adding features to flash maps. The first order of business is to evaluate how well the currently released flash maps are in their boost control, fueling mapping and timing mapping.
lfelunden's Avatar
Car: 335i e92
Default 06-13-2015, 02:04 PM
Correct no fueling changes. That would require flex fuel wire connectors to the fuel rail which can be installed but are a pita to reach. Since there is so much CANbus data coming in now like engine speed, pedal position, AFR, timing in multiple cylinders, etc, the tuning itself can be more refined.
Boost also can't be raised above what was being run on the Stage1 as the duty cycle is limited. So to get power up we're going to have to figure out a way to get some level of boost solenoid control. That is what I'm working on now. Again, the prospects are not great, as the solenoids are difficult to reach. We may conclude it's best to use the JB4 as a support tool for fine tuning flash maps.
I have seen other companies such as G-Power who control fuel too, but through a pin in the ECU not the rail itself.. They have control of the tmap, MAF and fuelpressure, check attached pictures:
Default 06-13-2015, 02:32 PM
If you care to cut/solder a wire in the harness then that's fine for fuel pressure. On the test car we just run a PNP connector to the sensor itself. It's just hard to reach. So much so I would not expect the average consumer to bother with it. With meth flowing anyway it's not needed for OEM turbos. MAF is useless to intercept. We just read it via CANbus.
lfelunden's Avatar
Car: 335i e92
Default 06-13-2015, 03:40 PM
The good thing here is that you won't need as much adaption vs no control of the fuelpressure. I can do that, if you have some pictures and maybe a PNP connector, I bother doing that! No problem for me BMW mechanics will do that with ease I suppose.
I can email you if this is possible.
Default 06-13-2015, 03:43 PM
Fuel trims are one of the loggable parameters in the JB4 so we'll be evaluating everything. We have a lot more possibilities now in what we implement. What we decide to do with all the new options is yet undetermined. Development continues.
Car: F06 N55 640i Gran Coupe
Default 06-13-2015, 04:15 PM
Yes getting it asap, once able to limit boost to avoid wheel spin there is high chance that can get into the 10s!
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS ** n FULL Custom Exhaust
Custom BC forge 18/17 set up
Default 06-13-2015, 05:40 PM
Working on BCM photos.
lfelunden's Avatar
Car: 335i e92
Default 06-14-2015, 01:49 AM
Nice work T!
Regarding the fuelling, that would be nice for us users who do not want to run meth.. Also, meth is so expensive here where I live (same story with racegas).
Default 06-14-2015, 10:07 AM
Better reference photo for the CANbus and METH wires when doing the upgrade.
lfelunden's Avatar
Car: 335i e92
Default 06-14-2015, 02:17 PM
Terry, you should make a thread at m5post too! Not many are aware of these news!!
Please go for the fuel pressure
Default 06-14-2015, 03:49 PM
We don't sponsor the forum so they can either start reading here or miss out.
lfelunden's Avatar
Car: 335i e92
Default 06-15-2015, 01:01 AM
haha, I saw mike@n54tuning did some posts with the meth kit
m6beast's Avatar
m6beast m6beast is offline
Car: 335i/m6
Default 06-15-2015, 04:27 PM
Just got mine ready to do some testing. Thanks again T and great job on pushing the envelope!
Default 06-15-2015, 04:45 PM
Yes many of our resellers do sponsor e90post. God knows why.
Default 06-15-2015, 05:15 PM
Lucky man.... G.
Default 06-15-2015, 08:59 PM
I was able to access both boost solenoids by popping the coolant lines off the passenger side intercooler and rotating it out of the way a bit. It's about an hour job and fully plug and play. I figure its better than cutting wires going to the DME.
Also if someone finds their fuel trims maxing out and wants/needs to add in the fuel pressure connections that is their prerogative. It's easy enough to add the connectors to the JB harness and we'll support them. For those of us with meth or using pump gas, it's not really a factor.
Default 06-15-2015, 09:01 PM
T, good to see you really work on this car....all the way....
lfelunden's Avatar
Car: 335i e92
Default 06-16-2015, 02:23 AM
Nice! If you could do a write-up for the fuel guys, that would be great!
speed808ix speed808ix is offline
Car: F10 M5
Default 06-16-2015, 09:44 AM
So the question is when can we order this
Default 06-16-2015, 10:00 AM
Will do. We're still in the early phases. We sent a few tuners out to start collecting some data but it may take a few weeks for us to finalize the connections being used and firmware.
I'm *really* excited about the boost solenoids. This opens up the tuning to seriously more power especially on meth.
lfelunden's Avatar
Car: 335i e92
Default 06-16-2015, 11:34 AM
Nice man, seriously can't wait. If you need any data collection (without meth) let me know, I can help you out (requires JB4 ).
Will be nice with the fuel pressure. Few weeks is fine, as long as you've turned your eyes to this engine, I'm sure you will hit records in no time.
