Default New JB4 F Series Billet Aluminum Enclosure - 04-16-2015, 03:04 PM
Jason @ BMS has been busy at the CNC shop with a new JB4 enclosure system specifically designed for F Bodies. So far I really like what I see and wanted to post a couple teaser photos.
What we're working on is a really nice CNC machined aluminum enclosure of similar quality to our other CNC machined parts like our oil catch can and wheel spacers. It's an upgrade option to the plastic enclosure system that JB4s normally ship with.
This upgraded enclosure has an ORING seal making it fully weather proof, internal mounting tabs to accept our JB4 & Stage1 circuit board, and is machined to accept the existing BMS harnesses.
To install you simply remove the covers off your harness (and data cable if equipped), pop it in the bottom of the new enclosure, place the top on, and tighten the included allen screws. In addition there are 4 large holes which accept zip-ties to attach it wherever you'd like within the engine bay. Since this solution is fully weather proof you're no longer limited to having to hide your JB4 under the plastic covers. Although, those do still make for a very convenient mounting location.
Attached is a photo of the prototype that we're testing in our M3 along with a shot showing how the harness and board fit inside. The production units will be anodized black. At least to start. We may also offer blue and red if there is interest.
Pricing will be $59 and we expect to have a batch ready in a week or two. I'll post a link when it's ready.
We're also still working on our new OBDII CANbus connectivity system which we expect to implement across the entire F Body platform, starting with the S55 models, but then also N20s & N55s. The new system eliminates the need to add POSI-TAPs and adds some additional features like an in dash boost gauge and on the fly map switching similar to our E Series models. More on that in the coming weeks.
Enclosure install directions:
1) Always disconnect the negative battery terminal when working with electrical wiring.
2) Unplug the JB4 control box and unsnap it's existing enclosure. It will pop right off.
3) Remove the black AMP shell from the JB4 harness by removing two screws and pulling it apart.
4) Remove the gray shell from the BMS DATA cable by removing two screws and pulling it apart.
5) Using the included 1/4" long screws attach your JB4 harness & DATA cable to the JB4 circuit board.
6) Place the circuit board bottom down in the side of the enclosure that says "bottom". It should lock in on the down pins provided preventing it from sliding around.
7) Position the JB4 harness grommet in the larger hole cutout.
8) Position the DATA cable in the smaller hole cutout.
9) Carefully install the top of the enclosure. If it does not side perfectly flush then there is an alignment issue with the JB4 inside.
10) Reinstall and tighten the 4 screws holding the enclosure together.
11) When working with the USB cable be careful not to allow it to touch the battery rail as this can cause a short circuit or other damage. We suggest covering the battery rail with a piece of cloth tape.
12) Reconnect the negative battery terminal.
335iMspizzle 335iMspizzle is offline
Car: 335i M sport
Default 04-16-2015, 03:05 PM
That looks SOLID !!!
2014 - M6 f06, FabWorx Ctlss **'s, JB4, FSB meth, Turner Exhaust.
2012 - 650i M sport JB stage 1 (Gone)
2009 - 335i N54 JB4, DINAN CAI, MACHT SHNELL **'S, HPF FMIC, ER CP, SYNAPSE BOV, EISENMANN RACE EXHAUST, BT OIL CC, COOLINGMIST/SNOW PERFORMANCE METH INJECTION - 427 WHP DYNOJET (Gone)
Abear Abear is offline
Default 04-16-2015, 03:18 PM
Awesome!
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 04-16-2015, 09:42 PM
No posi taps, full water proof.
By the way new map switching on the S55 we have been working on is pretty sweet
///Shaun ///Shaun is offline
Default 04-16-2015, 10:40 PM
This is AWESOME !
Will definite be on board for this new enclosure.
Looking forward to having the gauges etc for N55 F Series
Keep up the excellent work
JB FTW !
Peter @ Pure's Avatar
Car: F20 M135i
Default 04-17-2015, 07:43 AM
Looks very nice indeed!
F21 M140i - currently stock
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
kfardan's Avatar
kfardan kfardan is offline
Car: 2014 BMW 335i Sport Line
Default 04-17-2015, 11:25 AM
Awesome! where can I pre-order this
sadeem28 sadeem28 is offline
Car: F80
Default 04-17-2015, 11:53 AM
+1 where can I order?
e46m3to335i's Avatar
e46m3to335i e46m3to335i is offline
Car: 2015 F22 M235i
Default 04-17-2015, 12:23 PM
Sent you an email Terry.
- Nick J
2009 E82 135i: M6 / Alpine White / M-Sport / MHD Stage 1 / Performance Exhaust / Blackline Tails / CDV Mod / BMS PCV / Gloss Black Grilles
DCI's and exhaust things going on soon!!
boost82 boost82 is offline
Car: M235i
Default 04-19-2015, 02:12 AM
I need this. I pull the controller out every time I wash my car. Was actually thinking of working on a solution myself and saw this.
Default 04-20-2015, 08:41 AM
Hope to have a handful in the next week or so to start getting them out there. From there we'll ramp up production.
eyim1988 eyim1988 is offline
Car: 2011 e92 335i
Default 04-20-2015, 09:43 AM
I want this!
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default 04-20-2015, 09:48 PM
I want the new Canbus hook ups. How long until thats ready? I may hold off installing my JB4.
Mike Levy
2017 X3 xDrive35i
Car: F80
Default 04-23-2015, 09:44 AM
When can we expect these?
Default 04-23-2015, 09:45 AM
The enclosures? We'll have the first small batch ready this week. Assuming those look good we'll ramp up production.
Car: F80
Default 04-23-2015, 10:27 AM
Yup the enclosures, how can I get one ?
Mr. Grumpy's Avatar
Mr. Grumpy Mr. Grumpy is offline
BMW Freak
Car: F10 535i
Default 04-23-2015, 10:36 AM
Hi terry,
Are you going to add this enclosures to you BMS website or are you planning to do a sale list on this forum since you have a limited batch?
If you're doing a list I have dibs.
2011 535i (07/2011 build) Imperial Blue, Oyster/Black Interior, Anthracite Wood Trim, ZPP, ZP2, ZCV, ZSP, 2TB, 6NF, 6NR, BMS JB4 S2, BMS Intake, ER **.
2009 Kawasaki Ninja ZX-14
Retired: 2009 328i,Titanium Silver, Black Interior, Dark Wood Trim, ZPP, ZLP, 609, 494, AAW Tune.
jwdominick's Avatar
jwdominick jwdominick is offline
Car: 08 535ix
Default 04-23-2015, 12:26 PM
whats going to keep the aluminum from making contact with the circuits?
'08 535xi 6m, ACT 6 Puck Race Clutch / AR Design **'s / AFE Twin Power DCI / VTT Inlets / VRSF CP / TIAL BOV / Big Tom style IC / Fuel-It Stg2 LPFP / NGK 5992's @.022 / N20 T-Map / MHD Flash....100% e85 @24psi on stock snails!
Mike_L's Avatar
Anti-Social
Default 04-23-2015, 01:06 PM
Probably the connectors. It looks like the board is suspended by them.
Mike Levy
2017 X3 xDrive35i
jwdominick's Avatar
Car: 08 535ix
Default 04-23-2015, 01:10 PM
I sure hope that's not all they are relying on to isolate those bare circuits. any one of them could short to another and bad things would happen.
Jason @ BMS's Avatar
Jason @ BMS Jason @ BMS is offline
BurgerTuning.com
Car: F80 M3
Default 04-23-2015, 03:06 PM
There are machined locating support tabs on the upper and lower part of the enclosure ensuring no JB4 circuitry comes into contact with the enclosure.
BurgerTuning.com
Car: F80 M3
Default 04-24-2015, 10:34 AM
Nice! Here they are with the black anodizing.
Car: 2011 e92 335i
Default 04-24-2015, 11:44 AM
when can we order these?
Car: F80
Default 04-24-2015, 01:27 PM
I am ready to place an order
Default 04-24-2015, 02:32 PM
Jason will put it up on the site this weekend but we only have 10 in this initial batch. We will be ramping up production though.
