Default Mercedes C300 / C400 / C450 / C43 W205 Stage1 - 12-03-2014, 12:27 PM
This is going to be the central point of contact or our Stage1 tuner for the Mercedes Benz (W205 Model) C300 & C400.
THIS PART IS LEGAL FOR USE ONLY IN COMPETITION RACING VEHICLES AS DEFINED UNDER CALIFORNIA LAW, AND IS NOT LEGAL FOR USE IN ANY OTHER MOTOR VEHICLE. California law defines a "racing vehicle" as "a competition vehicle not used on public highways." (Calif. Health & Safety Code 39048) This part may only be used on competition racing vehicles operated exclusively on a closed course in conjunction with a sanctioned racing event. Competition-only motor vehicles may not be driven to a racing event on a public highway and must be transported on a trailer or other carrier. USE OF THIS PART IN ANY OTHER VEHICLE MAY SUBJECT YOU TO FINES AND PENALTIES FOR VIOLATION OF FEDERAL AND/OR STATE LAW, WILL VOID YOUR WARRANTY FROM BURGER MOTORSPORTS, LLC, AND CAN VOID YOUR VEHICLE'S WARRANTY. It is your responsibility to comply with all applicable federal and state laws relating to use of this part, and Burger Motorsports, LLC hereby disclaims any liability resulting from the failure to use this part in compliance with all applicable federal and state laws.
BETA Install Guide.
The system ships with map 1 selected and maps can only be changed with a BMS DATA cable.
Map 0: Disables tuner.
Map 1: Pump gas performance
Map 2: More aggressive map for higher octane fuels, E85 mixtures, or modified vehicles.
JB4 Interface: Latest Interface Download.
If you need directions on how to connect a laptop to your JB4 to update firmware or how to datalog Click here.
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 12-03-2014, 12:54 PM
Can't wait to see what it puts down on the dyno.
Excited about the development on this car. Hopefully some good power to be added.
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 12-03-2014, 01:01 PM
Cool stuff. I'm sure the Mercedes guys are excited
Default 12-03-2014, 09:16 PM
I was able to get some preliminary tuning done. I'm able to use a similar approach to what we use with the MINI N18 motor which lets us trick the DME in to increasing it's boost target, while keeping it fully in charge of boost control and running off its already mapped tables for fueling and timing appropriate to the higher boost target. e.g. if you read boost directly via the OBDII port its accurate. This could become the basis for a Stage1 tune.
Attached is a stock boost profile during a 3->4 run and a "tuned" 3->4 run. Able to pickup an average of 2psi so far. Which would be just enough to make a Stage1 tune viable. I can definitely feel the extra torque but need to keep working on the top end performance a bit.
rustyminded rustyminded is offline
Car: Bmw 328i F30
Default 12-04-2014, 09:21 AM
can't wait to see this against JB4 N20
F30 328i - 8 auto.. JB4+FF+EWG, OCC, Injen Intake+scoop, AFE **, AA axle-back - H&R springs, H&R rear SB - Front Strut - F&R BMS spacers..
musc's Avatar
musc musc is offline
Car: 335is DCT
Default 12-04-2014, 09:41 AM
Rather have the two cars in the garage
335is DCT
Default 12-04-2014, 09:57 PM
OK some good progress has been made the last couple of days. I have control over everything we need to successfully tune the vehicle.
The only hitch is one of the sensors is really difficult to reach. Probably a 30 minute job and a difficult one at that as there isn't much room to work with. You have to pull a few parts out and really contort your hand to get it in. Compare that to maybe 30 seconds total to install the rest of the connections which are right on top of the engine. On the plus side the tune functions nicely without the sensor giving most of the torque gains. You just don't get the power gains above 4500rpm.
We'll implement this tune similar to how we approach the M3 JB4. We'll Include all the connections on the harness and then allow end users to decide whether the torque gains from Stage1 are enough to keep them happy or whether they want to connect the devil sensor enabling Stage2 to unlock the rest of their top end power.
I was able to hit the private track for some tuned VBOX Stage2 runs on pump fuel and gains were pretty solid. 0-60 5.3s, 0-100 13.5s, 1/4 mile 13.8@101mph. Knocked a full second off the 0-100mph which was impressive. Stage1 times were a bit better than stock but with the car shifting itself around 6000rpm after the first gear you are working from a part of the power band that isn't increased much with Stage1.
Newguy123's Avatar
Car: 12' 135i
Default 12-04-2014, 10:17 PM
impressive! Not suprised at all though, Terry; a mad scientist in his habitat creating new formulas for all the new badazz turbo machines
12' DCT 135i
#PURETURBOS
#FUELIT
Ando @ BMS's Avatar
Car: bmw 335i
Default 12-04-2014, 11:55 PM
Now that's AWESOME!
Now lets get that 0-60 in 5.0seconds with some e85/race mix!
Bowser330 Bowser330 is offline
N54TECH FTMFW
Default 12-05-2014, 08:06 AM
Is this a hint that you may also tune the c63 m177 ?!
Default 12-05-2014, 08:42 AM
I don't think we'll get involved with any of the AMG models except maybe the C450 AMG if they make one. The volume just isn't there to justify it.
JB4UK JB4UK is offline
Car: F80 M3
Default 12-11-2014, 12:08 PM
same engine as the A45 AMG Terry?
Performance Centre - Large stocks of Burger Motorsport products with UK Nationwide fitting and dyno testing. http://www.theperformancecentre.co.uk/#!shop/c22lx
Default 12-11-2014, 12:19 PM
No idea on that but I'd like to look at some of the AMG models to check their electronics.
JonMartin's Avatar
JonMartin JonMartin is offline
huh?
Car: German car(S)
Default 12-11-2014, 09:54 PM
Its so funny I just helped my sister pick up one of these! I wish you had something for my CLS!
2014 CLS 550 Magno Cashmere White
Default 12-12-2014, 03:31 PM
I've been slowly becoming more familiar with the turbo MB vehicles. Have a photo of your TMAP sensor so I can check the electronics?
Default 12-12-2014, 03:54 PM
On the C300 front testing has been doing well. We've finalized the wiring harness and are gearing up to produce 100 sets which should take 3-4 weeks. Once done we'll be ready to launch a BETA program.
GBX's Avatar
GBX GBX is offline
Car: '08 335xi cp
Send a message via AIM to GBX
Default 12-12-2014, 06:07 PM
any idea if this is the same engine as the GLA250? The Gla makes a lot less power stock but both are turbo 4's . Can't believe MB makes more then 1...any idea?
Default 12-14-2014, 02:41 PM
Would need to see a photo of the engine bay to determine that.
GBX's Avatar
GBX GBX is offline
Car: '08 335xi cp
Default 12-15-2014, 11:17 AM
decided to go with an X1 instead.....JB Stage 1 here I come
Default 12-15-2014, 11:35 AM
Good choice!
FoShizzle's Avatar
FoShizzle FoShizzle is offline
Car: '11 335is DCT
Default 12-15-2014, 07:23 PM
My dad just picked up a C300 today. You can put me down as a beta tester.
JonMartin's Avatar
huh?
Car: German car(S)
Default 12-16-2014, 01:10 AM
I'll take a pic for you soon.
Laramie_05MR's Avatar
Laramie_05MR Laramie_05MR is offline
Car: Evolution
Default 12-17-2014, 03:15 PM
The CLA and GLA share the same engine designation 270920.
The C300's engine designation is 274920
topgun32 topgun32 is offline
Car: MB
Default 12-21-2014, 12:01 PM
Terry,
found this from Kleemann, in hopes to provide a different approach to tuning.
I just leased a C400 and looking to use your development to tune my car.
I live in So Cal (Inland Empire). In case I can be of assistance during beta testing.
http://catalog.kleemann.dk/catalog/4.../#!prettyPhoto
Thanks,
Default 12-21-2014, 12:57 PM
Drop me an email would love to check the car out.
