MFactory MFactory is offline
Car: BMW E92 M3
Exclamation MFactory Racing Clutches & Flywheels - Package Special! - 10-03-2014, 09:45 AM
Hey Guys,
we are proud to offer the following package deals on our range of MFactory Racing Flywheels + SPEC Clutches. Both items are oem compatible, so if you decide further down the line to change either Clutch or Flywheel, this is entirely possible without being limited to specific brands.
1pc Chromoly Racing Flywheels
Made from imported Japanese SAE 4140 Steel. These are Forged, Double Tempered and Super Sub-Zero treated for unsurpassed toughness, with a proprietary surface treatment for increased surface hardness.
Weight - 21lb
Fitment - 135i/335i 06-08 8 Bolt & 09+ 6 Bolt
MSRP - $499.95
SPEC Racing Clutches
Stage 1: Features an integrally molded carbon kevlar-based, high performance organic lining that offers smooth engagement and excellent life. This lining has an integrally bonded steel backing for strength under high clamp loads and temperatures. The hub is heat treated for strength and durability. Best for street and many track/off-road applications.
Torque Capacity - 430lbs
MSRP - $679.00
Stage 2: Features segmented or full faced pure Kevlar disc with steel backing. This lining features excellent drivability like the stage 1, but offers slightly longer life and higher torque capacity. The hub is heat treated for strength and durability. Best for street, drag, pulling and autocross.
Torque Capacity - 485lbs
MSRP - $759.00
Stage 2+: Features a multi-friction disc in a full faced configuration with carbon semi-metallic on one side and Kevlar on the other. Bridging the gap between stage 2 and stage 3, the 2+ offers drivability and engagement quality characteristic of the stage 2, but with a 15-20% higher torque capacity. The hub is heat treated for strength and durability. Great for street, drag, autocross, road racing, pulling, rallye and drift.
Torque Capacity - 545lbs
MSRP - $899.00
Stage 3+: The flagship stage for a high powered street or race car that requires a manageable and friendly engagement, the stage 3+ features a carbon semi-metallic full faced material that offers unparalleled life, friction co-efficient and drivability characteristics in one single package. The hub is heat treated for strength and durability. Great for street, drag, drift, autocross, road racing, pulling, rallye and drift.
Torque Capacity - 671lbs
MSRP - $949.00
Package Deals:
Stage 1 & Flywheel - $1000 inc shipping (+$50 for outside of Mainland US). Normally $1178.95 + shipping!
Stage 2 & Flywheel - $1100 inc shipping (+$50 for outside of Mainland US). Normally $1258.95 + shipping!
Stage 2+ & Flywheel - $1200 inc shipping (+$50 for outside of Mainland US). Normally $1398.95 + shipping!
Stage 3+ & Flywheel - $1250 inc shipping (+$50 for outside of Mainland US). Normally $1448.95 + shipping!
If you have any questions, please don't hesitate to ask or PM me
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 10-24-2014, 12:44 PM
great deals MFactory.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E50,
Fuel-it! Stage 2,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.026")
BostonShant's Avatar
BostonShant BostonShant is offline
Default 11-11-2014, 12:36 PM
interesting...I wish this was around when I was getting mine. I love working with MFactory.
2011 135i - N55 - JB4 ISO - FBO + Meth + Corn
VTT JB Stage 2 with VTT Forge DV and VTT N55 Waste Gate Upgrade
Pump Gas
60' ... 1.850
1/8 MPH ... 98.06
1/4 ... 11.735
Trap ... 122.71
Car: 2013 Genesis Coupe
Default 12-29-2014, 06:48 PM
Isn't this the only Chromoly flywheel available in the market? I'm surprised I haven't heard much about this. How is the chatter like?
Car: BMW E92 M3
Default 12-31-2014, 09:55 AM
There will be some chatter due to it being single mass, but because it is Steel and not Aluminium, it will not chatter as much as the others.
Default 01-04-2015, 01:13 PM
How much weight savings is it from factory? I'm torn between getting a Chromoly slightly heavier with less chatter vs. a lighter weight aluminum with more chatter.
Car: BMW E92 M3
Default 01-05-2015, 04:23 AM
I would need to check the weight of the oem, but our Chromoly Flywheel weights 21lbs
Default 01-05-2015, 11:35 AM
Ok thanks, probably would help showing the weight of the oem flywheel for comparison. I can't seem to find a straight answer on how much the oem dfmw weighs lol.
Car: BMW E92 M3
Default 01-10-2015, 01:06 PM
In stock and ready to ship
Default 01-10-2015, 03:35 PM
The OEM FW weighs approximately 14.785 kg / 32.595 lb, just for future reference, that's 11.5 pound reduction of rotational mass, pretty freaking impressive. That being said I'd like to hear a car with it to see how much chatter there is, compared to a 14 pound aluminum flywheel. Regardless Chromoly material is way better than aluminum.
Car: BMW E92 M3
Default 01-19-2015, 10:14 AM
All orders shipped out. Check your email for tracking numbers
hkninja's Avatar
hkninja hkninja is offline
Car: 535i 6MT
Default 01-20-2015, 04:01 PM
Will it fit 535i?
2008 535i 6MT * JB4 G5 ISO * Luke performance flash * E40 * BMS 100% Meth * AR meowless ** * ETS FMIC * BMS OCC * BMS DCI * ER chargepipe * HKS bov * CDV deleted * Ksport coilovers * UUC short shift kit * AC schnitzer rear spolier *
Car: BMW E92 M3
Default 01-20-2015, 11:30 PM
Yes, will fit the 535i
Default 02-08-2015, 06:16 AM
Whats the pedal feel like with the 2 and 2+ combos?
N54 | Build Thread
Car: BMW E92 M3
Default 02-08-2015, 07:58 AM
They are stiffer than stock, but still easy enough to use in a street car
Default 02-08-2015, 02:27 PM
Thanks! No clutch slip yet but feeling like it's a ticking clock.
N54 | Build Thread
suspenceful's Avatar
suspenceful suspenceful is online now
Car: 2008 BSM 135i
Default 02-13-2015, 01:54 PM
Payment sent for SMFW!
2008 BMW 135i 6MT - Doc Race Single Turbo 6266
749whp/643wtq @ 29psi, weighs 3260lbs
YouTube build: youtube.com/jakespence135
Instagram updates: instagram.com/jakespence
N54 t-shirts, etc: bimmerstreet.com
abhishriv abhishriv is offline
Car: 2007 335i
Default 03-05-2015, 03:10 PM
how does this chromoly flywheel differ to something like the spec flywheel that spec recommends for their clutches?
Car: BMW E92 M3
Default 03-05-2015, 09:37 PM
SPEC also have a steel flywheel, so they are very similar, but is more expensive than ours.
NihonX NihonX is offline
Car: 1M
Default 03-08-2015, 04:38 PM
Are these 1M compatible?
I am looking for a Stage 3+ with flywheel.
Car: BMW E92 M3
Default 03-08-2015, 09:28 PM
Yes, the 1M is the same fitment.
Car: BMW E92 M3
Default 03-20-2015, 09:34 AM
All Flywheels & Clutches in stock!
Car: BMW E92 M3
Default 03-22-2015, 09:31 AM
All PM's replied
Car: 2007 335i
Default 03-23-2015, 04:48 PM
MFactory, please check your PM, issue with the order.
Car: BMW E92 M3
Default 03-23-2015, 08:50 PM
Our flywheel was designed as an oem replacement, so can be used with any oem replacement clutch
Closed Thread
