RoyalFlush RoyalFlush is offline
Talking FBO + E50 Dyno - 10-05-2013, 01:42 PM
The day finally came; I got dyno-tuned by Jake of PTF today.
These are the numbers with my turbos (probably) on the way out; I wasn't hitting boost until low-mid 3K. They'll be getting replaced within a month'ish, so we'll re-tune and hit the dyno afterwards.
The weather didn't help since it was low-mid 90s out of nowhere, and probably hotter in the shop.
Modifications
BMS DCI
BMS OCC
BMS LTT
HPF FMIC
ER CP w/HKS SSQV 4 BOV
AR *** (*******)
Vanguard v2 Exhaust (*******)
Walbro 255 LPH Inline LPFP
coolbho3k's Avatar
coolbho3k coolbho3k is offline
Bravest N54 Owner Award
Car: BMW 335xi
Default 10-05-2013, 01:45 PM
Is it common for turbos to just fail like that?
2007 E90 335xi 6AT Premium Pkg | JB4 G5 ISO | Cheap custom exhaust: OBX ********* ***, Secondary *** Delete w/ Magnaflow Xpipe | WedgePerformance Backend Flash ("PUMP") | DCI | BMS Cowl Filters | Alpina TCU Software | M3 flappy paddles retrofit | NGK "one step colder" Soon: custom oil cooler retrofit, VRSF 7" FMIC
Lifted07Duramax Lifted07Duramax is offline
Car: bmw 335i
Default 10-05-2013, 03:18 PM
Shouldn't it be more around 450/500?
Being FBO and running a PTF E50 tune, I would think it would
VRSF 5" FMIC, VRSF *********, BMS DCI, JB4 G5 ISO, RB Turbos, BMS Flash, Muffler Delete
Default 10-05-2013, 07:02 PM
I don't think it's common, especially at around 53K miles. I purchased this car at around 34K(?) miles, so the previous owner had a lot of time if he ever decided to push it. I'm actually happy; I found a little (major) local hookup for turbos.
Is there a reason you think this (e.g. dynos from people running E50 on stock turbos and FBO), or just wishful thinking?
(Why would you think it'd be more with turbos going out?)
Car: bmw 335i
Default 10-05-2013, 07:20 PM
Didn't realize your turbos are going out
Default 10-05-2013, 07:49 PM
Disregarding that fact, was your reasoning behind your 450/500 numbers because of dynos you've seen?
Car: bmw 335i
Default 10-05-2013, 08:17 PM
Correct. What was your peak psi
Default 10-05-2013, 08:23 PM
Welcome to the 400hp club!
Default 10-05-2013, 08:42 PM
Thanks! After the turbos get replaced I'll be strapping on a meth kit. Hopefully you can welcome me to the 500hp club.
Default 10-05-2013, 09:08 PM
Can you post the links to those dynos (Or the members)? I'll be posting logs when I get them. Jake had a long day and he's in the process of moving, so not in a hurry for them.
335i 335i is offline
Member
Default 10-08-2013, 02:47 PM
Why is the standard in this community STD dyno correction instead of the SAE dyno correction seemingly used in every other group? STD juices up the numbers over SAE by about 10-15 hp, doesn't it? Of course, dyno #s from different dynos/dates/cars shouldn't be compared anyway...but if you make those comparisons, it takes some translation from the numbers here to the numbers reported by the V8 guys.
Default 10-08-2013, 03:00 PM
I wasn't aware and/or didn't notice. I'll grab both when I re-tune and re-dyno.
Member
Default 10-08-2013, 04:55 PM
It's no big deal. I just always thought that STD correction was the choice for dyno sympathy where SAE numbers were disappointing. SAE is the norm in every other car community I've dropped in on.
Default 10-08-2013, 05:41 PM
Personally, 400+whp/400+wtq would never be disappointing on stock turbos without meth.
Car: bmw 335i
Default 10-08-2013, 07:03 PM
Do you have a log of your run you can post?
Default 10-18-2013, 07:45 PM
Here are some logs:
Datazap - RoyalFlush + FBO + E50
Datazap - RoyalFlush - FBO + E50 (1)
Did you ever find those dynos/logs of FBO + E50 6ATs without meth hitting 450WHP/500WTQ? (Other than a tuner's own car - I think Terry hit 456WHP)
You were kind of saying it like it's pretty common.
skysurfer's Avatar
skysurfer skysurfer is offline
Car: 2008 535i
Default 10-18-2013, 08:25 PM
Here are some logs:
Did you ever find those dynos/logs of the 6ATs without meth hitting 450WHP/500WTQ? (Other than a tuner's own car - I think Terry hit 456WHP)
I'm one that hit 450 hp and 481 tq on a Dynojet without Meth, thank to Terry
Since I'm close by, Terry did all the testing
Check sig and my dyno
http://youtu.be/51z_sELokzk
2008 BMW 535i
JB4 G5, BMS Pump Flash, ( Updated FW ), DCI,
Eisenmann Race Exhaust
ER CP
E60 **
450 HP / 480 TQ ( when running AEM 320, 50% E85 )
https://www.youtube.com/watch?v=51z_sELokzk
Default 10-18-2013, 08:39 PM
Nice numbers! (Your percentage of E85 is higher than mine; I meant to put on E50. I'm OCD and was looking for the same car and mods.)
Did you stack tunes?
skysurfer's Avatar
Car: 2008 535i
Default 10-18-2013, 08:44 PM
Nice numbers! (Your percentage of E85 is higher than mine; I meant to put on E50)
Thanx
We were testing the AEM 320 ( not the E85 version ) at the time
I would say I was running anywhere between E60 - E70
Still running same setup
( Meth tank was added a month or two ago )
2008 BMW 535i
ER CP
E60 **
Default 10-18-2013, 08:46 PM
Thanx
That's awesome. I was trying to gun for E60 the first time, but Jake said the car wasn't liking it, so we added some 93 Octane.
I might do the in-tank upgrade to try and supplement more E85, but I'm pretty content right now.
skysurfer's Avatar
Car: 2008 535i
Default 10-18-2013, 08:58 PM
Thanx again
No need to do the intank, unless you plan on running more than 50% of E85
I ran my stock for over 2 yrs, off and on with 40-50 of E85
And the stock is still good, just changed it just in case I wanted to run higher % of E85, which I can whenever I want
2008 BMW 535i
ER CP
E60 **
