Car: 135i, 335i, X5D
Tuner: BMS
535 E85 Dyno Testing, 146rw delta -
02-12-2013, 06:12 PM
Had a chance to do a before/after dyno comparison on a 535 N54 today. He's running the BMS DCI, a custom catback system, and a $100 inline fuel pump. Factory downpipes, IC, etc.
To start we ran 91 octane bone stock. Then we added the JB4 G5 ISO, BMS Flash, and 60% E85. Did a few adaption runs on map 5 which peaked out around 410rw. Then we kicked it over to map 7 and pushed it up a bit further. For kicks I dialed boost up a bit further using map 6 and picked up a bit more power, but he had an orignal plug in #6 (had only replaced 1-5) which would misfire at high RPM so we left boost lower at redline.
Up next I understand he will be adding downpipes and we'll retest to see the gains.
Car: 08 535i
Tuner: Umnitza
02-12-2013, 06:19 PM
Impressive numbers and I just wasted half a tank of gas after installing dci and jb4.
All I can say is I love the power, I need e 85 now.
Tuner: Terry
02-12-2013, 06:20 PM
Oh heck yeah...but can't see the image...I really want those map 6 settings (throughout the rpm range)
Who only replaces 5 spark plugs
Edit: must be on my end, can't see em on other posts either. Nice work though and great results!
Thought I joined a car forum but all we ever talk about is alcohol, meth, and LSD....sooo confused!
Car: 535 XIT
02-12-2013, 07:06 PM
Terry I appreciate the 535 support..
Car: 2009 535i - Jet Black - Sport, Sport Auto,
02-12-2013, 07:11 PM
Seems like anyone who installs the JB4 G5 ISO and BMS Flash could expect to do comparable numbers, considering the only other hard mods were the fuel pump adding next to nothing on this car, and the catback contributing a few horsepower. yes there's a million factors like dyno, weather, etc etc.
E85 is N54 crack - this dyno makes me wonder what the car would feel like if i took it up to 60% E85. Since the first time I used it, I haven't gone a tank without it.
Jet Black '09 535i -- Sport Pkg | SAT | Premium Pkg | Cold Weather Pkg | Navigation | Comfort Access | PDC | Logic7 | CPO -- Mods: JB4 | DCI | E85 (30%)
Car: 2008 335I
Tuner: COBB
02-12-2013, 07:26 PM
Dam! Very nice!! I'm done -I am going to ditch the Cobb only and buy this G5 iso, get the flash and fuel pump. Terry look for an email from me tomorrow for some help.
JB4 G5/BMS Flash/RB Turbos/Dinan CAI/ETS 7" FMIC/ETS DP's/KW V2/COBB/Wavetrac/ER/Forge/BMS OCC/BMS Meth/HPF Clutch
Car: 2007 335i
Tuner: BMS
02-12-2013, 07:42 PM
Nice - I've been at 40% E85 - time for 50% tomorrow.... let's see what my car can tolerate.
07 E92 335I | JB4 G5 ISO | BMS Flash | DCI | BMS DPs | Helix FMIC | Alpina TCU Flash | Walbro GLS392 |
135i is in my sights...
Car: 2011 WRX STI
Tuner: Will be BrenTuning of Worcester
02-12-2013, 07:49 PM
Car: 2008 535xi
Tuner: none
02-12-2013, 07:59 PM
Yup definitely buying bms flash instead of dp's.
2008 535xi auto, JB4 G5, BMS WW Meth kit, BMS OCC, BMS DCI, M5 166 19x8.5/19x9.5 20mm offset wheels 12.9@108
Tuner: BMS
02-12-2013, 08:41 PM
Originally Posted by b1aze
Too lazy to read it. But looking at the first sentence a delta of 120rw+ is easily doable with E85 and tuning!
Minor Diety
Car: 2009 335i AT
Tuner: JB
02-12-2013, 09:04 PM
Any logs?
09 335i Coupe
JB4-G5 Iso, Pre & Post Turbo Meth,
DCI, FMIC, BMS AccessPORT, Alpina Flash
Sold 08 335i Sedan
12.035 at 118.14 1.92 60 foot
JB4, Meth, FMIC, Mr5 CAI
Tuner: Terry
02-12-2013, 09:12 PM
Quick question in regards to the E85 % you're running. What AFR are you targeting? I know that with the higher percentage of Ethanol the DME leans out the AFR and can run higher numbers due to the cooler EGTs and less potential for knock.
Or you could just post logs
Tuner: BMS
02-13-2013, 11:54 AM
Here are logs from map 5, 6, and 7.
Car: 535i
02-13-2013, 01:58 PM
need to get my hands on a cheap cobb for some bms flash love.
Tuner: BMS
02-13-2013, 01:59 PM
Just email us. We have plenty and a low price to go along with them.
02-13-2013, 03:04 PM
Pertinent to the ability to duplicate these numbers - as they mostly hinge on the E85 ratio -
Is the E85 fuel used for the dyno runs understood to be watered-down "mininum 70% ethanol" like the E85 around here, or is it real E85 (85% ethanol)? Just wondering if your 60% would be more like 70% with the "minimum 70% ethanol" E85.
Car: 2008 535i
Tuner: JB4 and Loving it
02-15-2013, 12:47 PM
W O W !!
Who's car is this, these are AMAZING #'s for so little modz
I want this for my car,
OH Wait, This IS MY Car
Shout out to T, for all his knowledge and support
FYI...
this is what I now have in my fuel tank
AEM 320LPH In-Tank Fuel Pump ( Modified to fit my setup )
http://www.aemelectronics.com/high-f...fuel-pump-101/
2008 BMW 535i
JB4 G5, BMS Flash ( Updated FW )
AEM 320 ( in tank lpfp )
BMS DCI
Eisenmann Exhaust - Race ( Quad setup )
ER CP
Car: e92 N54 335i
02-15-2013, 02:33 PM
Looking at the timing curve....more poweris to be had....that's one poor looking curve! New plugs ASAP!
Car: 2008 535i
02-15-2013, 05:38 PM
As T noted, new plugs are installed, #6 was not, cuz of bad plug and I am waiting for the replacement.
More power will come, TRUST Me, many plans to come
2008 BMW 535i
BMS DCI
ER CP
Car: 535i
Tuner: Burger Motorsports
02-16-2013, 03:00 PM
Great numbers.
I just replaced all of the plugs with the NGK iridiums, based on feedback I saw on this forum. They seem great so far.
I'm also looking to upgrade the fuel pump and BMS flash in the next two weeks. Getting lean codes with just a 40%'ish e85 blend, so thought it was time to tweak some more!
Is your goal to run 100% e85? I'm currently running meth, but was wondering if I can get rid of that and just run straight e85. I'm just too lazy to mix the 50/50 meth/water batch all the time.
I currently have stock snails, but want to upgrade to RBs in the future. Which begs another question about getting rid of the meth. Can I hold 20psi on straight e85? I guess time will tell, but I'd hate to unwind the meth kit and sell it only to find it has to go back in to get value from the RBs.
JB4 G5 ISO, BMS Flash, 50/50 E85/91, DCI, AR downpipes, ER CP, Forge DVs, cp-e FMIC, OCC, BB exhaust, WW meth kit, HPFP upgraded, e85 Walbro replacement
Bilstein PSS10 coil overs, Stoptech BBKs, CCW Forged C10's, Conti DW
Car: 535i
04-02-2013, 02:06 PM
Those are some impressive 535 numbers!!
Looks like I need to get on the ball and upgrade my JB3 to a JB4 G5 and look into the BMS Flash.
E60 2008 535i | BMS JB3 | Injen Intake |
Car: 2009 335i
Tuner: JB4
04-02-2013, 02:24 PM
so is the bms flash just help with the higher percent mix of e85?
Car: 2008 535i
04-02-2013, 02:33 PM
Without a Doubt !!
Yes
Before, I was maxing out with 40-50%, with stock pump
Now I run without any issues 70-80%, with AEM 320 inline pump
2008 BMW 535i
BMS DCI
ER CP
Tuner: BMS
04-02-2013, 05:39 PM
Can't wait to get this car back on the dyno with downpipes.
Car: 2008 535i
04-02-2013, 06:15 PM
You and Me Both
bad spark plug replaced and thinking about Oil Temp mod.
Should be the same fit ??
( but we both know that the 3's are not identical to our 5's for all things )
2008 BMW 535i
BMS DCI
ER CP
| Thread Tools |
| Display Modes |
