N54tech.com | BMW N54 N55 135 335 535 Turbo Performance Forum
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Tuner: burger Motorsports
Default Misfire GONE!!!! Wow. - 01-10-2013, 08:20 AM
I had put in new bosch plugs and ran for the past 500 miles. Ride got smoother esp on high boost but still had those intermittent misfires when I idle it for the lights and right after I floor the pedal.
Yesterday, I decided to put in ~0.022" gapped NGK plugs. When I took out those relatively new bosch plugs, I was surprised to see dark carbon on the plugs cylinder 2 again. Basically, that misfire was happening in the same cylinder even with new plugs. Suspected bad coil.
Now, the NGK.....I was amazed by the feel of the car during this morning's commute. NO MISFIRES! Period. Even when I WOT'd (very short period though not to scare other drivers), car just felt so much better.....no engine vibrations.
My car is 6 years old, and I've had JB4 for the past 20K miles out of 45K on the clock now. As soon as I added meth and raised my psi to ~17nish, the vibration started. It went away 70-80% after new bosch but not completely. NGK (gapped to 0.022") was put in and it's gone. Amazing! I've had those intermittent and almost stalling misfires ever since I got this car, and they are gone now. Now, I am pretty sure higher voltage upgraded coils should help also, but they are very expensive.
Next thing, I am going to check and see any black carbon present on the NGK plug cyl 2. If there is, then the coil will be swapped to cyl 6. If I see any of that black carbon on plug 6, then the coil will be replaced.
Now, this doesn't have to be the NGK brand. This 5992 plug was easy to adjust the gap with a coin looking gap gauge. So I would say gapping closer than the factory setting on any brand should help with any highly reving engine.
I will further post pictures of plugs and possibly some logs.....but I don't know what to look at.....maybe the timing values? My timing shoots up to 20 as WOT starts but stay at 15 a while then quickly goes to 0 as boost falls. Is it normal? What's the unit on the values?
Getting there: JB4, Meth, PLM 3" DP, Ebay FMIC(6x6x22), BMS OCC, CDV delete, Short clutch Stop
08n54 08n54 is offline
Car: 2008 535xi
Tuner: none
Default 01-10-2013, 09:17 AM
On turbo cars I usually gap plugs between .019"-.025". Depends on how much hp the car is putting out. N/A cars can run like .045", I remember on my integra i had a lot of miss firing but I gapped it down to .019" and it went away. I don't know what BMW is gapped from stock.
2008 535xi auto, JB4 G5, BMS WW Meth kit, BMS OCC, BMS DCI, M5 166 19x8.5/19x9.5 20mm offset wheels 12.9@108
rudypoochris rudypoochris is offline
Default 01-10-2013, 09:18 AM
Yeah, sounds like you have other issues if you're misfiring WOT at 17psi on new OE plugs. That being said I run these plugs and they are great.
2008 335i Coupe 6MT
JB4G5, DCI, Wagner FMIC
najin23's Avatar
Car: 335i CDV
Default 01-10-2013, 09:27 AM
And I think my problem is solved with these closer gapped plugs. I really doubt that it's from any other issues, valves or injectors...I don't want to see that route to be honest. Apparently though, closer gapped plugs fixed the problem(further evaluate to find out if it's from coils) for now.
najin23's Avatar
Car: 335i CDV
Default 01-10-2013, 09:28 AM
was integra a turbo car? Didn't know.
I can tell my bosch plugs were gapped closed to 0.03" or higher just by looking.
Default 01-10-2013, 09:38 AM
I think .7mm is stock. That's around .028".
2008 335i Coupe 6MT
Eleventeen Eleventeen is offline
Car: 2007 335i
Tuner: Me
Default 01-10-2013, 10:14 AM
It sounds like an injector issue on cylinder 2, especially with the black plug.
11.960@117.93 | 1.753 60' | Street Tires | 93+Meth | Stock Turbos
Car: 2008 535xi
Tuner: none
Default 01-10-2013, 11:31 AM
Acura Integra, I turbo'd it years ago.
najin23's Avatar
Car: 335i CDV
Default 01-10-2013, 12:19 PM
I think you are right.
Here are pictures from cyl 1-6 after 500miles. cyl 2 and 5 plugs have two pictures each.
#1
#2
#3
#4
#5
#6
najin23's Avatar
Car: 335i CDV
Default what's next? - 01-10-2013, 12:29 PM
Should I find a way to get new injectors?
I don't know. My instinct says run another 500miles on the new NGK and evaluate; compare to the bosch plugs. If I see the same results as those pictures above, I may really have to either swap the injectors(esp for 2 and 5) or eventually get new ones. What about cleaning injectors? Does any shop do that? I am sure dealers would do but they might just push me to replace with new ones or charge me for a diagnostic fee. As I test out the NGK plugs, I may probably start looking into getting new injectors.
Thanks for the insight.
Car: 135i, 335i, X5D
Tuner: BMS
Default 01-10-2013, 01:01 PM
Interesting but good news. I may consider stocking these plugs for you guys. NGK wanted us to order a minimum 15,000 of them (lol), but have a note out to our local distributor to see if we can work something out.
najin23's Avatar
Car: 335i CDV
Default 01-10-2013, 01:13 PM
Terry.
I was really going to pm you for stocking these along with those cheap coin looking gauge tools. I just can't find a way to describe it, but my 6 yo bmw became like a new engine. From engine tone to almost zero vibration were something that I could tell the difference just like when I got jb4 installed for the first time. Now I drove 25k miles w/n a year period 2012, and I know I can tell the difference. I do have logs from the bosch above. So once I get logs for the NGK, I will post both.
najin23's Avatar
Car: 335i CDV
Default 01-10-2013, 02:08 PM
Just pasting this for those of you have some misfire issues.
CORRECTION
In case of a reproducible "cold start" rough engine running with corresponding misfire faults, replace the high
pressure injector of the affected cylinder, using the improved part (P/N 13 53 7 585 261). Follow TIS Repair
Instruction RA 13 53 310 for injector removal and installation. If the spark plug from the misfiring cylinder shows
wetness (fuel soaking) after cold start removal, then it should be replaced as well.
I will try this to see if I get any soaked plugs.
Default 01-10-2013, 03:24 PM
What would be really sweet is if they gapped them for us at 0.022". I would pay $1-2 a plug more for that and I actually have the tools.
2008 335i Coupe 6MT
Carl Morris Carl Morris is offline
Tuner: self
Default 01-10-2013, 03:55 PM
I'd rather just gap them myself, I don't trust pre-gapped enough to install without checking.
najin23's Avatar
Car: 335i CDV
Default 01-10-2013, 06:36 PM
+1 since I have the gauge now....
bimmer305's Avatar
bimmer305 bimmer305 is offline
Car: 2007 335i E92
Tuner: JB4
Default 01-10-2013, 07:38 PM
I also had a misfiring issue on cylinder 3 every time I went WOT. At first I though it was a bad codded injector because I just had 6 new injector, coils and spark plugs put in.
I swapped coils and spark plugs and misfire staid on cylinder 3.
I ended up replacing the injector and misfire was gone.
Fault injector had lots of carbon buildup, but spark plug was clean
If you can take out the injector and inspect it maybe?
On a side note, thanks to Terry for helping me troubleshooting it. He found my low fuel pressure sensor was defective, I didn't know.
JB4 G5 / DCI / CDP's / VRSF 7" Intercooler / E85
najin23's Avatar
Car: 335i CDV
Default 01-10-2013, 08:36 PM
Wow.....that does really look bad. I am going to swap coils then injectors.I had significantly reduced small misfires by gapping the ngk plugs. So far superb results. I'd love to take out and physically examine injectors. Now when I take em out can I just put em back? Thanks.
bimmer305's Avatar
Car: 2007 335i E92
Tuner: JB4
Default 01-10-2013, 08:46 PM
Yes. I took mine off a couple of times and put it back in, and no issues.
rem3 rem3 is offline
Default 01-11-2013, 10:50 AM
What is the NGK ref?
az335iat's Avatar
az335iat az335iat is offline
Minor Diety
Car: 2009 335i AT
Tuner: JB
Cool 01-11-2013, 11:37 AM
NGK wanted us to order a minimum 15,000 of them (lol),.
Come on Terry.... place the order for 15k!!!!!
At 6 plugs/engine and perhaps 200 orders/year it would only take you........... 12.5 years to sell all of them.
09 335i Coupe
JB4-G5 Iso, Pre & Post Turbo Meth,
DCI, FMIC, BMS AccessPORT, Alpina Flash
Sold 08 335i Sedan
12.035 at 118.14 1.92 60 foot
JB4, Meth, FMIC, Mr5 CAI
az335iat's Avatar
Minor Diety
Car: 2009 335i AT
Tuner: JB
Default 01-11-2013, 11:45 AM
I wish we were neighbors...... $4/min is good pay.
Gapping a set of plugs has to be the easiest part of replacing a set.
09 335i Coupe
Sold 08 335i Sedan
az335iat's Avatar
Minor Diety
Car: 2009 335i AT
Tuner: JB
Cool 01-11-2013, 11:52 AM
NGK premium platinum single electrode spark plugs to replace the Bosch OEM plugs.
http://www.n54tech.com/forums/showthread.php?t=17698
09 335i Coupe
Sold 08 335i Sedan
najin23's Avatar
Car: 335i CDV
Default 01-11-2013, 12:12 PM
+1
cb224 cb224 is offline
Tuner: BMS
Default 04-04-2013, 03:02 PM
What torque specs did you use?
