N54tech.com | BMW N54 N55 135 335 535 Turbo Performance Forum
(#101)
Byoung8's Avatar
Byoung8 Byoung8 is offline
Car: E90 335i 07
Tuner: Jb4
Default 03-13-2011, 06:51 AM
Tried that no luck. I'm getting 12volts from the switch both opening and closing but the motors don't want to open. The flaps aren't stuck either. I was able to force them open about a credit card thickness
JPSlick's Avatar
JPSlick JPSlick is offline
Holla
Car: 2009 335i 6MT
Tuner: Hondata (myself)
Default 03-13-2011, 05:53 PM
Did you try testing on the battery itself? Just to see if they work? (if possible)?
az335iat's Avatar
az335iat az335iat is offline
Minor Diety
Car: 2009 335i AT
Tuner: JB
Cool 03-13-2011, 08:57 PM
Did the shop weld the by-passes into the exhaust with the "blades and motors" still bolted to the weld flange? Try unbolting one and power it up directly from the battery as suggested.
Byoung8's Avatar
Car: E90 335i 07
Tuner: Jb4
Default 03-13-2011, 09:14 PM
I'm going to try it wired to the battery. Nothing has been installed to the exhaust yet. Install is set for Tuesday so I'm trying to see if everything is working properly first.
UPDATE: connecting to the battery did not work either. Same results as when tapped through a fuse. I hear a click from the motor.
az335iat's Avatar
Minor Diety
Car: 2009 335i AT
Tuner: JB
Cool 03-13-2011, 09:46 PM
Very good idea. Two defective bypasses at the same time seems unlikely but not impossible. If they are defective..... send back for refund.... and run like hell from supplier!
Byoung8's Avatar
Car: E90 335i 07
Tuner: Jb4
Default 03-18-2011, 09:12 PM
So DMH has failed me again...I did not receive the new cutouts today as promised. Does that mean they're a bad company? Dont think so, but they're failing in customer service. He even assured me they would be here by Friday if he 2nd day it on Wednesday! I wanted them ready for EuroSunday, but it may be pouring now so it may get canceled. I could just manually leave them open and run "muffler delete". Here are some pictures of the install.
DMH's product came with plates to cover the open hole whenever the cutouts are removed. So I had my installer just do this and I'll complete on my own when I receive the new cutouts. Installer looked around and figured this was the best spot he could install them. He mentioned this may have an X pipe effect. Here are the pics...
To complete the install, there are 2 grommets located above the cutouts that supposedly lead into the trunk and from there I'll run the wire along the kick plate to the front wherever I decide to place the switch.
Completion pictures and videos will come eventually...for those who are wanting to do this, I hope you have better luck with your experience with DMH.
Byoung8's Avatar
Car: E90 335i 07
Tuner: Jb4
Default 04-14-2011, 01:24 AM
ALL COMPLETE!!!
Sounds and feels awesome. I'm very happy with it and going WOT puts a bigger smile on my face.
Forced Air's Avatar
Forced Air Forced Air is offline
Got Boost?
Car: 2010 135i
Tuner: Burger Drink! its.... ....FAST!
Default 04-14-2011, 07:57 AM
I definitely would have installed pre-cat but guess that works.
- - My Car Domain - -
2010 BMW 135i AT, AW, ///M Sport
JB4|BMS DCI|Macht Schnell 3" cattless DPs|Golf Tee|33% Tint|///M Pedals
On JB3 & DCI, 91 oct, ~2500 DA
12.85@107.63, 12.86@110.97, 12.96@111.06
GbreeE90 GbreeE90 is offline
Tuner: Terry
Default 12-04-2011, 11:01 PM
So how is it? Has anyone done pre-cat? Any pics?
Stage 3+ E90 335i
Remonster's Avatar
Remonster Remonster is offline
Tuner: N55 JB4 Stage 2
Default 12-05-2011, 03:24 PM
Screw pics, we want a sound clip!
nailer335 nailer335 is offline
Car: AW '08 e92 335xi
Tuner: BMS
Default 12-06-2011, 09:45 AM
I'm in for pics... sound clips... before/after dyno... the more information the better.
I'd love to do this on my xi if it were possible, but I think I'd only want to do it if they could fit pre cat... So to clarify, these open at the push of a button? Where did you put the button?
jlcolon2001 jlcolon2001 is offline
Car: 335i 2007
Tuner: BMS (JB4, DCI, WW Meth, BMS OCC)
Default 12-06-2011, 03:57 PM
+1 I'm very interested too
Soulja620 Soulja620 is offline
Tuner: Jb4
Default 12-06-2011, 08:19 PM
How big a difference performance wise do they make??
07 A/W e90-
Jb4/DCI/IC/PUMP+METH=-12.2 @ 116
JB4/DCI/IC/Meth+Race Gas/slicks= faulty ET board
1988 Mitsubishi Starion, built, rwd, lsd, 2.7L I-4 Turbo
Tuner: Terry
Default 12-07-2011, 04:21 PM
I just want to know if I can fit them in a better position than right behind the muffler.
Stage 3+ E90 335i
Forced Air's Avatar
Got Boost?
Car: 2010 135i
Default 12-09-2011, 12:01 PM
Originally Posted by KC_skyrider
Seems odd. I've often argued with my friend till we are blue in the face because he insist my car needs the back pressure and I keep reminding him it's turbo and the pressure behind the turbo is all it needs and if I dumped from the turbo it would be the optimal exhaust path for power. Any ideas why you precieved less HP?
Most likely it would be air getting in the open end of the downpipe and screwing up the 02 sensor readings. Make sure you leave enough pipe between the 02 sensor and the atmosphere. Obviously the larger the pipe the longer it would need to be as exhaust velocity will be lower hence making it easier for air to get to the sensor. So maybe put the dumps a little way into the exhaust rather than on the DP.
Tuner: Terry
Default 12-09-2011, 12:27 PM
I dont think there is room for a cut out right after to DP anyway.
Stage 3+ E90 335i
Bimmerocious Bimmerocious is offline
Car: 335 coupe
Tuner: BMS
Default 01-02-2012, 05:24 PM
Updates on this?
I was fiddling with the idea of getting these and trying to have the can flap on the jb4 control them.
Tuner: Terry
Default 01-02-2012, 06:22 PM
Originally Posted by Bimmerocious
Updates on this?
I have decided against them.
Stage 3+ E90 335i
Byoung8's Avatar
Car: E90 335i 07
Tuner: Jb4
Default 01-05-2012, 01:48 PM
[u2b]http://www.youtube.com/watch?v=utsvp2wGQrg&list=UUiulV36Cl5XDrfz5DUGTtmA& index=2&feature=plcp[/u2b]
I thought I put the vid up already. There's another in car video within the user's channel.
Byoung8's Avatar
Car: E90 335i 07
Tuner: Jb4
I'm not seeing the embedded video, here's the link: http://www.youtube.com/watch?v=utsvp...2&feature=plcp
stylin8o8 stylin8o8 is offline
Car: 2008 535i
Default 04-17-2012, 12:31 PM
So has anyone dynod their car to show proof of loss or gain? im really interested in this im running c less dps, and no secondary cat going to muffler. id probably put the cut out closer to the muffler. but im curious about dyno results thanks guys!
Byoung8's Avatar
Car: E90 335i 07
Tuner: Jb4
Default 04-29-2012, 10:27 AM
I just met a new neighbor who works at a shop with a dyno and he just dyno'd another 335i that was running all kinds of maps. I told him I was just curious what hp I was putting to the wheels. When I set this up I'll be sure to do open and close and see if there's any change, but the sound is awesome when you get on it. Plus I have the control to keep it "classy"
JonBi335i JonBi335i is offline
Car: 08 335i
Tuner: BMS
Default 10-14-2012, 06:47 PM
so have you gone to the dyno?
Byoung8's Avatar
Car: E90 335i 07
Tuner: Jb4
Default 10-30-2012, 09:58 PM
Sorry I've been away from the forums for a few months now. Took a break from all the mods.
I have not dyno'd. Wanted to, but never had the time to set it up...I dont think there's much gains. I would do the ******* DP's then dyno it because that would yield positive gains.
