(#2726)
QFitty's Avatar
QFitty QFitty is offline
Car: 2016 Q50 Red Sport
Default 07-09-2018, 02:23 PM
JB4_Q50_OBDII_3_T1.hex
Sorry for the "Rookie " question but how do I update the firmware?
Mine doesn't show the version you say. I don't see an option in the settings for UPDATE FIRMWARE.
2016 Q50 Red Sport
BMS JB4 Map 1
Infiniti Sport Mufflers
Car: Infiniti Q50 RS400
Default 07-09-2018, 02:45 PM
Ah cool, send a log like that, and let's see what we can do!
Attached the logs, one brake boost @2500rpm, other is just straight up....with traction control on.
Boxy Boxy is offline
Car: 2018 Infiniti Q50 RS400
Default 07-09-2018, 02:47 PM
I can see it's based on the ECU's firmware version. While charge air temp is still a mystery in the process I found the PID for pulling up intercooler water temperature. Might be an interesting parameter to add for evaluating heat exchangers.
Is it something you think we could ask the dealers to flash? I assume if it's a newer firmware version that works then yes, but they likely wouldn't downgrade us to an older firmware version.
Default 07-09-2018, 02:49 PM
No I don't think that is a good idea. We setup the JB4 firmware so it shows MAF temps to everyone now, to avoid confusion. And we'll work on sorted out charge air temperature for everyone. Just be aware when evaluating different intakes what you see on IAT doesn't match the temperature of the air entering the engine.
Default 07-09-2018, 03:25 PM
Make sure car is off and ign is on, connect to Jb4 via BT Mobile app. Go to settings tab on the bottom right. Then under the list it should come up "Firmware Update".
QFitty's Avatar
Default 07-09-2018, 03:35 PM
The is no Update Firmware option in my Settings screen. If I tap "Modify Firmware" it will send me to the message board. I'm sorry but am i missing something or just not seeing it?
2016 Q50 Red Sport
BMS JB4 Map 1
jrobohm's Avatar
jrobohm jrobohm is offline
Default 07-09-2018, 03:44 PM
The is no Update Firmware option in my Settings screen. If I tap "Modify Firmware" it will send me to the message board. I’m sorry but am i missing something or just not seeing it?
When it takes you to the message board - select the N20, Mini, MB, Q50/Q60 Group. Then select the top Thread “Infiniti Q50...” - it will bring up the first post in the thread (you will see the BMS Q50 photo.)
Scroll down to the second post - just below the videos - there are four JB4 files to select from - pick the one on the bottom JB4_Q50_OBDII_3_T1.hex
QFitty's Avatar
Default 07-09-2018, 04:22 PM
Ah yes thank you!
2016 Q50 Red Sport
BMS JB4 Map 1
twister68's Avatar
twister68 twister68 is offline
Car: 2017 Q60 RS
Default 07-13-2018, 10:17 AM
Is this the latest firmware as that post is over a year old?
QFitty's Avatar
Default 07-13-2018, 10:51 AM
The post is updated each time there is new firmware.
2016 Q50 Red Sport
BMS JB4 Map 1
Default 07-13-2018, 11:50 AM
The higher the number on the firmware, the newer it is. You can check your existing firmware version in the "read only" area of the JB4 interface/user adjustment tab. V3 is the latest one posted a couple weeks ago.
twister68's Avatar
Car: 2017 Q60 RS
Default Version Number - 07-13-2018, 12:46 PM
My Firmware Ver. value is 50/3//5
Default 07-13-2018, 12:50 PM
50// is the Q50/Q60, 3 is the firmware version, and //5 is the JB4 board type. So you're on V3. We also make subtle changes from time to time that won't show in the firmware version but are labeled as T1-T99 in the firmware.
Default 07-15-2018, 09:15 PM
Any Red Sport logs on the new map4 yet?
Default 07-16-2018, 11:10 AM
Short runs on the new Map4 I can see the difference. 2017 RS RWD.
jrobohm's Avatar
Default Yesterday, 12:53 PM
Report from the field:
Valeted my Q50 for lunch and put the JB4 into Map 4. The effect was noticeable enough for the valet to ask me what was wrong with my car!
slimjim2525 slimjim2525 is offline
Car: 2016 Infiniti Q50 Red Sport
Default Today, 08:03 AM
Can someone look at this log, and see how it is. This is a 30mph to 120 mph run. JB4 map 6, max boost of +4, and tapering up and down on each RPM range.
Default Today, 08:05 AM
Does it look like my JB4 is operating correctly? I only see a max boost of 16.5??? This is on straight 93 octane.
Default Today, 08:08 AM
CSV log
Default Today, 01:21 PM
Looks okay, why not map 1?
Default Today, 06:23 PM
Map 1 is just too harsh, i like the smoothed out feels of the tapered boost. Think i can go highr on the boost than +4 on 93 octanes? It's a 2016 Red sport. I'm seeing a max of 16.5 on the boost. Is that supossed to be 18 or more if i'm running +4 from 3k to 5,500 rpm? I'm not sure if that correlates 1:1 if that makes sense.
Default Today, 07:13 PM
g0t2bmiirii's Avatar
Default Today, 07:35 PM
Quick question... on the jb4 app which is the setting to show how much boost is the car running? I only see target/eci psi/ boost, which one do i use to calculate boost ??
-Catback + d0wnp1pes
-BMS Cold Air Intake
-Jb4 (map 6)
Default Today, 08:47 PM
Boost.
Default Today, 09:55 PM
Boost.
*bump* thanks Terry
-Jb4 (map 6)
