(#551)
Default 04-13-2018, 07:31 AM
Originally Posted by 135idct
will u do any updates for the BEF?
the pump flash works well on my EWG n55, but the RACE_7C i can't load it i see Drivetrain while flashing.
Sure we update them regularly. Not had any issues reported loading the EWG RACE BEF though.
Snowman Snowman is offline
Car: BMW M135I
Default 04-13-2018, 11:56 AM
Originally Posted by enemigo
listed BEFs probably were never tested in real world. Otherwise author of them would know that e.g. JB4_F_PWG3_RACE_3B.bin speed limitation is set to 0km/h. How it looks? Car starts jerking just after you start to move
Is it true that the map above contains that "bug"?
dror135's Avatar
dror135 dror135 is offline
Car: m1235 2013 f20 n55
Default 04-14-2018, 05:44 AM
after i flash STG 0
where is the log BEF location ? ( on andriod )
m135 2013 at-8 PWG STG2 PureTurbo **-ER CP IC NGK plugs inlet pure tmap 3.5 meth kit cm10
JB4 pump fuel stg2 fuel-it
WaqasRiyami's Avatar
Car: Bmw 535i - 2011
Default 04-14-2018, 07:17 AM
Originally Posted by dror135
after i flash STG 0
First post in this thread
2011 F10 535i N55 PWG AT | JB4 ISO - Bluetooth.Rv3 | N20 3.5bar TMAP Sensor | TREBILA BEF Performance Tune | Pure Stage 2 Turbo | GFB DV+ | Fuel-It Stage 2 LPFP | BMS 100% Meth-Dual CM7 Injection | 93 Octane Fuel | BMS Intake | ER 4" CLess D/Pipe | ER 3" Charge-Pipe | Wagner-Tuning Competition Intercooler | https://i.imgur.com/iR4wm3I.jpg |
dror135's Avatar
Default 04-14-2018, 10:01 AM
thx i mean fisrt log for terry !
P.S's Avatar
P.S P.S is offline
Car: M135i xDrive
Default 04-14-2018, 11:23 AM
Fix the fuel pressure with PI volume and I can help you fix the fuel trims after.
I added more fuel bias until I got rid of hpfp crashes at lower gears. Here's a pile of logs.
M135i xDrive EWG, JB4, Pure S2, Pure inlet, N20 tmap, c a tless, Wagner fmic, FTP chargepipe, Fuel-it PI, BMS PI controller, Fuel-it lpfp, ACF Performance back end flash. 10.9s @ 204km/h
Timdelacerna Timdelacerna is offline
Car: 2014 f30 335i
Default Mhd flasher stating that unsupported DME while connected - 04-14-2018, 11:50 AM
Guys Iím new and need help with this issue.
My f30 335i has a different DME from the factory, I purchased the mppk when the car was built in Germany.
Mhd flasher is stating UNSUPPORTED DME 😩😩😩
Default 04-14-2018, 01:07 PM
I think MHD is still not supporting MPPK DME - They will in the future if thats the case you will have to wait
Default 04-14-2018, 04:37 PM
OK email me and I can send a modified BEF to get the scalars corrected. Remind me on E85 mix in the email too.
siim138 siim138 is offline
Car: F10 535i
Default 04-15-2018, 06:36 AM
Hello,
since the MHD Beta release at 11. April I'm on the way with my JB4 with BMS BEF (PWG1_RACE_1c.)
Power is so smooth and fun to drive, burble ist just amazing also. Map 1 feels the best to me. Amazing job guys!
A little negative side: last night a was abel to drive a little faster and make the pulls like 0-100 MPH - I got 2 times drivetrain errors No reduced power just error kicks in at 90 MPH when I'am in WOT without letting down the pedal...I made a quick MHD read out for DME codes, you can see them on the pic.
I made some pulls later, then no drivetrain error.
With JB4 Map 1 only (over a year since today, I never got this error when driving the car in the same way)
Today I'm able to make some logs with my JB4 and then post them here!
2011 F10 535i M-Sport PWG // Deep sea blue //
//MHD + JB4 BMS BEF PWG1_RACE_1c // M Performance mufflers// 3,5" dowpipe
Default 04-15-2018, 06:48 AM
Originally Posted by siim138
Hello,
Its good to post Logs, To Help BMS to identify your problem & Make updates to the BEF to Make it better.
Its not alot of us with PWG1 out there
Car: BMW M135I
Default 04-15-2018, 10:18 AM
For you who run BMS bef stacked with JB4, what are the biggest ups with running that combo compared to just JB4?
I had a M135 last year with "just" JB4 and i thought that was mental with a properly set up map 6
Now im curious on what might have changed and in what way the bef could improve the drive.
Would it be possible to have a log on any map, with and without the bef to see what has changed?
TideMD's Avatar
TideMD TideMD is offline
Car: 2016 M4
Default 04-15-2018, 10:52 AM
Looks good. What do you think of map5 vs. say map2 behind the wheel?
Riding with map2 the last several days and I feel like the JB4+BEF stack is WAY more drivable than the standalone JB4 map2.
There's still a sudden dump of torque at around 4k RPM that will throw your head and butt into the seat, and can suddenly swing the backend sideways if not ready for it.
However, low RPM range is much smoother and is actually usable for daily use.
Boost levels don't taper to the pressure level of map5, but I'm assuming that's set by the map parameters.
Posted a couple of logs and will upload some more over the coming days and should get to an area with E85 next weekend. Looking forward to trying out various blends.
I installed the JB4 a few months after delivery of my M4 and drove it for almost 2 years before the MHD beta and adding the BMS BEF. In my opinion (and without objective data such as dyno numbers), you can't even compare the JB4 on its own. Adding the BEF makes the power delivery unbelievably smoother and the individualized tweaks that Terry provides for each driver/car set up is top notch.
Add in the MHD flash options (burble, VMAX delete, etc, and more to come...), and the entire system becomes an even greater pleasure to drive. I can't help but smile every time I'm on the road and enjoying a nice leisurely drive, then decide to put the foot down and get that rush of raw power.
2016 F82 M4 // Sakhir Orange // Black extended leather // Opti-Coat Pro
JB4 (stage 3) // MHD + BMS BEF (RACE, rev11c) // BMC drop-in, carbon filter delete // (pending install Injen CPs and JB EWG connection)
LCI rear light retrofit // AutoTecknic front splitters // Mode Carbon High Kick rear spoiler // Status Gruppe rear diffuser // Macht Schnell spacers - 15mm(f), 12mm(r)
Abear Abear is offline
Default 04-16-2018, 07:10 AM
Car feels super strong. To me, the logs look pretty good, trims dip for a bit in 4th gear, but honestly, besides doing logs, the car is not really in the rpm range for very long where it dips.
Just posting to see what you think.
Car: F10 535i
Default 04-16-2018, 07:17 AM
Hello,
Here are the logs, 3th gear pull and 4th gear pull and the last 0-200km/h (125mp/h). ONLY one time I was abel to get the same drive train error, unfortunately I was not logging at this time. I straight cleared the codes with ISTA and then made several over 0-110MPH and 40-110MPH pulls and somehow no drive train error JB4 is up to date to latest FW (for BEF) and all settings are default. Need I change anything in options?
Default 04-16-2018, 08:23 AM
You need to update to PWG ISO firmware to use a BEF, and may need slow speed CANbus.
Default 04-16-2018, 05:15 PM
Hi, sorry I'm a real beginner here.
For PWG ISO help use the PWG ISO thread in this forum.
Nbarrett Nbarrett is offline
Car: 2014 435i Xdrive
Default 04-16-2018, 05:25 PM
Can anyone give me some insight on the BEF instructions? do i just follow the original first page directions? I'm wondering which BEF map is best for my car. does the MHD app walk you through everything I'm just not finding good instructions for doing this BEF. also after all said and done which MAP do you run the JB4 on?
2014 EWG F32 435 Xdrive 6MT_93 Octane Pump Fuel
JB4|Dinan Intake|VRSF 4"|ER FMIC&Charge Pipe|
Default 04-16-2018, 06:21 PM
Directions are in the first post. The fuel used depends on the intended fuel usage. Always E85 mix, always pump, switching between the two, WMI or not, etc.
Default 04-16-2018, 06:25 PM
I'm always93 octane pump until i do WMI or E85. for 93 octane would i use the Race or Pump BEF?
Default 04-16-2018, 06:39 PM
I'm just confused so i download the MHD app unplug my JB4 OBD plug and hookup my MDH Flasher and flash stage0 for whatever the MHD cost. after this do i go back to jb4 to select a tune or leave it on whatever map because it seems as though the directions say to go back to jb4 and set the Future Use D to Bit 6. then go back to the MHD and download then load the appropriate BEF.
this is my first time doing this so sorry for being a noob
Default 04-16-2018, 07:38 PM
Start with RACE
m4driver m4driver is offline
Car: M4 2015
Default 04-16-2018, 10:33 PM
just tested the actual BEF E85 map for the S55.
Anyone else having "problems" with the burble option? The burble only works the first few minutes after starting the engine. When I push the car the burbles won't get back until stopping and starting the engine again. Also having this problem with the normal RACING BEF map for the S55. It seems to be not dependent on the burble intensity or duration.
Bye
Car: F10 535i
Default 04-17-2018, 01:39 AM
Hi, I posted my problem there.
Could you Terry please tell me here:
Is there no chance to use regular (no ISO) JB4 with BEF? Somehow my car operated well with it! Never felt so smooth and strong power.
After one year usage of regular JB4 I never need slow canbus, do I need now change the settings for canbus?
P.S's Avatar
P.S P.S is offline
Car: M135i xDrive
Default 04-17-2018, 08:54 AM
First impression of PI tune is pretty good. Trying to get some 1/4 mile logs and email them.
