acrhalo's Avatar
acrhalo acrhalo is offline
Car: 2017 BMW 440i MPPK
Default 440i Meth Question? - 07-04-2017, 06:15 PM
Terry,
I'm seriously considering taking the leap to Meth. Currently I have the 440i MPPK with intake, **, & JB4. If I add the BMS meth kit, should I also add the (EWG) and fuel control (FF) wires to get the best results, or would I just be wasting my money?
Thanks for the input!
Default 07-04-2017, 08:52 PM
EWG connector suggested. No need for fuel pressure wire.
Mrpink Mrpink is offline
Car: M140i
Default 07-05-2017, 12:08 AM
You won't regret it.
Meth adds some decent gains!
Bullitt1841's Avatar
Default 07-08-2017, 11:03 AM
Get both sets of wires so you can at least log.
2017 F36 440i Gran Coupe | PS2 | MPPSK | Track Handling Package | JB4 | BMS Meth Kit (Dual CM5) | BMS Intake | BMW 513M Wheels | Dinan Shockware
acrhalo's Avatar
Default 07-08-2017, 11:44 AM
The price is cheap! Both bought and on their way!
Default 07-08-2017, 11:55 AM
Exactly
spikiii's Avatar
spikiii spikiii is offline
JB4 addict
Car: powered by JB4
Default 07-08-2017, 03:32 PM
If not running meth - just jb4 + intake + exhaust = no benefits from EWG or FF connectors right?
Default 07-08-2017, 03:58 PM
You might benefit from the EWG wires as far as boost control and smoothness. But no HP gains with either one.
I use them both for running ethanol, smoothness/boost control and logging capability.
spikiii's Avatar
JB4 addict
Car: powered by JB4
Default 07-08-2017, 04:01 PM
Thanks . that's the one i was thinking about. EWG is easy enough to add to the existing B58 JB4 harness right?
Default 07-08-2017, 04:06 PM
EWG is right under air intake box. Pretty easy to get to.
FF is literally the easiest connector to reach on the B58.
Be careful inserting the pins into the JB4 harness for 2 reasons. Don't want to break a pin and you don't want to put them in the wrong location the first time around.
spikiii's Avatar
JB4 addict
Car: powered by JB4
Default 07-09-2017, 03:51 PM
^ thanks for the feedback Bullitt :D
viperstang1 viperstang1 is offline
Car: 340i 2016
Default 08-10-2017, 09:23 AM
once the EWG and FF wires are installed. are there any special settings in the jb4 that need to be adjusted?
Default 08-12-2017, 10:20 AM
EWG, no. FF wires, only if your trims are high or maxing out.
Just by installing either you can drive the car as before if there weren't issues beforehand. Post logs after the install in the Support sectiforfor review.
