(#1076)
MarkMeyers MarkMeyers is offline
Car: BMW 430i
Default 02-12-2018, 05:20 AM
Is it possible to disable the gauge sweep on engine start?
It looks cheap on the new LCI black panel gauges, because the displays refresh rate is too low to make the sweep look nice.
Maybe in a future firmware, an option to disable it via the OBD menu?
Default 02-12-2018, 08:37 AM
Sure... But lets see a video of it so I can see if its working right.
Repo335i Repo335i is offline
Default 02-12-2018, 09:07 AM
Hi have 3 times ask. First question are the settings on page 1 still up to date or are there new ones? Second question I drive in Germany gasoline with 102 octane, I can thus map 2 and map 3 drive without further settings? Question three the Jb4 becomes active only when the engine is warm or?
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 02-12-2018, 09:13 AM
Yes the info on the first post is up to date.
Map 2-3 should be fine for you.
Car: BMW 430i
Default 02-13-2018, 11:26 AM
I donít have a YouTube account, so I uploaded a video here
https://ufile.io/k4gsu
Hope this works.
oldmanjoe oldmanjoe is offline
Car: BMW M140i
Default 02-15-2018, 02:26 AM
Gute Morgen,
1. Das JB4 system aktiv nur wenn das Motor warm ist.
2. 100 Benzine in der Schweiz oder Deutschland ist gleich 93 Octane vom USA, deshalb Map 2 is mŲglich.
Default 02-15-2018, 03:06 AM
Hi thanks for the answer .. Map 3 is not possible with 102 octane in Germany? Or can I drive map 3 without problems?
Car: BMW M140i
Default 02-15-2018, 03:23 AM
Mike says its possible. I am no expert. I just look at it in terms of performance vs risk and think your not getting much more at Map 3 than Map 2 and taking on a lot more risk of problems with a stock car.
Default 02-15-2018, 09:12 AM
OK, I do not understand that now. I thought map 3 is for stock cars. Why should that be risk now?
Car: BMW M140i
Default 02-15-2018, 09:55 AM
I thought from your profile you had an N55, ie different engine but I see a post where you declare ownership of an M240i.
Default 02-15-2018, 10:08 AM
Map3 is suitable for a stock car on good quality fuel like RON 102. Might even be OK with map5. Log it if you want us to double check.
Default 02-15-2018, 02:04 PM
Thanks for the answer .. Logging is currently difficult because of thin winter tires and minus grade outside .. But as soon as the summer tires are on it I will log
theresmy5 theresmy5 is offline
Car: 2017 540i xDrive MSport (B58)
Default 02-18-2018, 10:26 AM
Hey Terry, guys- experimented with Map 3 today. Car is totally stock otherwise; am I safe running Map 3 according to the log? Running Shell octane 93.
Default 02-18-2018, 11:22 AM
Log is too short to tell much.
Default 02-18-2018, 12:39 PM
Iíll post another. Do you need distance or speed?
I M inluv340 I M inluv340 is offline
Car: BMW 340i FBO WMI
Default 02-18-2018, 02:02 PM
More time at WOT.
