camberadam camberadam is offline
Car: 09 e92
Default 10-09-2017, 09:33 AM
Originally Posted by sirfredi
I just tried to set ET = 1, it has not changed at all, I was hoping it would give a solution, but we have 12v with the car at rest (which excites the coil and in turn starts the 2nd pump)
I have tested both ET = 0 and ET = 1 and the result is the same.
Look at the images where you can see the pin 7 and the WMI configuration
obtain the same result. TPS = 50 still giving ground ...
@trebila, you have good friendship with Terry and Steve. Could you ask what the reason and the possible solution might be?
Thank you
Which is it? One post your say 12v triggers the pump & the next you're saying ground triggers it. I've been guessing at what you're trying to say for most of this post.
sirfredi's Avatar
sirfredi sirfredi is offline
Default 10-09-2017, 09:54 AM
@camberadam
We have tried on 2 different cars.
One with meth kit with FSB and Stage 3 of coolingmist (with SS = 100) and another car with kit bms (with SS = 60).
In the 2 the same result.
sirfredi's Avatar
Default 10-09-2017, 10:17 AM
English is not my first language
I'll try to be clearer.
In all cases I have ground on pin # 7. The pin # 7 ALWAYS sends a signal of ground, in my case it doesn´t matter what configuration you have made so far in the jb4 mobile, it behaves like an NC contact and what is needed is to behave as a NO contact, so that the pump doesn´t running all the time, it is necessary that these pin shoots only when it is necessary, is not all the time CLOSED and transmits ground that excite the relé coil.
I mean ... have the car on or have the car in stand by, if I use the pin # 7 and use the battery positive terminal of the car I always get 12v, when I should only send ground signal when the car is on above 2500rpm and have the psi set.
Do you understand something better?
sirfredi's Avatar
Default 10-17-2017, 01:13 AM
not updates
