18bmwb58 18bmwb58 is offline
Car: 2018 bmw 340i m sport
Exclamation B58 running lean - 05-16-2018, 10:58 AM
Hey guys im new to this platform and i wanned to get some opinnions on AFR i realized these cars run lean but whats too lean ? I got bolt ons jb4 and at 17 psi 3rd wot im at around 14-15 afr
Moderator
Default 05-16-2018, 03:03 PM
If you can post a log we can further make sure all is running the way it is supposed to. To answer you question though yes, they do like to run lean around 14-15 AFR mid range and come down to 13-14 redline.
Default 05-16-2018, 04:00 PM
I have the wireless bluetooth it only lets me email logs.. do you have an email i can email the logs to?
335xiRT1 335xiRT1 is online now
Default 05-16-2018, 04:38 PM
Only thing I hate about the app.
You can’t upload and post logs through it.
What map are you running.
2017 340i JB4/ BB TBi/ intake
Default 05-16-2018, 04:47 PM
Map 5 and map 3 ill try to enail it to my self maybe it will let me post it ... i just got the ewg harrness to fix my tb closure where can i find the flex fuel wires ? I looked around but cant find anything on the site
Default 05-16-2018, 05:14 PM
You have to run map 6 and absolute values for EWg to work and help throttle closures
Try flat 15psi first and see how it looks.
fUA at 10 to start, if still throttle closures increase FUA slightly
Default 05-16-2018, 05:15 PM
I like to stay under 14 AFR but that’s just me.
Default 05-17-2018, 03:38 PM
Ok guys did more logging 3rd and 4th map3 3k rpm 4th gear afr starts at 15 and slowly goes down to 13 as rpm rises
Wickedowesix's Avatar
Car: 540i G30
Default 05-17-2018, 08:08 PM
The logs are saved on your phone under the jb4 folder. Go in there and attach the .csv to this thread.
Talking 05-18-2018, 04:26 AM
Got it
Moderator
Default 05-18-2018, 09:04 AM
Got it
Log is okay but not long enough to fully evaluate. Get a log in 3rd gear from 2k rpm - redline. Make sure pedal is at 100% or else the logs won't be accurate.
