Petek135i Petek135i is offline
Car: E82 bmw 135i coupe
Default Should I update my firmware and what version? - 06-19-2018, 12:04 PM
Hi, I recently bought my e82 135i with gen 5 jb4 fitted. This was done Sept 2014.
Apparently it had the anti lag chip fitted too, January this year.
Current firmware is 32/5//2
Should I update the firmware and what version should i choose?
Thanks in advance for your help.
ps. data log added (I think?)
180605_1839.csv
180605_1935.csv
Dave @ Fuel-it!'s Avatar
Default 06-19-2018, 12:48 PM
Originally Posted by Petek135i
Attachment 76039
Attachment 76040Hi, I recently bought my e82 135i with gen 5 jb4 fitted. This was done Sept 2014.
ps. data log added
Always best to utilize the most up to date firmware-
http://www.n54tech.com/forums/showpo...68&postcount=2
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 06-19-2018, 12:59 PM
So 32 _ 12?
Default 06-19-2018, 01:22 PM
So 32 _ 12?
Correct
e92 AT 335xi 2.0
Doc Race Kit 6062
Thumbs up Thanks - 06-19-2018, 01:28 PM
Brilliant, and i don't have to cut diodes?
Default 06-19-2018, 10:11 PM
If you have the g5 board w. Anti lag etc already - i would assume no
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 06-20-2018, 08:31 AM
Would you mind having a look at my logs too please
Default 06-20-2018, 09:34 AM
Post up the log and we'll take a look
Default 06-20-2018, 09:39 AM
Thanks.
Hope that's worked
Haynpunch's Avatar
Car: 07 E90 335i
Default 06-20-2018, 07:05 PM
Thanks.
Hope that's worked
Those are the same logs you posted yesterday
update to the latest firmware located at bottom of this post
32_10 or 32_12
http://www.n54tech.com/forums/showthread.php?t=10605
set settings to default Post #3
enable 6cyl Timing Logging
07 E90 AT 335I 130k
JB4 G5 - Race BEF
DCI
VRSF CP - TS RP BOV-Orange Spring
VRSF V2 D-P's
7" FMIC
Stage 2 Bucket
Default 06-21-2018, 06:34 AM
Thanks.
Hope that's worked
These look to be the same old logs?
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 06-21-2018, 09:22 AM
Thanks Dave
Sorry they are lol.
I'll do some at weekend with new firmware and settings. Work too busy atm.
How do I enable 6 cylinder timing please?
Value currently at 0
Default 06-21-2018, 10:29 AM
Thanks Dave
Sorry they are lol.
What year is your car?
Software Version: IJE0S for MSD81 (most 2008 and newer cars), I8A0S for MSD80 (most 2007 and early 2008), INA0S for 335is models, and IKM0S for 1M models.
Default 06-21-2018, 11:29 AM
2008 135i
Default 06-21-2018, 11:50 AM
Is there a way to tell for sure, which it has?
Thanks for all your help btw ����
Default 06-21-2018, 12:29 PM
Try I8A0S and see if you have any values.
Default 06-21-2018, 12:36 PM
Thnx
Default 06-21-2018, 09:27 PM
Thnx
You do that under the user adjustments tab, select value / save
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 06-21-2018, 10:46 PM
Thanks Dave
I'd worked that out. So much to learn though. I haven't had a hobby car for ages. The last one had a carb
Default 06-22-2018, 11:28 PM
Thanks Dave
My advice, read the stickes that apply to you, & if you donít understand something, just ask, lots of info, lots of n54 terms/jargon.
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 06-22-2018, 11:38 PM
Thanks.
It's running much better with new firmware and the user defined settings back to defaults.
Looking forward to doing some logs.
Default 06-25-2018, 01:49 PM
180622_1916.csv
180622_1920.csv
Hi, I updated firmware and reset settings to default.
The settings, as I bought the car, were as follows:
FUEL BIAS:
3k - 25
3.5 -30
4k - 30
4.5 - 30
5k - 30
5.5 - 28
6k - 23
6.5 - 20
7k - 18
DUTY BIAS:
0
25
30
30
35
35
35
40
40
40
40
40
Default 06-25-2018, 01:55 PM
sorry I have to type it all out. Cant upload the screenshot for some reason.
Boost safety - 21
Default W G pos. -70
PID gain - 40
A S Boost reduction - 80
FF / WGA - 150
Fuel open loop - 90
Meth safety mode - 0
Meth trigger mode - 100
Max boost 1st 2nd 3rd all 0
Tmap voltage 1.97
FU A - 0
FU D - 2
Tmap - 15 tbc.
Default Please look at my logs - 06-25-2018, 02:03 PM
6 cyl timing - 15
Anyway point is the car has developed a misfire since I updated etc. No misfire codes though. I looked at the plugs and 4 and 6 were black with soot. all other plugs good.
Did notice pcv hose connector has been leaking above these plugs. Also car has been smoking intermittently. So Im going to veplace pcv valve.
Could previous tune, supposedly done by a shop on a dyno according to the guy who sold me the car (I have a reciept) masked the problem that is causing the misfire? Or is it just a coincidence?
Please check out my logs if you have a moment, assuming they loaded correctly.
Default 06-25-2018, 11:25 PM
6 cyl timing - 15
More than likely a coincidence.
e92 AT 335xi 2.0
Doc Race Kit 6062
