MaruCHAN MaruCHAN is offline
Car: F80 M3
Default 2018 F80 ZCP JB4 Map 6 result, my new best friend is Terry now lol - 03-15-2018, 10:08 AM
First of all, let me introduce myself, My name is Anthony, picked up a 2018 F80 ZCP 6spd a few mths ago, got the JB4 installed last month and i have been getting tons of help from Terry@BMS, its like daily help from analyzing logs, suggestions of different maps and settings. It is running exactly what i wanna.
First I started out with map 1, then Terry told me it doesnt hurt anything to try map 2 just to see, which i did and seems like the car is taking it good and later on i asked him questions about map6, with Terry's help on duty bias tuning this is how the car runs now.
fwiw, and this is where i started, Map 1, i only plugged in both map sensors, Terry suggested me to also plug in the fuel mass sensor and ewg for better boost control if i want to run map6
After plugging all the sensors, got tons of help from Terry, and viola..... its working perfectly!
Here is the ride
Zeppelin Zeppelin is offline
Car: E92 335
Default 03-19-2018, 06:23 AM
Good job !!
Silverstone_F80 Silverstone_F80 is offline
Car: 2017 f80 m3 zcp
Default 06-21-2018, 10:36 PM
What supporting mods do you have done to tnt car ore its it just stock with jb4?
Default 06-24-2018, 10:01 AM
onfire onfire is online now
Car: X5 50i F15
Default 06-24-2018, 12:20 PM
Map 2 doesn’t command 23psi ?
TideMD's Avatar
TideMD TideMD is offline
Car: 2016 M4
Default 06-24-2018, 05:58 PM
Hey Terry,
Are there noticeable gains running map 6 over maps 2 or 5, particularly now that the duty bias autolearning is activated? Currently, I'm running map 2 with 93 pump (occasional E85 mix), exhaust mods, plus the S55 RACE BEF with MDH.
Always interested in safely/reliably squeezing out as much power as possible with the current setup. (although, getting a strong itch for WMI and next level upgrades...)
2016 F82 M4 // Sakhir Orange // Black extended leather // Opti-Coat Pro
JB4 (stage 3) // MHD + BMS BEF (RACE, rev11d) // BMC drop-in, carbon filter delete // Injen CPs // VRSF down Ps // Active Autowerke midpipe
LCI rear light retrofit // AutoTecknic front splitters // Mode Carbon High Kick rear spoiler // Status Gruppe rear diffuser // BMS ceramic black billett exhaust tips // Macht Schnell spacers - 15mm(f), 12mm(r)
Default 06-25-2018, 08:24 AM
It depends what your end goals are, but I didn't see much gains with custom map 6 vs map 2 that I daily on.
DSCOFF's Avatar
DSCOFF DSCOFF is offline
Car: 335i coupe N54
Default 06-27-2018, 10:15 AM
Presuming u are running 22 psi on map 6 vs Map 2 which is a 22psi Map power should be pretty much same with all connectors connected on jb4...?
2009 N54 335i coupe, 6AT PD trans, Stage 3 XHP, Built Motor, 9.6:1 Comp Ratio, Ported Head, Trebilia Custom Flash, JB4, Mhd flasher, Ngk 97506 0.018 gapped, PI Kit 100% E85, Jb4 PI integration, Stage 2 Pure Turbos 25.6psi, TFT inlets, Stage 3 Fuel-it Fpr, FBO, 422rwkw Mainline Dyno Aus
2016 M4 Competition Pack, 7-sp DCT, Jb4 Map 6
25.0 psi, JB4 S55 Bms E70 BEF tune, MHD F series flasher, M4 plugs gapped 0.020, stock everything else, 364.9rwkw Mainline Dyno Aus
