(#101)
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2015 335i GT MPPK+
Default 07-11-2017, 04:48 PM
It's not a CA issue its a USA issue.
Sure doesn't seem that way in NY.
Mike Levy
2015 335i xDrive Gran Turismo
m123 m123 is offline
Car: 440i F32
Default 07-12-2017, 11:13 AM
Very very dissapointing. Can we at least have it outside the us? Waited for this for months and now this
F32 440i JB4
F11 550i N63tu JB4 Stage 1
Default 07-12-2017, 12:06 PM
You are completely wrong, but little reason to get in to it on the forum. If you have any additional questions on the change feel free to email.
Default 07-12-2017, 12:08 PM
The n63tu hardware is identical to the s63tu hardware. At some point we will add the n63tu firmware to the first post but leave it as an officially unsupported platform. So if you want to run one you can but with the understanding you're going to have a CEL on within the USA with the MAF sensors unplugged, and outside the USA can use passive delete to reset that CEL every startup.
Car: 2010 535
Default 07-12-2017, 05:07 PM
When is the intake going to be released for sale?
Default 07-12-2017, 06:14 PM
It's under development. We don't have a timeframe yet for it.
Default 07-16-2017, 09:12 AM
Customer sent in this useful photo from installing his BCM. It uses the same BCM as the M5/M6 and you also have to remove the passenger side intercooler to access the connectors.
Car: 440i F32
Default 07-17-2017, 07:13 AM
Ok, Hope to get this possibility soon.
F32 440i JB4
Default 07-17-2017, 12:22 PM
Firmware is in the first post. We'll slowly add extra documentation to the first post as needed.
enigma99a enigma99a is offline
Car: 550i
Default 07-17-2017, 02:35 PM
Thanks for the update. Is there a reason passive delete can't be used within the USA?
Default 07-17-2017, 02:41 PM
Emissions compliance.
Mike_L's Avatar
Anti-Social
Default 07-17-2017, 03:09 PM
Why is this able to work with the S63TU without throwing codes but not the N63TU? Is it not possible to keep the MAFs enabled somehow?
I though it may have been because the S63TU didn't have MAFs, but I checked and it does
Mike Levy
Default 07-17-2017, 03:54 PM
It's just a difference with the n63tu DME programming.
Car: 440i F32
Default 07-18-2017, 12:58 AM
Ok, Just to get this right:
I oder the S63Tu JB4 with BCM and use the firmware from the first post.
I can drive it in map 1 without unplugged MAF but will have less power, or I drive it in map 2 and will have a CEL.
To add the BCM I will need to cut wires.
F32 440i JB4
Mike_L's Avatar
Anti-Social
Default 07-18-2017, 02:00 PM
I was under the impression that all the MAPs ran MAF free and threw codes. The Stage 1 doesn't.
Mike Levy
Default 07-18-2017, 02:06 PM
If you leave the MAF connected with the n63tu JB4 you'll have stock like power. Sounds like a waste of time to me.
Car: 440i F32
Default 07-19-2017, 02:23 AM
Ok, no problem, MAF will be unplugged.
What about the wire cutting needed only for BCM or always?
F32 440i JB4
Car: 550i
Default 07-19-2017, 08:50 PM
Thinking about going the BCM route. If I spend the time to hook it up initially, is there a way to make a simple uninstall for maintenance dealer work? (like tie up the wires not connected for example)
Default 07-19-2017, 08:56 PM
You could tuck it out of the way but anyone looking carefully would be able to find the wiring.
