Nordic335IM3 Nordic335IM3 is offline
Car: BMW 335I N54
Default map5 log - 06-11-2018, 12:36 AM
did pulls in map5 yesterday,hoping the autotune would set things right.
I had this strange oscillation going on, in the start of wot runs, could clearly hear the airflow from the inlets going on off on off and then on and boosting like normal..
I looked in the settings afterwards and FF is set to 5 ?!
could anyone take a look at the log?
Car: BMW 335I N54
Default 06-11-2018, 08:21 AM
just looking for feedback from the in-the-know guys
Car: BMW 335I N54
Default 06-11-2018, 12:01 PM
did a run in map 2 today , after I input the standard values in the settings.
Dave @ Fuel-it!'s Avatar
Default 06-11-2018, 02:22 PM
FF looks better here, but timing throughout the pull doesnt look great, craps out a bit up top.
Are you using any e85?
Do you get the oscillating issue on map 2?
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: BMW 335I N54
Default 06-11-2018, 03:05 PM
Im just using shell vpower99, which is supposed to be E10, but who knows.
E85 is not available ,Ethanol can be bought at hardware stores , cheapest is 15 usd for 5 litres :-/
The ocillation was not as bad with the standard settings, but still it should not happen.. maybe I will do a video from inside the cabin to show what it does.
I will do logs tomorrow again..after I check plugs and coils.
1. what should I do settings wise?
2. should I try spray pure Ethanol to up the octane (single CM10 cp nozzle)
(I dont have any meth at the moment - yes that is also hard to get and even more pricey)
thx
Car: BMW 335I N54
Default back - 06-12-2018, 01:27 PM
so how does these look:
did a run in map 2 and 3 , still get the hesitant ocillation in the beginning..
(have den. alcohol and water in the meth tank)
map3 gave a misfire in cyl1
also its like the JB4 function with limiting boost until oil is heated .. how is that possible?
E92 N54 2007 (kline)
mods:CP + TIAL, MMP in & outlets, BMS 10 C ALC/H2O, JB4 mhd BEF , pipesdown + no cats, 5" stepped wagner IC , öhlins shocks & springs , M3 swaybar front
Car: BMW 335I N54
Default 06-12-2018, 02:26 PM
added 5 litres of E to the tank.. with 25-28 litres gas in the tank
did a map3 run.. afterwards I got kicked into map4, no codes
and did a map 1 run also.
felt stronger.. I think the problem has something to do with the wastegates
, when I changed FF higher, the ocillation was less .. but it keeps learning downwards .. :-/
Default 06-12-2018, 05:13 PM
FF needs to go down because you are overboosting that's why you got kicked into map 4 the first log on map 3.
Lower FF to 60 and get another log.
Car: BMW 335I N54
Default 06-13-2018, 01:09 AM
okay , will do..
do you know why it ocillates?..it starts boosting,then stops for a second and the n goes on again and boosts fine ..
its on WOT only
if I ramp up boost slower, it does not do it..
Car: BMW 335I N54
Default 06-13-2018, 09:55 AM
https://www.youtube.com/watch?v=jJeQT1UOTyE
short clip of the inlet sound. this is not wot though.. small acceleration in 4th , engine not fully warmed up..
Car: BMW 335I N54
Default 06-13-2018, 10:37 AM
to new logs...
Default 06-13-2018, 11:35 AM
Much better to me, I don't see any oscillation in the logs. Trims are pretty far apart though and that may cause you to go into safety. How is your meth nozzle setup?
Car: BMW 335I N54
Default 06-13-2018, 02:45 PM
10 cm nozzle in the CP. den. alcohol and water, it was 50/50 , but I added some alcohol to increase octane maybe 60 or 70 alcohol.
Had another guy take a look and he told me it could be JB4 issue:
WGDC is flat line up to 4600 rpm because JB4 can’t control it lower so it’s over boosting the set point significantly
This is a major issue with JB4, it can’t control WGDC less than 25
how Do I fix this ?..other than dictching the JB4 and go flash only
Default 06-13-2018, 04:51 PM
You don't need to ditch the Jb4, just follow directions. I see your Duty bias settings need adjusting. Make sure they are all set to 50 across all RPM. Get another log with FF at 50.
Car: BMW 335I N54
Default 06-15-2018, 01:11 PM
two logs in map 1
on the first one it had a hesitation at around 3k rpm otherwise it was ok
but it still learns down , and it still does the occillation thing..there must be a way to tune this out?...
have others with inlet & outlet experienced this ?..
also I know the BEF adds to the boostlevel but 18 psi in map 1 seems high?
Car: BMW 335I N54
Default 06-18-2018, 05:51 AM
bump
Car: BMW 335I N54
Default 06-22-2018, 08:45 AM
removed the MHD flash, now OEM.
jb4 in 4/3 setting
have made log in map1.
Default 06-22-2018, 05:54 PM
Your trims are way off at the end of the run and AFR is perfect between banks. How are your injectors? HPFP and LPFP looks good so I can't think of anything else. Does the car run better without the flash?
Car: BMW 335I N54
Default 06-23-2018, 03:31 AM
yes I thought so too with the trims, they used to look more even before?..
this was a smooth run, without the occilation
but I still think something is off regaring the boostlevel.. with oem flash and normal JB4 setting would map 1 not stop at 13 psi?
my injectors should be fine, have just cleaned them and changed teflonseals and decouplers..
should duty bias still be 50 without the MHD flash?
Default 06-23-2018, 09:54 AM
I think map 1 is 15 psi IIRC.
Yes duty bias should still be 50.
Car: BMW 335I N54
Default 06-27-2018, 02:22 PM
well Im at a loss.. I don´t know what to look for or at, to determine what action to take..
this boost on off on off on...(like the video) is baffling..
is the JB4 truly 100% disabled in map 0 ?
Default 06-27-2018, 03:51 PM
Yes, on map 0 the Jb4 should be disabled. You can pull it off if you need to make sure, shouldn't take too long!
Car: BMW 335I N54
Default 08-03-2018, 07:14 AM
https://www.youtube.com/watch?v=Y0vG...ature=youtu.be
the pulsing caught on video .. does the JB4 have trouble with wgdc below 25? (someone told me that)
Default 08-06-2018, 03:12 PM
Have you checked or swapped solenoids? I'm not too sure to be honest.
Car: BMW 335I N54
Default 08-08-2018, 02:56 PM
yes, I have bought a new one coz the nipple broke, so I have tried running both turbos on each solenoid alone, and one turbo at the time also, but it did not change anything.
I dont know the logic / feedback system of the wastegates so Im at a loss as to what to try next...
only time it does not do it, is in map 4
