(#901)
Nicoo70 Nicoo70 is offline
Car: M135i
Default 02-16-2018, 04:41 PM
Hello , i have an M135i PGW with a ******** and i run in map 2! what is the interest of putting my jb4 in ISO? Thank you
Car: F25
Default 02-16-2018, 05:38 PM
I'd posted earlier about stacking BM3 OTS with JB4 on my PS2 X3. Common sentiment seems to be that they'll "fight" each other, but I haven't really found that to be the case.
I've been playing with stacking for a little while now, and with some tips from another stacked user, cnm135i, I've come up with something that seems to work pretty well, hitting the boost targets that the flash itself couldn't at my altitude of 5,500 feet.
Here are some logs from my baseline 15 psi tune. It outruns stock F10 M5s and F15 X5Ms at this altitude with this tune. Runs to 60 in 4.1 and 1/4 in 12.29 @ 116, according to Dragy.
I'm on stock fuel system other than a Walbro 450. I'll be installing JB4 controlled PI system with hardwired flex fuel sensor soon, once the parts roll in.
I'm thinking a BM3 E30 2H tune or custom E50 tune and the FF PI should give me some ethanol content variability and enough octane to put together some custom map 6 settings with 19, 23, and 27 psi targets.
1st through 3rd - https://***********/u/hardparker/log...-8-11-18-19-20
partial 3rd - https://***********/u/hardparker/log...-8-11-18-19-20
5th - https://***********/u/hardparker/log...-8-11-18-19-20
Default 02-16-2018, 06:54 PM
With ISO firmware it's impossible for the flash and JB4 to "fight" each other. DME BT is quite high here but not a big issue. Mapping seems reasonable enough to me.
I'd update the JB4 software so duty bias can auto tune itself a bit closer to WGDC.
cnm135i cnm135i is offline
Car: m135i
Default 02-17-2018, 11:21 PM
Terry
Any closer to a solution for this post tip-in under boost?
M135i, PWG, Pure Stg2, WMI, bootmod3 + JB4
100-200kph: 7.0sec (93 and meth)
www.youtube.com/user/npharkes
WaqasRiyami's Avatar
Car: Bmw 535i - 2011
Default 02-17-2018, 11:25 PM
Originally Posted by cnm135i
Terry
I wonder why not everyone is getting this underboost..
check out my log...
2011 F10 535i N55 PWG AT | JB4 ISO - Bluetooth.Rv3 | TREBILA BEF Tune | BMS Intake | ER 4" CLess D/Pipe | ER 3" Charge-Pipe | Wagner-Tuning Competition Intercooler | https://i.imgur.com/XEO6ZpR.jpg |
Coming Soon: | Pure Stage 2 Turbo | Custom High Flow Inlet | GFB DV+ | Fuel-It Stage 2 LPFP | N20 3.5bar TMAP Sensor
dror135's Avatar
dror135 dror135 is offline
Car: m1235 2013 f20 n55
Default JB error code - 02-18-2018, 01:03 AM
error code
i cant clear this error
i try from carly apps and ISTAD too
but its not clear
i havn't DT
how to clear this code ! ?
m135 2013 at-8 PWG STG2 PureTurbo **-ER CP IC NGK plugs inlet pure tmap 3.5 meth kit cm10
JB4 pump fuel stg2 fuel-it
Car: m135i
Default 02-18-2018, 03:25 AM
Originally Posted by dror135
error code
but its not clear
i havn't DT
Did you disconnect your MAF sensor? Then that is the reason.
Car: m135i
Default 02-18-2018, 03:27 AM
check out my log...
Yep, yours looks PERFECT! Terry might be able to tell if this has something to do with the BEF or that you run stock turbo......???
Default 02-18-2018, 04:39 AM
Actually, I think its BEF related.. Did you try other BEF's or Terry' Beta BEF ?
Why dont you try TREBILA BEF ?
dror135's Avatar
Default 02-18-2018, 05:56 AM
nope
Marlinman's Avatar
Car: 335i coupe 2010
Default 02-18-2018, 06:35 AM
Two logs since lowering FF. Boost is more on target albeit not perfect. Everything feels fine. Please see logs. Of note however, are a drivetrain malfunction:please drive moderately, that will pop up in the iDrive when Iím cruising on the highway under mild load say in six or seventh at 2.5K RPM on a slight incline and the jb4 picks up the 120308: boost is lower than expected. When this happens there is nothing that I feel or hear that would worry me, please advise. I donít know why it would throw this code of boost is relatively on target. Thanks.
Default 02-18-2018, 11:09 AM
error code
The MAP sensor is the one on the brown patch on top of the manifold. Put that connection to stock to see if its wiring related.
Default 02-18-2018, 11:10 AM
Just means boost is lower than the DME is expecting to see under those conditions. We have a potential fix for false alarm under boost in the latest MHD BEF. If on the stock flash you'd want to log it coming up so we can come up with a work around.
Your shift reduction is too high IMHO, I'd lower that. No reason to drop boost this much during shifts.
Default 02-18-2018, 11:12 AM
Terry
I only look at JB4 CSV logs. Don't see anything attached there.
dror135's Avatar
Default 02-18-2018, 11:45 AM
Thanks terry
Disconnect only the map from jb ... (other connector stay with jb )
And check error code ?
I
M-terkait's Avatar
M-terkait M-terkait is offline
M-Terkait
Car: F30 335i
Default 02-18-2018, 03:53 PM
Terry
reduce Wastegate position to 60, and try if it helps reduce it more.
PureTurbo N55
Car: m135i
Default 02-18-2018, 06:35 PM
Increase 6 cylinder setting to solve this.
Default 02-18-2018, 06:38 PM
Thanks terry
I
Put MAP sensor only back to stock, clear codes, and evaluate.
Marlinman's Avatar
Default 02-18-2018, 09:14 PM
Thanks terry I will try that. I think I had it at 40 during these runs. I will lower to twenty
dror135's Avatar
Default 02-22-2018, 07:05 AM
thanks Terry
with stock connector its cleared the error
can stay without jb ( map ) ?
and what use map ?
