robinsson's Avatar
robinsson robinsson is offline
Car: bmw 335
Exclamation I can use double fuel pump?? fuel it - 09-13-2017, 01:26 PM
i have fuel it stage 1 LPFP and stage 2 LPFP ....can i connect the two to for better performance? or connect stage 2 LPFP only?
Car: 2008 E93
Default 09-13-2017, 02:07 PM
Stage 2 only.
Default 09-13-2017, 04:04 PM
I am not sure but I bet you could. The line pressure should be the same just volume differences. You would have to run them in parallel and maybe trigger the stage 1 add on with a hobb switch. I think thats what fuelit stage 3 does with 2 stage 2 pumps. So it would be a stage 2.5.
2012 N55 135I, Speedtech 7670, JB4 + MHD, Fuel-it port injection & stage 3 LPFP, M4 A2W IC, Mfactory LSD, KW V1, Apex EC-7
09n54jb4 09n54jb4 is offline
Car: 09 335i
Default 09-13-2017, 10:31 PM
Think there was a thread not to do this.
N54QC N54QC is offline
Car: 07 BMW 335i
Default 09-13-2017, 10:47 PM
There is, don't do it. http://www.n54tech.com/forums/showthread.php?t=46833
Default 09-14-2017, 09:06 AM
Correct...don't do it.
Default 09-14-2017, 09:29 AM
Lets say you went from stage 1 to 2. Could you run in parallel only kicking on the stage 1 add on for volume via hobb?
Default is just us Steves designs, but if I had both lying around i would think it could work. Totally agree dont put the smaller stage 1 add on in series with a 450 = reallllly bad idea. In parallel though, i would be interested in steves opinion.
Call it a ****ty 2.25 DIY with no warrantee, but seems like it would work.
Default 09-14-2017, 10:06 AM
When running pumps in parallel, it's generally suggested that they be identical pumps.
We haven't tested this for a few reasons, nor would we recommend it.
