(#826)
Default 09-30-2017, 05:59 PM
I'm here, although it's been awhile since I pulled that off. There are a couple screws that attach it to a bracket. Find those?
TrillM5 TrillM5 is offline
Car: F10 M5
Default 09-30-2017, 06:10 PM
Thanks sir... yeah, i removed them as well... mine will not budge though. I gave up, left the car on the farm and called it a night. I will get back to it when the sparkplugs and coilpacks arrive.
I may snap some photos in the a.m. and post them to see if I'm missing
something.
Was planning on taking it to the track tomorrow... but maybe its better that I wait.
Down4it's Avatar
Down4it Down4it is offline
Default 09-30-2017, 07:54 PM
something.
There's a worm clamp you have to loosen up at the bottom of the intercooler holding it to the hose, then it turns left and out.
Singapore Grey M6 GC
Car: F10 M5
Default 10-01-2017, 02:46 AM
allmotor_2000 allmotor_2000 is offline
Car: 2014 F10 M5 CP Frozen Grey
Default 10-02-2017, 05:05 PM
1. Remove the charge ***** (pass side)
2. Remove the screw holding the IC to the clamp (also holds the alternator)
3. Remove the coolant hoses into the pass-side IC (yes it will drip coolant)
4. Loosen the clamp holding the TB to the intake manifold (may need to remove the pass-side airbox to gain easier access)
5. Remove some of the hoses/fittings on the IC as they restrict motion to the left
6. Then either pull the IC out or push it far the left (an extra set of hands helps here)
7. Plug the BCM harness
8. Do everything in reverse to re-install
Car: F10 M5
Default 10-02-2017, 05:09 PM
Thanks Ram
steeve13m steeve13m is offline
Car: 13 M5 DCT
Default 10-03-2017, 03:51 PM
allmotor whats your next project since the M5 is gone?
2013 F10 M5 -DCT- Montecarlo Pearl Blue- BBMR 800 Stage 1 Twin Turbo system 700whp+ on 93 octane, BBMR D.P./Exhaust, Intake, HRE FF01, AC Schnitzer springs,Lucas Octane Booster, 5% 3M Window tints,Clear protection film,LED interior bulbs,Blinder M27,Escort Passport MAX,12" Sub+Amp,Sprint Booster.
2004 Lamborghini Gallardo -Manual- Giallo Midas Pearl Yellow- Modified Intake, Exhaust, Tuning, Carbon parts, HRE wheels, Sound system, +
Car: F10 M5
Default 10-03-2017, 05:38 PM
http://f10.m5post.com/forums/showthr...1384049&page=6
Default 10-05-2017, 04:55 PM
This one...
Car: F10 M5
Default 10-05-2017, 04:59 PM
Look at them Piecuts! Nice!
Car: 13 M5 DCT
Default 10-05-2017, 07:36 PM
Originally Posted by allmotor_2000
This one...
very nice....would be great to beat the 1000whp mark!
did the trans DCT issue drive you nuts on the old car?
Default 10-06-2017, 09:05 AM
It was fine after I swapped DCT's
Default 10-06-2017, 09:07 AM
This one...
Looking forward to the tuning.
Default 10-06-2017, 09:22 AM
I'll ping you.. probably week of the 23rd.
Thx!
Car: F10 M5
Default 10-06-2017, 10:19 AM
Got it all buttoned up... how do you toggle through the settings without using a laptop? I'm out on my farm with no wi-fi.
Default 10-06-2017, 11:10 AM
If you need help email tech support with what you need help with. Wifi is not needed to connect to the JB4 or do anything.
Car: F10 M5
Default 10-06-2017, 11:12 AM
Ok
Car: 13 M5 DCT
Default 10-09-2017, 07:50 AM
found your thread thanks
http://f10.m5post.com/forums/showthread.php?p=21756018
Car: 13 M5 DCT
Default 10-22-2017, 05:33 AM
First ever 1000+whp M5!!
https://www.facebook.com/BimmerPerfo...1326638228936/
Default 10-23-2017, 03:56 PM
Impressive! We just wrapped up JB4 S63TU twin bank pneumatic wastegate control and tested it out on Pure's development car. Expect to see more on that car soon.
What are they using for fueling at that level? WMI seems to only be good for 850whp or so at least in the current configuration.
Default 10-23-2017, 05:15 PM
Supposedly stock fuel system... plus WMI.
Car: 13 M5 DCT
Default 10-25-2017, 01:07 PM
Major engine work$$, big garretts, modified ECU tuning (no piggyback) +meth
Apparently the F10 M5 stock engine limits are 700 wheel torque as they tested the max with a few blown engines!
Default 10-25-2017, 02:01 PM
Hmmm I don't think WMI can support 1000whp. At least not safely!
Car: 13 M5 DCT
Default 10-26-2017, 07:24 AM
UPGRADED COMPONENTS:
BPC Spec Darton Flanged Sleeves Optimized wall thickness for strength that far exceeds factory Alusil cylinders without compromising block integrity or cooling characteristics
BPC Spec Carrillo H-Beam Rods Rated at 1500 HP
BPC Spec Diamond Coated Pistons Thermal coated crown and teflon coated skirts.
BPC Spec Total Seal Stainless Steel Piston Rings
BPC Spec Calico Coated Main & Rod Bearings
BPC Spec Spark Plugs
MACHINING SERVICES
ENGINE BLOCK
CNC Bore & Hone Process
CNC Main Bearing Line Hone
BPC Spec Optimized Engine clearances
Precision Balanced Rotating Assembly
CYLINDER HEAD
BPC Spec Ported Cylinder Heads
BPC Spec Valve seat machining
CNC Cylinder Head Resurfacing
FACTORY COMPONENTS:
BMW Revised Design Billet Aluminum Rear Coolant Cover
BMW Engine Gasket & Hardware Set
BMW High Pressure Fuel Injectors
BMW Water Pump & Thermostat
Default 10-26-2017, 10:05 AM
Agree - maybe setup normally runs 900-950whp and the 1K dyno pull was more to prove it is possible.
