OldBooster's Avatar
OldBooster OldBooster is offline
Car: 2008 135i AT
Send a message via Skype™ to OldBooster
Default WHEEL STUCK ON HUB - 10-15-2017, 11:41 AM
Wanted to mount different aluminum wheels on rear today (135i). But I can't get the current wheel to break free from the hub; tried all things possible without damaging the wheel. Advice please
Terry's unmatched dedication to the N54
Held #1 on www.DragTimes.com:
First to run 11.012 @129.30
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default 10-15-2017, 11:49 AM
Happens all the time. Put a block of wood against the back and beat on it with a hammer. Then rotate it and do the same on the opposite side. Keep rotating and beating until it comes free.. But remember before you start to keep a couple of lug bolts screwed in a couple of threads. You don't want it falling when it breaks loose.
Mike Levy
2017 X3 xDrive35i
OldBooster's Avatar
Car: 2008 135i AT
Default 10-15-2017, 02:37 PM
Sounds good, Mike. Best wishes
RAYSN54 RAYSN54 is offline
Car: 08 BMW 335I - E90
Default 10-30-2017, 10:32 PM
if that don't work this worked for me. I left the lug nuts loose, drove around for a bit, felt it get loose (drive slow) keep the breaker bar or ratchet with socket handy so you can pull over and tighten it back up.
zipphreak zipphreak is offline
Car: 2015 BMW m235xi
Default 11-01-2017, 10:01 AM
A large rubber mallet. Hit it around the tire on the edge over and over and over again, 12oclock, 3oclock, 6oclock, 9oclock, etc... It will eventually break free. If your feeling rowdy get some PB Blaster and spray it around the hub, wait a few minutes, wack it more. It will come free.
OldBooster's Avatar
Car: 2008 135i AT
Default 11-01-2017, 10:05 AM
Thank all of you for the suggestions. I will get back to this project tomorrow!
Larry
Bullitt1841's Avatar
Default 11-01-2017, 03:16 PM
This just happened on my 2017 F36 with only 15,000 miles. Fortunately the rust was not so bad to where I couldn't kick the tires a few times on each side (alternating). But I was very shocked to see how bad they were on this new of a car. Yes, I park it outside overnight, but this is Southern California!
Anyway, I spread a whole bunch of anti-seize on the rusted portions of the hubs so hopefully this isn't a problem down the road.
2017 F36 440i Gran Coupe | MPPSK | Track Handling Package | JB4 | BMS Meth Kit (Dual CM7) | BMS Intake
SOLD: 2007 E90 335i | PURE Stage 2 N54 Turbos | JB4 | FBO | 160k+ miles on the car, 120k+ miles on the JB4
Mike_L's Avatar
Anti-Social
Default 11-01-2017, 04:16 PM
On older cars there was a paper "gasket" between the hubface and the wheel to keep the different metals from corroding with each other. My E39 had that. For some reason, they stopped using those, and I can't even find them any more.
Mike Levy
2017 X3 xDrive35i
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 11-09-2017, 04:23 PM
Yeah those were useful, I think they still sell them but im not sure.
In terms of breaking the wheel free I always left one lug on so it doesnt fall and scratch the surface of the wheel, then I kicked the side wall to get it off. Just make sure the car is on a stable set of jacks and jack stands, for me it was on one of those four point quick jacks which was stable enough to kick the wheel without knocking over the jacks.
Mods: Stock for now
2016 Porsche 911 (991) GT3 RS: white, PDK, carbon ceramic brakes, Fully loaded
Mods: Fabspeed race headers, competition exhaust, High flow fiters, Ecu flash race gas and pump tune, roll cage, schroth harness, clear bra.
2017 Audi R8 V10 plus- dynamite red, fully loaded
Mods: Currently stock (hopefully a super charger and full exhaust soon)
