N54tech.com | BMW N54 N55 135 335 535 Turbo Performance Forum
(#801)
Bluesummer Bluesummer is offline
Car: DCT 135, E90 M3
Tuner: BMW
Default 05-07-2013, 04:26 AM
Just wondering, does the JB4 work on the new 640? Which harness will I have to use...
11' AW 135 ///M Sport DCT|JB3| (I can't wait for JB4 )
11' JzB E90 ///M3 |Akrapovic Evolution|BBS LM|3D|
NeoN NeoN is offline
Car: 2011 335i X Drive
Tuner: BMS
Default 05-10-2013, 09:56 AM
Unsure of what map to run:
JB4, Stage 2
93 octane all the time (BP gas)
N55
BMS Intake
Soon to be: Vishnu Catted DP (100 cell race version)
Currently I've been switching around from map 1,2, and 5
I ran map 5 for a few weeks, eventually it had great low end, great response, 15 psi initially, then would taper off to 10psi redline (1/2 fuel mark).
I switch to map 4 to test it out, and it would make 10-11psi around 4000 rpm then taper off to 9psi redline
Map 1 would yield similar results, with 11-12 psi then tapering off to 10 psi redline
Map 2 was similar to map 5 but i feel i had better low-end with map 5. 13-14 psi tapering off to 11 psi
Any reason why my map 5 after full learning process (3 weeks on map 5) would boost to 15 psi initially then taper to 10 psi. If i gunned the car at 40mph and it dropped to 2nd gear, say 4500 rpm and pull to redline, it would only hit 10psi and stay there. nothing more. if I accelerate from a stop it would boost to 15psi ---> 10 psi redline.
Now map 5 is similar to map 2, 12-13 psi tapering off to 11 psi redline.
Should i be datalogging all this information, such as timing advance, boost, and then choose what's the best? or just leave it on 5 and assume the unit knows better than me?
So map 2 or map 5? That is the question.
Also, I will be hitting the track next week with 100 octane, what map is best for that?
Brett
2011 BMW 335i xDrive, Black/Black, iDrive,
JB4 Stage 2, Map 5, E85 Mix
JB Intake
Vishnu Catted Downpipe
1994 Toyota Supra, Baltic Blue, 6-speed, mods...
1200rwhp/875rwtq
3.4L Stroker
Track Master's Avatar
Car: 135i, 2010, N55, DCT
Tuner: Burger Tuning no Other
Default 05-13-2013, 04:29 PM
Map2 always feels better to me and adapts faster although during top end Map5 makes a few more hp.
,12.01@119.3, With Meth
,12.10@115 e85 + ISO
423hp@497 - 0.60 in 3.75sec
Tuner: BMS
Default 05-13-2013, 08:11 PM
Interesting. I love map 2 for daily use. U think map 5 is better for the track? My catted downpipe is amazing. added tons of torque and spool!!
JB Intake
1200rwhp/875rwtq
3.4L Stroker
Car: 135i, 335i, X5D
Tuner: BMS
Default 06-07-2013, 04:23 PM
Deleted various support and help request posts. Use the support section or email us for those.
Home of the Worlds fastest N54s and N55s!
N54 Overall Traps World Record (11.33@132.78)__N54 Stock Turbos WR (11.25@122.86)__N54 AT Stock Turbos Traps WR (11.38@125.24)__N54 Twin Turbos WR (11.01@129.30)__N54 Stock Turbos 60-130 WR (8.39)__N54 Stock Turbos WHP WR (456whp)__N54 Stock Turbos+n2o WHP WR (542whp)__N54 Stock Turbos+n2o 60-130 WR (6.95)__N54 Stock Turbos+n2o WR (11.11@129.47)__N55 WR (11.91@117.81)__N55 WHP WR (399whp)__F30 WR(11.99@114.35)
Copyright © 2007 - 2013, N54tech.com
