(#551)
cnm135i cnm135i is offline
Car: m135i
Default 01-11-2018, 11:15 PM
Originally Posted by dror135
what the different םמ ISL_8_T1
how to download
the new version?
Dude - the FW is where it has always been - in post one
Please try to make a single log with 5-6 pulls in map2 (2000-5000rpm is ok). Terry is trying to fix some tip-in boost oscillation for me and I'd like to see if other also have this issue
M135i, PWG, Pure Stg2, WMI, bootmod3 + JB4
100-200kph: 7.02sec (93 and meth)
Car: 2013 535i (N55 F10)
Default 01-12-2018, 01:15 AM
Originally Posted by cnm135i
Ehmmmm, am I the only one interested in perfecting the ISO FW?
You are not the only one!
2013 F10 535i N55 PWG, Pure Stage 2, Wagner FMIC, ER Charge pipe, ER **, BMS Intake, JB4, Fuel-It Stage 2 LPFP, Fuel-It Platinum PI Kit, BootMod3 Flash
1995 e36 M3 - Future Track Car
Car: m135i
Default 01-12-2018, 02:01 AM
Then please test out the latest 8_T2 I have the below issue... Boost start out nicely on target but become more and more "wobbly" as pulls are added.
Peter @ Pure's Avatar
Car: F20 M135i
Default 01-12-2018, 02:03 AM
Hope you get it fixed!
F80 M3 - 100-200: 4.9, 60-130: 5.6
F20 M135i (sold) - 100-200: 6.26
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Marlinman's Avatar
Car: 335i coupe 2010
Default 01-12-2018, 03:59 AM
Do we know what was changed in the new firmware? I just noticed there was a new one.
Car: m135i
Default 01-12-2018, 06:15 AM
No. No change notes. I just tested 7_T3 which I remember being good, but that is behaving similarly.
WaqasRiyami's Avatar
Car: Bmw 535i - 2011
Default 01-12-2018, 08:07 AM
I updated to ISO_8_T2.
I will post some logs later, but they will be test's only as i am dialing in the TREBILA BEF Tune.
2011 F10 535i N55 PWG AT | JB4 ISO - BT.Rv3 | TREBILA BEF Tune | BMS Intake | ER 4" CLess D/Pipe | ER 3" Charge-Pipe | Wagner-Tuning Competition Intercooler | https://i.imgur.com/XEO6ZpR.jpg |
Car: m135i
Default 01-12-2018, 04:23 PM
This is about boost control as I see it so the BEF should not influence that. 4-5 pulls in one log is needed to se if boost start oscillating like the picture above.
Default 01-12-2018, 04:30 PM
Any time you're looking at boost vs. target you need to also be looking at WGDC and FF.
Car: m135i
Default 01-12-2018, 04:45 PM
Here the same log with FF and WGDC. I sent the log on email also.
Default 01-12-2018, 05:01 PM
For tuning on PWG systems you can control the pid gain, which is P I and D factors scaled together, the FF, and the target itself. Often a lower PID gain improves oscillations
Car: m135i
Default 01-12-2018, 05:08 PM
I emailed you logs with both PID 25 and PID 10. The PID 10 is not much better. Maybe I went too low and PID 15 is the sweet spot. Guess I'll be back on the street testing again...
Default 01-12-2018, 05:53 PM
It's one of those things you'd have to dial in. At some point we'll expose the full P, I, and D functions in the tuning interface so you can better dial it in.
Car: m135i
Default 01-12-2018, 07:19 PM
Both you and Steve talk about matching FF and WGDC, but I would be inducing overboost by forcing up FF here wouldn't I?
alo0oy215's Avatar
alo0oy215 alo0oy215 is offline
Car: 2012 f30 335i
Default 01-13-2018, 10:20 AM
just did the diod thing and updated to the ISO firmware
attached 2 logs with map 1 and 3
fuel used is RON95 (91 octane) and running single nozzle CM10 with 100% meth
is there anything thati can change or do to make the car better?
N55 powerd 335I sedan :
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
5- BMS F30 N55 Performance Intake
6- BMS WMI KIT
Default 01-13-2018, 10:54 AM
FF is just the prediction of the ultimate WGDC output. Closer is better but I don't think it's an issue here. It seems like spool up mode (where WGDC is sitting at 100% as turbo spools) is cutting out a bit too soon causing the initial dip.
I tightened up spool mode for 3.5bar sensor maps on this test. See if its better or worse. If there is something there, I'll make it user adjustable like we have for the JB4 N54 single turbo firmware.
alo0oy215's Avatar
Car: 2012 f30 335i
Unhappy 01-14-2018, 02:55 AM
First thing, when cutting the diode should cut it from both sides and remove it or its ok to cut one side and leave it?!
The second question is why is the lp_fp and water temp became 0 and there not showing any thing after cutting the diode?!
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
6- BMS WMI KIT
Car: m135i
Default 01-14-2018, 02:59 AM
Terry
It was only running PID=10 that initial spool was not enough. PID=25 spool looks ok I think.
As said, I dont care much about a bit of tip in overboost as throttle takes care of that. It is the dip after wards that can sometimes be felt as loss of power.
You can cut one side only, i did it like this.
alo0oy215's Avatar
Car: 2012 f30 335i
Default 01-14-2018, 03:01 AM
Ok, and what about the lp_fp and water temp readings? Why did they became 0 and showing no other reading?!!!
Everything thing else is working perfectly and showing all the readings once i start the engine
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
6- BMS WMI KIT
Default Yesterday, 09:07 AM
ISO_9:
1) Redesigned logging engine for much faster sampling of all CANbus channels. Normal speed logging is around 10hz for all CANbus channels now, and slow speed logging remains an option for cars with older software and drops sampling down to around 6hz.
Car: m135i
Default Yesterday, 06:26 PM
ISO_9:
Oh wau - this is great! Which FW revison has 9 been build on - 8_T3? I'll test flash only 100-200 in about 3 hours. Will try this out then
Default Yesterday, 07:29 PM
It's built on T3
Marlinman's Avatar
Default Today, 09:24 AM
Terry, does this new firmware mean the slower CANbus guys may have better luck with Map 5 adapting? Right now I don't use map 5 because, as you've discussed with me, a possibility is the speed is too slow for the JB4 to adapt properly. Thank you
Default Today, 09:26 AM
Yes, this should fix that issue! Try it!
Currently Active Users Viewing This Thread: 4 (3 members and 1 guests)
Drag_n54, Lamz, zole2112
