Patrick4588's Avatar
Patrick4588 Patrick4588 is offline
Car: 2010 335i and 2006 M3
Icon1 Rear end for drag racing - 08-30-2016, 07:23 AM
Mfactory Helical Lsd
Mfactory axles
Mfactory dif bushings
Turner solid aluminum subframe bushings
Bc coilovers
M3 control arms
Suggestions for anything else?
Default 08-30-2016, 07:58 AM
Megan or rogue tie rods? biggest sway bar?
Car: 335i, 2009
Default 08-31-2016, 02:53 PM
Sway bar doesn't really do anything for the drag strip. And tie rods are for steering. I don't see what benefit you would achieve with modifying either of those items.
E90 335i 2009 ///M Sport Auto
Mods: | Wagner Intercooler | MeowPipe | Meth-Trunk | JB4 | Pump_Back_End_Flash | Fuel-it! Stage 2
Drivetrain--------ForgeStar F14 Wheels 18" (245 & 275 PSS) | Alpina Transmission Flash | Wavetrac LSD
Suspension-------KW V3 Coil Overs| M3 RSF Bushings and Dif Bushings | H&R Sways
vwetish's Avatar
vwetish vwetish is offline
Car: BMW 335I / VW 2.0T
Default 09-02-2016, 05:52 AM
Patrick is referring to rear toe links which in aftermarket race execution would be of identical design as aftermarket race front tie rods, so he is not far off and they are a must if you want to keep rear toe in/out during hard acceleration.
vwetish's Avatar
Default 09-02-2016, 06:00 AM
Just for reference see bellow:
Bmwfixerguy Bmwfixerguy is offline
Car: 335i, 6sp Mt, Fbo with 2.3 gal meth with Do 3 &7 nozzles 100% bmw washer concentrate, it's free:)
Default 10-11-2016, 03:04 PM
I an only assume this is a 335 and assume again it's an auto?
If not I'd say a set of auto gears on a large pumpkin would be a good mod for a manual drag racing bigger turbo car..
I don't run this but I've heard it helps maximize 4th gear
2007 BMW 335I
jb4 g5 w/n20 tmap & e85 bef
bms 2.3 meth w/DO 5 & 7 nozzles
Vrsf **'s
Ebay chargepipe w/ 2 meth bugs and tial 50
6x6x23 intercooler
mmp inlets and outlets
E50 mix w/fuel it stg 1 lpp
Bosch n55 plugs @.22
Rear diff lock down
550i clutch w/cdv and e46 M3 Trans mounts
B&M short shifter w/bmw perf weighted knob
2007 BMW 335I
Vrsf **'s
6x6x23 intercooler
Rear diff lock down
