Immaculate Immaculate is offline
Car: 11' 135i
Default Brake Pad Wear Sensor - 06-28-2016, 05:16 PM
I recently just changed out my brake pads and accidentally broke the brake pad sensor while removing it, so I left it off for now till my new one comes. I was expecting to get the brake light on the cluster but haven't, does the JB4 disable that light from coming on?
DARKBLUE52 DARKBLUE52 is offline
Car: N54 E92
Default 08-30-2016, 07:00 AM
Folllowing
Car: 2010 535i
Default 09-08-2016, 11:33 PM
I don't think so, I'm on map 7 daily and my brake replacement light just came on recently. It doesn't clear, comes on every time I turn on the car. My rear pads need replacing. Maybe disconnecting the sensor makes the nag go away.
konvikt21 konvikt21 is offline
Car: 2008 335i 6mt
Default 09-09-2016, 06:59 AM
you can just cut the wires and connect them together to complete the circuit if you want the light to go away.
Doc Race Single Turbo Kit PTE5862 - e93 6MT - ADE PI - Fuel-It Stage 2 Bucketless - JB4/MHD - MFactory 3.46 LSD - MFactory SMFW - Spec Stage 3+ Clutch
Car: 2010 135i
Default 10-22-2016, 01:46 PM
When I did my brakes I bungled the clip for the sensors. The way it looks to me they are inductive. So once the air gap gets tight enough they create voltage and that's what turns the brake service lamp on. So disconnecting them and/or leaving them hang should not turn a lamp on.
2010 135i auto, MHD E40 tune, Fuel-It stg 2 pump, best 1/4 mile 11.863 @ 119.17 mph
new mods this year, VRSF 5" stepped IC, RB EVO inlets, CP-e/Tial CP, 1320 **'s, xhp stg 3 trans tune, E-85 tune
Best 1/8 mile: 7.469 @ 98.56, 1.769 60'
Best 1/4 mile: 11.480 @ 121.79 1.802 60'
Boland01's Avatar
Boland01 Boland01 is offline
Car: 535ix
Default 10-23-2016, 07:00 AM
I think I paid under $10.00 each at Rock Auto for new ones a month ago.
Car: 11' 135i
Default 10-27-2016, 12:22 PM
Didn't come on till I hit the track one weekend, so I plugged in the new one with the wires cut and looped. All is good!
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 02-15-2017, 04:20 PM
Not sure why the light is not coming on. I'd just replace it anyway though, since it's cheap/easy, could probably do it without removing the wheel.
Also confirming the JB4 does not prevent the brake pad wear indicator warning.
2009 535i Sport
548 whp/ 489 wtq
