bulletrs's Avatar
bulletrs bulletrs is offline
Car: M235i '15
Default H&R Sports springs popping sound - 05-12-2017, 05:10 AM
My dealer installed H&R sports springs for me on my '15 M235i with adaptive suspension. Now the car makes a popping sound on the frontleftside when turning the wheel on standstill or while parking.
My BMW dealer has swapped the complete suspension on the frontleft side but the popping is still there. According to them it is probably the frontleft spring causing the issue, it is definately properly assembled. The frontleft spring also seems to be a little higher in measurement (4mm). Don't know if that could cause it.
What do you guys think could be the problem?
2015 F22 M235i N55 EWG | M Performance | 18" VMR710 | Pure Stage 2 Turbo | Pure High Flow Inlet | Bootmod3 BEF | BMS JB4 + FF & EWG Wires | BMS Performance Intake | BMS Methkit | GFB DV+ T9356 | N20 TMAP | NGK SILZKBR8D8S 0,5mm | Wagner DownP | Wagner EVO2 Performance Intercooler | VRSF Chargepipe | M Performance Exhaust | Aral 102 Fuel
100-200kph: 6.97
1/4 mile: 11.43s @ 125mph
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 06-29-2017, 10:33 AM
hard to say.
strut mounts, strut not tightened back into the hub clamp, ball joint not bad or loose ...
2009 535i Sport - 548whp
Software :
zort zort is offline
Default 09-21-2017, 06:02 AM
Crap I just went through this exact issue and was able to solve the problem. Lowered the car on springs and developed a popping sound when turning either moving on at a stand still. Sounded like a spring binding. Frustrated and knowing I needed rear shocks I did full coilovers the next year along upper mounts. Same issue.
Just did my clutch and when the car was on the ramp I asked the shop to have a look -
It was the shield just above the steering ends . Just found it after two years.
I bet you this is your problem.. well hopefully.
-B
