(#76)
cnm135i cnm135i is offline
Car: m135i
Default 03-15-2018, 06:31 PM
Originally Posted by WaqasRiyami
The One Thing I've Noticed is:
Every time i add more power or mods to the car ,It seems like I am hitting some sort of Torque Limiter in 6th Gear that i wasn't hitting before the PS2.
If you check Log(1) On Stock Turbo DME BT was Normal in 6th Gear,
But in Log(2) after installing the PS2 the DME BT dropped little in 6th gear.
Now in Log(3) after getting Meth DME BT Drops A Lot in 6th gear.
It seems there is some type of limiter in 6th Gear, Maybe the Trans cant take that much of a Torque ??
Correct. I have been high lighting this issue to BMS and PTF for the last year. No body knows how to solve it. Looks like it happen every time TMAP read above ~20psi in low rpm. It does not always happen if you shift at high enough rpm.
M135i, PWG, Pure Stg2, WMI, bootmod3 + JB4, Quaife LSD
100-200kph: 7.0sec (93 and meth)
www.youtube.com/user/npharkes
Car: m135i
Default 03-15-2018, 06:42 PM
So we finished tuning the Car with Trebila - He did a really good job
As promised i will attache 3 logs.
93OCT Fuel in all logs
1)First Log - Is after Trebila Fully tuned the car FBO with stock turbos.
2)Second log is the best that we could achieve with the PS2 - Before realising that i will need meth since the timing was really killed in the log because of the IAT's and low Octane in my fuel. Here we could reached 22 PSI HPFP was holding up - but timing was killed so in final tune without Meth and in this log we were targeting 19PSI
3)Third Log is after i got meth and the car is fully tuned now : With Meth we target much higher timing - close to 11 With 20PSI of Boost
What Do you think Guys ?
What happened to your AFR here? Try flat 20psi from 4000 and up - looks like you have enough fuel and octane to do that. IAT looks great!
WaqasRiyami's Avatar
Car: Bmw 535i - 2011
Default 03-16-2018, 01:54 AM
raising boost targets up top won't make a change, turbo is already maxed out up top.
2011 F10 535i N55 PWG AT | JB4 ISO - Bluetooth.Rv3 | N20 3.5bar TMAP Sensor | TREBILA BEF Performance Tune | Pure Stage 2 Turbo | GFB DV+ | Fuel-It Stage 2 LPFP | BMS 100% Meth-Dual CM7 Injection | 93 Octane Fuel | BMS Intake | ER 4" CLess D/Pipe | ER 3" Charge-Pipe | Wagner-Tuning Competition Intercooler | https://i.imgur.com/iR4wm3I.jpg |
Peter @ Pure's Avatar
Car: F20 M135i
Default 03-16-2018, 02:10 AM
This is from my old M135i doing 6.26s 100-200 kph pull!
F21 M140i - currently stock
F80 M3 - 100-200: 4.9, 60-130: 5.6
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Car: m135i
Default 03-16-2018, 02:29 AM
It is far from maxed out - look at your WGDC!
trebila's Avatar
trebila trebila is offline
Default 03-16-2018, 02:40 AM
in Waqas car, the Pure stage 2 turbo is maxing out at lower boost:
maybe a boost leak ??
Peter@Pure, any idea ?
Car: F20 M135i
Default 03-16-2018, 02:50 AM
Either the intake system on the 535 has a huge restriction, or there is a boost leak.
peter@pureturbos.eu
pureturbos.eu
Yoandry Yoandry is offline
Car: 13 f30 335i
Default 03-16-2018, 06:35 AM
Where do you see it maxout?, because wgdc is below 50 when.
F30 PWG PS2 + WMI + MHD Bef/JB4 + VRSF FBO + N20TMAP. MPPK, MPE, MP-Susp, MP-Brakes, 437M, MP-Lip, MP-Diffuser, MP-Spoiler, MP-Rocker Panel, MP-Sills, MP-Pedals, MP-Grille, MP-Mats, IND Reflector.
JETmn JETmn is offline
Car: 2011 335xi
Default 03-16-2018, 10:48 AM
It is very likely there is a torque limit in the trans. The 6AT had one, but we have been able to remove it with the xHP trans tune. I am not aware of anything like that on the 8AT yet.
Default 03-16-2018, 11:16 AM
When dose it max out ? is it On 50 or more ?? Because if its on 50 , then it reaches 47 in some spots which seems maxing out right ?
Car: 13 f30 335i
Default 03-16-2018, 01:11 PM
Not sure what are you saying.
Normal wgdc value on jb4 is from 0 to 100. So 99 = max-out turbo or boost leak. On your log shows 50. Now, I dont know whats the scale if isnt the regular 0-100
Default 03-16-2018, 01:18 PM
I think the Wgdc Value scales from 0-50
Anyone ??
Car: 13 f30 335i
Default 03-16-2018, 01:33 PM
Anyone ??
No man, check one of your excel log the wgdc column. You will see values above 50.
Default 03-16-2018, 03:00 PM
Ok , Just to Try - I Did 3 logs
1- Trebila's Given PSI ( 20PSI Tapering to 16PSI up top )
2-4000+RPM - 20PSI
3-4000+RPM - 22PSI
So, I think from the logs Trebila Was Right, I Should not Up the boost - The Turbo is Maxing Out ( Boost is Not On Target )
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 03-16-2018, 03:13 PM
2-4000+RPM - 20PSI
3-4000+RPM - 22PSI
What is your elevation? This looks close to PS1 levels. My three guesses are one, you have a boost leak. Two, you are at a higher elevation and this is the limit of the PS2. Three, you installed a PS1 and not a PS2.
2011 E92 335i Auto
12.0 @ 125MPH JB4
12.6 @ 112MPH 92 Octane | 11.7 @ 120MPH E30 MHD
Custom MHD Tune | XHP Stage 3 | ER Chargepipe | VRSF 7in Intercooler | Methanol Injection | Performance Line D-P | Pure Inlet | Pure Stage 2 | Go Fast Bits DV+ |
2014 E84 X1 35i - Stock For now 13.9 @ 99MPH 293 AWHP 305 AWTQ
Default 03-16-2018, 03:17 PM
Haha,
1)Maybe A Boost Leak ( But should be a small one ) Since it can produce some power.
2)Elevation (f) 59 feet
3)PS2
Car: 2011 e92 335i
Default 03-16-2018, 04:13 PM
Haha,
3)PS2
I had a boost leak and was capped at 20.5 psi flat. When I tested for a boost leak I could hear it at 1 psi. If you have a boost leak it is greater than mine was. This was at 175 foot elevation.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Car: m135i
Default 03-16-2018, 09:10 PM
Wasqas/Yoandry...Understanding the left x-axis of the Interface
All values that are considered percentages: Throttle/Pedal/WGDC/FF/Meth/?? are displayed as 0-100% on the left x-axis no matter what you set it to on the settings page.
The other values: AFR/Trims/Boost/Ignition/HPFP/IAT...are following the scale. Dont set the scale below 50 as that might lead you to believe your trims are maxed out (50) even though they are not.
Car: F20 M135i
Default 03-17-2018, 12:48 PM
pure stage2 should do 23-24 psi at 6k rpm in 4-5th gear. If you only do 16 psi at 6k rpm for sure there is quite big boost leak. Unless you are at very high elevation which I dont think you are. Yes the turbo will make power still at 16 psi. However you are overworking the turbo which can shorten its lifespan. So I would check for boost leak!
peter@pureturbos.eu
pureturbos.eu
Car: F20 M135i
Default 03-17-2018, 12:49 PM
WGDC goes from 0 to 100. However on the graph the values should be multiplied by 2. Also in graph above 40 (80 real value) is considered not much left in the turbo.
peter@pureturbos.eu
pureturbos.eu
Default 03-17-2018, 12:55 PM
Could it be the hot weather in my country is the problem ??
Its 30C at night here when i am taking the logs
But i do have meth witch should eliminate the heat problem right ..??
Car: 2011 e92 335i
Default 03-17-2018, 12:58 PM
Intake air temps seem fine.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Car: F20 M135i
Default 03-18-2018, 12:12 AM
My experience is tha hot weather usually allows for more boost. I could do 27 psi in summer and 23-24 in winter. However cold air has more oxygen than hot air.
16 psi at 6k rpm is really low. I would have the car checked for boost leak asap.
peter@pureturbos.eu
pureturbos.eu
trebila's Avatar
Default 03-19-2018, 06:08 AM
it could be a huge restriction on 535i, with stock turbo, boost wasn't exceeding 10 psi at high rpm...
on JB4 logs, when you read wgdc = 48, then real wgdc is 96%, so completely maxed out.
