(#11051)
yellowfin's Avatar
yellowfin yellowfin is offline
Car: 335xi - jb4 - DCI
Default alternative anti-rattle - 09-11-2017, 07:41 PM
Terry, could you give more details on the alternative anti-rattle? I was looking in the forum, but did not find much. Before I got new turbos, I used it on the stockers, it dramatically improved rattle, but maybe a tad more lag.
Does it override DWP? Under which circumstances recommended, any pros and cons?
2007 335xi -- VTT GC lites + inlets + outlets -- Fuel-it stg 2 lpfp -- CPE catted **, FMIC, CP -- Tial BOV -- BMS DCI + OCC -- RB PCV
JB4 + BMS bef (E50)
Default 09-12-2017, 11:20 AM
It's documented somewhere, feature is a few years old. Holds WG open at low throttle then returns to normal at 20% input or something along those lines. Works for some, not all.
yellowfin's Avatar
Default 09-12-2017, 12:00 PM
Ok, thanks. Quite surprising that it did not create more lag than it did.
Then again, my WG's might have been so worn out that they did not really open at 0 wgdc. Glad those times are over
JB4 + BMS bef (E50)
mistawall mistawall is offline
Default 09-13-2017, 11:36 AM
G5_ISO_32_5
1) Setup JB4 to automatically change itself to map0 if a flashing device is connected to the OBDII port. Upon switching to map0 it will flash the turn signal indicators to alert the user.
2) Added battery reset and register (when installing a new battery) under the menu 1/7 adaption resets.
So by setting it to 1/7 after installing a new battery will take care of the coding it needs?
TFT inlets, charge pipe TIAL BOV
RISS **, Exhaust
Walbro 450
335is CLutch
BMS short shifter
VRSF 7"
Apex EC7
KWv3 (not installed)
Devils own Meth kit (not installed)
Default 09-13-2017, 06:03 PM
Correct, 1/7 is battery reset. On the latest firmware we moved the rest of them to 1/4.
Hidden_man Hidden_man is offline
Car: 2007 BMW 335i
Default JB4 andAutoclear - 09-15-2017, 08:04 PM
Hi ,
I'm from Australia and i updated to the ISO_32_8 firmware and now i keep getting codes for having ******* *********?
I read that this update got rid of autoclear for US cars? But mine shows as Australian in the JB4 setting and doesnt clear the codes?
Can you help me out?
vwetish's Avatar
vwetish vwetish is offline
Car: BMW 335I / VW 2.0T
Default 09-16-2017, 07:41 AM
Either upload older firmware or do BEF.
Car: 2007 BMW 335i
Default 09-16-2017, 08:06 AM
I am running with the newest BEF already and still get the codes for ******* **'s.
Is there anywhere i can download the older firmware? Cant seem to find it anywhere?
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
