suspenceful's Avatar
Car: 2008 BSM 135i
Default 04-23-2018, 12:11 PM
I was able to test this and all I can say is... IT WORKS! I'm thrilled. The car finally reacts to super fast shifting abilities. Was so painfully slow before!
Check out the throttle, pedal, and boost levels between the 3-4 shift.
2008 BMW 135i 6MT - Doc Race Single Turbo 6266
752whp/691wtq @ 30psi, weighs 3260lbs
Complete build info: my1series.com
YouTube channel: youtube.com/jakespence135
Instagram updates: instagram.com/jakespence
N54 t-shirts, etc: bimmerstreet.com
Default 04-23-2018, 12:12 PM
islandboi3 islandboi3 is offline
Car: S2000
Default 04-23-2018, 10:44 PM
It DEFINITELY works!!!!!! Thanks to BMS again for the platform support. I can post my before and after logs as soon as I figure out how to post pics. The error I’m getting is the screenshot is too large.
mattgu40 mattgu40 is offline
Default 04-27-2018, 02:42 AM
If so we've got something new for you to test.
Side Effects:
1) As implemented, the JB4 is not currently reading gear, so boost by gear has been changed to boost by speed. Where 1st is < 40mph, 2nd is 60mph, and 3rd is 86mph. We've got some ideas to correct this back to true boost by gear we'll need to flush out.
2) With the DME no longer seeing the clutch position cruise control doesn't work.
3) The clutch safety start logic appears fully functional. Test and let me know if you find otherwise!
4) You'll have a shadow code stored for clutch pedal signal not active. Just ignore it.
would this side effect affect the BMS PI controller ?
crazyyardie's Avatar
crazyyardie crazyyardie is offline
Car: 2007 335i
Default 04-27-2018, 09:47 AM
Hey terry will this affect the manual shift bog that mhd gives with the backend flash !?
Default 04-27-2018, 09:53 AM
Makes no difference, that setting is supposed to help shift bog but many users still had issues.
The way this is implemented is different but it works 100%. Give it a try, you wont be disappointed!
Default 04-27-2018, 09:54 AM
It should not have any, I am using this on my car with BMS PI. You just can't use the NLS/2step RELAY, DO NOT NLS.
Car: 2007 335i
Default 04-27-2018, 10:02 AM
Loading it up as we speak.
Will my boost by gear remain the same boost pressure although itís mph now. As in will it still be 10 psi 1st and 12 psi 2nd
Default 04-27-2018, 10:09 AM
Will my boost by gear remain the same boost pressure although it’s mph now. As in will it still be 10 psi 1st and 12 psi 2nd
Yes, but it is still in development. Needs a bit more work to be accurate. Works Via Speed.
Default 04-27-2018, 11:47 AM
Exciting. I'll load it tonight and do a test. Will try to get a log to show effect on stock turbo fbo pump. Getting hard to do high speed logs around here thanks to revenue ticketing.
N54 | Build Thread
Default 04-27-2018, 11:51 AM
No, it will now reflect on speed instead of gear, as indicated in the first post.
Zeezul's Avatar
Zeezul Zeezul is offline
Car: e92 n54 pre lci
Default 04-28-2018, 04:14 PM
This is great news Terry! I can't wait to try this out. Hopefully it won't rain tomorrow. I have shift bog bad wot and 3-4 post shift. It doesn't really occur if I shift slow but that's just really annoying to do. I thought about contacting my tuner about torque limiting but I'll just give this firmware a try first.
Look at this 4th gear post bog with my throttle cut
glachhman glachhman is offline
Car: 07 335i
Default 04-28-2018, 05:25 PM
Flash only people, can we just remove out clutch wire from the dme?
weebles weebles is offline
Default 04-28-2018, 08:32 PM
This fix helped my car out big time. Much cleaner shifts.
Zeezul's Avatar
Default 04-29-2018, 12:37 PM
Great job Terry! After a couple of pulls, it looks like it completely fixed my bog issue. These are with fast shifts too btw.
FBO MT N54 w/stock turbos-tuned by Trebila
Xshadows Xshadows is offline
Car: 2008 135i
Default 04-29-2018, 02:24 PM
I just exploded my intake manifold over the weekend working on my e85 tune. But I was having major shift bog issues. Once my DocRace manifold shows up I'll give this a whirl.
DocRace Top Mount w/ Precision BB 6266 - JB4 G5 - BMS Pump flash - 650HP AD-E Intercooler - BERK Race Exhaust - Fuel-It Stage 2 Fuel pump - ER Chargepipe w/ TIAL BOV - 560whp @ 20psi on 93 octane only
AnilKram AnilKram is offline
Car: 09 135i
Default 04-29-2018, 06:17 PM
Will this works with a custom backend flash? Thanks
09 135I MT jb4 g5 iso 32.5, mhd Trebila backend flash. 7" vrsf intercooler, ETS chargepipe with synapse BOV, MMP-E relocation inlets and outlets, fuelit stage 2 lpfp, vrsf **** **. AP midpipe, berk race axleback, ngk 5992 .022, 3.5 bar sensor w/ bms adapter
Bryce 135i Bryce 135i is offline
Car: 2008 135i
Default 04-30-2018, 07:19 AM
Just to be clear if I have the 2 Step/NLS relay wired in right now this will not work right? Also with a custom BEF there is no impact either where it is just the clutch wire?
Car: 2008 BSM 135i
Default 04-30-2018, 07:25 AM
I have the 2-step/NLS relay and a custom backend flash, but the shiftbog fix still works. The 2-step and NLS will NOT work, so don't try to use them.
Car: 2008 135i
Default 04-30-2018, 07:29 AM
Will this eventually work with the NLS / 2-step? It's clearly still in development, so will that be the plan?
Default 04-30-2018, 07:34 AM
It should work with any BEF.
Default 04-30-2018, 07:35 AM
The 2STEP is still active with it. The JB4 NLS logic itself (cutting power to the coils) is currently disabled, although I'd be curious to see how the DME reacts to a NLS with it.
Zeezul's Avatar
Default 04-30-2018, 01:19 PM
I'm tuned by trebila running this firmware. Anyways, while driving this daily I've noticed the throttle engagement is a lot more noticeable when initially pressing your foot on the gas. My car can get a little jerky. I assume that's a natural drawback to the firmware for the bogfix. Not a big deal. Terry, do you think you'll be able to work around the cruise control? Also, I haven't tried anti lag on this firmware. Is that advisable? Haha. Thanks again.
Keith
Default 04-30-2018, 03:08 PM
Did some 1/2 mile Shift bog testing yesterday. I have a bunch more videos I will need to edit and put together.
I was trying to get some good runs but my transmission decided otherwise. It wouldn't let me fast shift into second or even shift into it at some points. I was mostly doing slow shifts into second to get some good traps but didn't even try for records.
Connormobley Connormobley is offline
Default 05-05-2018, 11:21 AM
Also curious if 2step (for launching) and anti lag would be functional later on. Also, if I were to go on long road trip, would it be easy enough to plug in the clutch wire and keeping using the firmware, then just pull the pin back out after the trip? My car isnt a daily so cruise controll is rarely used but, it is still handy for the highway.
