Venom77's Avatar
Venom77 Venom77 is offline
Car: 335I
Default 12-11-2016, 10:18 PM
Originally Posted by dlp3719
1/07 build date here. Anyone have a link to a DIY on a TCU swap? I feel it is in my future.
Im in your boat too. Curious on this as well.
Garrett Gtw 6465, Supporting mods , Mhd/Jb4
E92 420 E92 420 is offline
Default 12-12-2016, 12:56 AM
This is the guide I used when I swapped mine out for a later one
http://www.zftranspart.com/images/custom/mecha.pdf
Once installed you then need to follow this reset and relearn adaptions procedure
https://www.fcpeuro.com/blog/posts/h...on-adaptations
UK V8Bait Tuned
Built Motor
TD Turbo 335i
djkr21 djkr21 is offline
Car: 08 bmw 335i coupe
Default 12-12-2016, 05:22 AM
Im in. I would love to be a beta tester, all requirements are easily met!
phv628's Avatar
phv628 phv628 is offline
Car: BMW 2009 335i xdrive
Default 12-12-2016, 08:11 AM
I would also like to be included in the beta testing group.
Thank you.
|E92 335i xDrive| |JB4+MHD BEF| |VM Single Turbo Kit + PTE 6466| |Built Auto Trans| |xHP Trans Flash| |Stage 4-Triple Walbro 450s, fpr + return| |EOS Intake with Port Injection| |AD-ENG FMIC + AD-ENG OCC| |RB PCV Kit| |PR Ignition kit| |Built N54: Darton Sleeved, Manley I-Beam Rods+ARP Rod Bolts, JE 9.5:1 Pistons, JE Wrist Pins, VAC coated main & rod bearings + ARP Head Studs| |Keyed crankshaft snout, crank hub, timing & oil pump sprockets + VTT crank-bolt capture| |ADV Oxygen Sensors|
Blackarrow335i's Avatar
Blackarrow335i Blackarrow335i is offline
Default 12-12-2016, 04:32 PM
Would like to be a beta tester
E92 09' 335i MHD BY V8BAIT
MMP STAGE 3 / MMP PI
XHP s3 / MR.5 AIRINTAKE
VRSF **'s VRSF 7" IC / RB PCV VALVE
VTT 2" INLETS / STETT CP TIAL BOV
M3 F/R CONTROL ARMS / M3 STEERING RACK
MEGAN TOE ARMS / KW V2 SUSPENSION
ST DRILLED/SLOTTED ROTORS
BODY/INTERIOR MODS
N20TMAP NGK 5992s Gapped To 0.018"
PR IGINITION UPGRADE
FUEL-IT STAGE 3 LPFP / MISHMOTO + BMS OCC
SETRAB AT COOLER / PERFORMANCE EXHAUST MOD
Jsr1256 Jsr1256 is offline
Car: 08 335i Sport Package
Default 12-12-2016, 04:35 PM
Pm sent
08 E92 335i AT 20k Miles | Wedge E60 Flash| E85 | VRSF FMIC | VRSF Lower Charge Pipe | ER Charge Pipe|Tial Bov| Vrsf *** | DCI | IC Sprayer | Scoops | NGK 1 Range Colder Plugs | Fuel It LPFP | E60 | [12.2 @ 118with e85 flash] [ My E60 flash 1/4 = 11.8 @ 120
klipseracer klipseracer is offline
Default 12-13-2016, 12:08 AM
Originally Posted by J_hynson
PM sent. Im in for one but im rarely on N54tech.
Usually on other forums. Seems that i need to frequent this one more often.
Mods are: Motiv 900 W/PI & AEM EMS4, Engine W/ VAC Stg 3 Head, Solid Mounts - Overrev Roll Cage, IC & Crashbar - Lvl 10 Trans - NX Proton kit - Revshift Flex Disk - DSS Rear Axles - M Factory LSD - Defiv Lock Down Kit - Fuel-It Stage 3 LPFP - Turner Motorsports Solid Subframe Bushings, Wheel Studs - Stoptech SS Brake Lines - DirtKurt AT Trans Cooler Bracket W/ Aubeast Trans Fittings & Setrab 25 Row Cooler
Transmission only has about 84 miles on it along with everything else. Engine has less. Let me know
There is an entire thread on it on e90post:
RayBan81's Avatar
RayBan81 RayBan81 is offline
Car: 335i E91
Default 12-13-2016, 08:05 AM
Originally Posted by Ocean
Subscribed!
Would you happen to know how we identify the TCU version?
E60s can't use the Alpina flash, so are we out of luck again?
No, sooner or later 5-series will be covered. The problem with Alpina is not that the TCU is not matching, the problem is (most likely) the E/M Shifter. E-Series has mechanical parking lock and mechanical gear lever, 5-series has the electronic one.
So xHP will support 5-series, but don't nail me down on a timeline. Lot's of things to do the next months and I have not decided yet, which cars will come next after 3-series.
xHP Flashtool: The worlds first Android-based TCU Flashtuning tool!
More Infos on Youtube -> http://bit.ly/2hfYJT8
xHP on Facebook: https://www.facebook.com/xhpflashtool/
BMW135xi's Avatar
BMW135xi BMW135xi is offline
Car: BMW 135I
Default 12-13-2016, 08:24 AM
Like to be a beta tester if possible. BMW 135I-2010-|MHD -E-40 | A.A- FMIC | A.A- Charge Pipe | A.ATial Bov| A.A- *** | | | Scoops | NGK 1 Range Colder Plugs | Fuel It LPFP stage II| Alpina Flash /A.A Exhaust. (80,00- miles on car).
rhodesman's Avatar
rhodesman rhodesman is offline
Default 12-13-2016, 10:33 AM
Does this mean that the E8x crowd will be able to get the TCU flash at launch? I'm possibly interested in beta testing, however I have an 09/10 N54 E88 and usually in the February/March time my car is in the garage because of the weather. But, with that stated, if the roads are clean, I have no problems taking it out for test purposes!
Also: I too already have the Alpina flash done to my AT.
Engine/Drivetrain Modifications:
JB4/MHD/Trebila tune, xHP stg3, BT R8 Coils, BMS OCC, BMS DCI, VTT 2" Inlets, VSRF ceramic 3", ER Charge Pipe w/ Forge DVs, AMS Intercooler, Fuel-It Stg2 LPFP, MMPe twin 1k's
Suspension:
Front & Rear 1M/M3 control arms & Subframe Bushings, MFactory YCW Coils tuned for e88
Exhaust:
Berk Street Performance Axle-back w/ Berk Resonated Midpipes
12.146@116.93mph 1/4 mile on 93 pump
Last edited by rhodesman; 12-13-2016 at 10:37 AM.. Reason: sometimes I forget stuff, other times I omit stuff
Nniftyfour's Avatar
Default 12-13-2016, 05:37 PM
I would love to participate in the beta...
No issues using Winkfp in an advanced fashion.
I have three 335's under my care with the correct TCU's...
1: 2008 completely stock trans but its not beat to crap because it was recently modded for the first time
1: 2007 (post 3/07) with moderate mods and fresh OEM turbos running E45 (450whp) and the level 10 valvebody otherwise stock trans with fresh fluid, hasn't skipped a beat yet.
1: Fully built Lvl 10 build that was recently re-done as it failed quickly due to bleeding off line pressure (bad bushings) now fixed and running VTT stg 2's but not really going to be used until the spring. So it will be fresh
I also tune all these cars myself, but I don't go crazy as I don't have local dyno so just what I can get safely from street logs and being sure I'm not passing MBT.
I feel like I would be a good beta tester. PM me if I can get in.
I would REALLY like to get in as the lvl 10 valvebody does show promise when you reset everything but over time the adaptations kill the extra performance.. Pisses me off.
COTT5Series COTT5Series is offline
Car: 2008 BMW 535Xi
Default 12-13-2016, 06:06 PM
Definitely interested in this if you need someone from the 5 series crowd to participate! I'm located in colorado and have ties to a few bmw groups and N54/N55 owners locally.
RayBan81's Avatar
Car: 335i E91
Default 12-14-2016, 03:30 AM
Hi guys,
thx for your overwhelming interst on this!
Apply for Beta is already CLOSED!
I have some backlog on my private message folder, will work that up the next 2 days!
Thx,
Clemens
Default 12-14-2016, 09:19 AM
Excited
Stuntz's Avatar
Stuntz Stuntz is offline
Car: 135i 2009
Default 12-15-2016, 03:32 PM
subscribed for purchasing when available...
'09 135i
JB4 with MHD back-end flash, Fuel-It Stage 2 Bucket-less Fuel Pump, BMS DCI, BMW Performance Exhaust, Eibach Springs, M&H Drag radials, e85
1.69 60'
7.51 @ 94
11.71 @ 115
nitemare's Avatar
nitemare nitemare is offline
Car: 2010 535i 2002 530i
Default 12-15-2016, 10:34 PM
In for when available for the 5series.
WORLD'S FASTEST 535i - 60': 1.62 1/8: 7.2@98.3 1/4: 11.2@124.6 (@ 23psi only)
1/2: 151.2 (no boost in 4th or 5th bad TMAP)
Hexon RR700s/JB4/Trebila BEF/BMS Meth/MFactory LSD/Fuel-It Stage 2/ADE Port Injection/Full E85/ VRSF Inlets/VRSF ***/VTT Outlets/Custom 3.5" single exhaust/VRSF CP/Tial BOV/Rev9 FMIC/RB PCV fix kit/ RaceStar Dark Star 17" & 15" wheels/Custom 15" brake setup
Future: Lots more to come...stay tuned!
RayBan81's Avatar
Car: 335i E91
Default 12-16-2016, 05:30 AM
E8x N54/N55 will be covered together with the E9x series. The architecture is the same, therefore that can be covered at once.
Quicktime's Avatar
Quicktime Quicktime is offline
Car: 2008 335i
Default 12-16-2016, 09:24 AM
Subscribed!
enrita's Avatar
enrita enrita is offline
Default 12-17-2016, 03:02 AM
Like to be beta tester
07 335i AT - MOTIV 750 - MHD BMS E85 Flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
Default 12-17-2016, 04:06 AM
Read Post number 38
Beta testing is closed
UK V8Bait Tuned
Built Motor
TD Turbo 335i
Maximum996's Avatar
Maximum996 Maximum996 is offline
Car: 08 535xi
Default 12-17-2016, 05:13 AM
In also when 5series is available...
08 535Xi - jb4 iso w/mhd flash, Bms dci, AR ********* **, er cp with forge dv, second *** delete, muffler delete, xhp trans flash, ets fmic, bms oil tstat bypass.
fazman fazman is offline
Car: e90 FBO
Default 12-21-2016, 01:19 PM
Is there a limit to the number of times you can flash your TCU before it no longer accepts any new flashes? I remember when I did the Alpina flash, my car did say something about the number of flashes remaining available at the 70's? Dealer did a Mechatronic sleeve replacement under CPO and they flashed me back to stock tho, Since then I hated ending to hit the paddle or switching to sport on the shifter if I ever wanted to get out of eco mode in the alpina flash. I like the stock setting where if I mash the gas, it will just go.
RayBan81's Avatar
Car: 335i E91
Default 12-21-2016, 01:22 PM
That's an artificial limit introduced by ZF/BMW. The hardware itself basically has "no" limit and therefore you will be able to flash as often as you want with xHP.
Car: 2007 BMW E90 335i
Default 12-21-2016, 01:56 PM
Hmm... I thought that limit was something in WinkFP, not the TCU itself. Regardless, like you said, shouldn't have any impact on your flashing tool.
2007 E90 335i Pre-LCI
RayBan81's Avatar
Car: 335i E91
Default 12-21-2016, 02:27 PM
WinkFP writes some history information on each flash into the EPROM. The memory reserved for this purpose has a certain limit and that's the limit which is shown bei WinkFP.
