tim421gg tim421gg is offline
Car: 2009 335i coupe
Default 335i lsd questions - 04-18-2018, 07:02 PM
so far from what I have discovered, I have 3 different options to put an LSD into my 335. Buy a pumpkin/ get it machined. Swap an m3 differential with axels and driveshaft. or the options I'm hoping would work, is buy an older generation 335i bolted diff and install an LSD myself. My question is would my last option even be a possibility? would I be able to buy and 07 bolted diff and install an m sport lsd?
Jeevin12 Jeevin12 is offline
Default 04-19-2018, 08:27 AM
m3 all the way
I bought my car with an mfactory lsd (lifetime warranty) and I love it
KevinC39 KevinC39 is offline
Car: 11 335i 6MT RWD
Default 04-19-2018, 09:10 AM
You can Google around and there's a DIY on how to install the LSD yourself but I don't think it's a beginners task. I did the prebuilt pumpkin and shipped my stock one back.
2011 E90 335i RWD 6 Speed
FBO JB4 MHD
Amik Amik is offline
Car: E92 335i
Default 04-21-2018, 08:42 PM
I did the same as above, prebuilt pumpkin and core return, and mine is a bolted 07. Setting up gears is not a simple task and if you aren't intimately familiar with how to set backlash properly, you may be better off leaving it to folks who have the right tools and do it routinely.
Pulling the complete pumpkin and replacing it was pretty easy. Getting that large driveshaft nut backed off completely takes a while, but the process is very straightforward.
2007 e92 335i AT - 1/07 Build Date
Wedge Flash | Pure Stage 2 DD | Precision Raceworks Ignition w/ NGK 97506 @ .022 | RB Inlets and Outlets | Fuel-It Stage 3 Bucketless LPFP | VTT Double Barrel HPFPs | N54Tuning D-P | VRSF 7" HD Intercooler | ER Chargepipe | Turbosmart DVs | Innovative Racing Oil Cooler and Tstat | MFactory LSD | Bilstein B12 Pro Kit | ECS Swaybars | V710 19s w Michelin PS 4S 235 front 275 rear
