Getu1 Getu1 is offline
Car: 535i
Smile First n54 log with new Turbos and FBO - 01-13-2018, 04:18 PM
Hey everyone,
Itís winter here but Just took my e60 n54 out for a quick run to do some pulls on map 5. Long story short just installed Pure Stage 2 DD Turbos and FBO including ******* *********, inlets and outlets, 7Ē FMIC, turbosmart BOV, Jb4 with Rev3 (iPhone app) and MHD flasher app on an android device. (BEF options or custom tune)
Iím new to this whole logging stuff and wanted to see where I need to start. Attached are 2 short logs.
Sorry for the super newbie approach but could use some help to get my car locked in with what I have available right now until I can get a custom tune down the road. At a glance it looks like my evil psi is not hitting the target boost levels on map 5. What could this be and how can I make tweaks to fix? Anything is looking outta wack? How can I fix?
Thanks all and look forward to this journey of n54 boost
Haynpunch's Avatar
Car: 07 E90 335i
Default 01-13-2018, 08:46 PM
Im pretty new to this stuff too. With stock turbos I know to start you would need to set your JB4 settings to default http://www.n54tech.com/forums/showthread.php?t=10605
then let you can let map 5 adjust on its own. im not to sure with the set up you have also I think you gotta do a pull from 2k to atleast 6k RPM, pic a gear 3rd or 4th to get good data
07 E90 AT 335I 130k
JB4 G5 - Race BEF
DCI
VRSF CP - TS RP BOV-Orange Spring
VRSF V2 D-P's
7" FMIC
Stage 2 Bucket
Default 01-14-2018, 10:30 PM
As mentioned, you need to set your user adjustments to the defaults. Your current setup is incorrect and will cause a lot of issues.
Car: 535i
Default 01-15-2018, 05:20 AM
Thanks both, how do I set the user adjustments do default? When I go into the app and click user settings everything says 0 and there isn’t a button or options to hit default.
Can someone let me know how to do this? Once this is done do I then select map 5 again and do some logs? Thanks
Default 01-15-2018, 10:36 AM
You will have to enter them manually and save them while connected to the car.
Yes, once that is done, do a log on map 5.
Car: 535i
Default 01-15-2018, 10:46 AM
Ok sounds good. I’ll do a search and see if I can find the default settings numbers. I’ll post new logs once I get a chance. Thanks
Default 01-15-2018, 03:51 PM
This is the thread you should be monitoring for firmware updates and information.
Car: 535i
Default 01-15-2018, 04:18 PM
Thank steve, I literally just saved that link. I’m going to update my firmware as my jb4 is running IOS 7202. Thank you for the help, much appreciated and I’ll post back once I update jb4, input default user settings and then run some logs on Map 5. GREAT SUPPORT!!
Car: 535i
Default That was easy - 01-15-2018, 06:58 PM
Updated firmware and took 2 more quick logs.
How do these logs look? Anything need adjusting or an issue? Car pulls consistently pulls harder now with the suggested update. Seems that boost drops off at higher rpms which may be the 17psi limit but it feels good. Also feels like there is some lag and boost doesnít kick in until 3k rpm.
Thanks for the continued help and Iíll be sure to search through the forums.
135iam 135iam is offline
Default 01-15-2018, 07:18 PM
Those logs are not very good. You need to log from 2000-6500 rpm WOT in 3rd. Also turn on ign logging for cylinders 2-6
2010 E88 135i manual/sport package
KWV3's| M3 F&R control arms| WL subframe bushings| ARC 8's w/ 235/275 ExtremeContactSports| MFactory Flywheel w/ Spec Stage 2+| AR downp*pes | Magnaflow axleback| 7" VRSF IC| RB Next Gen +| RB inlets/outlets| RB PCV| ER Charge pipe| Tial BOV| BMS intake| JB4 with BEF
Car: 535i
Default 01-15-2018, 07:24 PM
Ok I’ll try again in a few days when I’m back from a work trip.
Thx
Default 01-16-2018, 10:24 AM
User adjustment settings were not set to default...those will need to be updated before doing additional logs.
Dave @ Fuel-it!'s Avatar
Default 01-16-2018, 10:14 PM
Personally I’d set your user adjustment settings to default, and let’s see some logs on Map 2 first- ensure everything is correct & then move our way up. Just my initial thought.
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 535i
Default Default User setting view - 01-18-2018, 07:25 PM
Dave, I will make some logs on Map 2 tomorrow.
Attached is a screen shot of the default user settings I manually input. Are these correct as I canít find an example with all of the values that I actually see on my mobile app. Also, default shows Fuel Bypass at 0, but mine keep putting values in, is that supposed to happpen?
I Definitely want to ensure the foundational things are correct before I start pushing things.
Thanks all again for inputs, much appreciated.
Sorry, Site wonít let me attach my pics
Default 01-18-2018, 09:40 PM
Resize & they should post
e92 AT 335xi 2.0
Doc Race Kit 6062
Haynpunch's Avatar
Car: 07 E90 335i
Default 01-19-2018, 12:13 AM
Default settings is on the #3 post of that link. just input the same numbers into the settings and SAVE when you are done
07 E90 AT 335I 130k
JB4 G5 - Race BEF
DCI
VRSF V2 D-P's
7" FMIC
Stage 2 Bucket
Default 01-19-2018, 09:31 AM
Those numbers are dynamic...that is fine.
Car: 535i
Default 01-19-2018, 09:42 AM
Perfect!!! Told you I’m learnibg lol.
I’ll do some MAP 2 logs when the snow clears here ��
Default 01-20-2018, 01:43 PM
Perfect!!! Told you Iím learnibg lol.
Iíll do some MAP 2 logs when the snow clears here ��
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 535i
Default Final got some logs - 01-25-2018, 06:18 PM
Map 2 attached
Car: 535i
Default Map 5 log - 01-25-2018, 06:19 PM
Attached
Default 01-25-2018, 08:20 PM
I'd recommend logging on map 1, map 2 looks to be too aggressive, you are pulling timing, I avg is high, and your AFRs are quite rich. Probably due to the DME seeing knock.
Car: 535i
Default Ok - 01-25-2018, 08:49 PM
Is it easier for me to just get a custom tune done? Can you tell if my LPFP is operating ok? I donít plan to run e85 anytime soon but donít know if it is functioning properly.
Last, itís interesting that my car seems to be acting weird with these mods. From being s long time car and bmw enthusiast, it always seemed like factory boosted cars were more plug and plug to get serious power. This kinda seems touchy. Dunno though as Iím a newbie. My expectation was go FBO and upgrade Turbos, run on map 5 and Iím good.
Lmao I guess not so much.
Default 01-26-2018, 09:45 AM
Fuel pump looks fine thus far. There is no replacement for octane but I would suggest loading up the BMS pump flash.
Car: 535i
Default 01-26-2018, 10:45 AM
Ok, thanks Steve.
Iím assuming you mean the MHD Flasher pimp BEF, correct? Iíll definateky look into that next as I have all of the equipment so far, just need to read up and do it.
Thanks man
