(#126)
Default 08-21-2016, 08:10 PM
I don't know what the velos tune is. Flash or piggyback system?
Grayforge Grayforge is offline
Car: 2008 E90 335xi
Default 08-21-2016, 09:42 PM
Velos is a Flash
Speed Is Life
Default 08-21-2016, 09:55 PM
Then JB4 should work just fine in conjunction with it. Once installed log map4 and we can evaluate what settings are needed.
tailwinds tailwinds is offline
Car: BMW X6M
Default 08-22-2016, 06:58 AM
Ok thanks. Anyone with an answer to the warranty question? I've had my car in for a number of items and the flash was never noticed.
Car: 2008 E90 335xi
Default 08-22-2016, 07:34 AM
If the dealer detects a modification to the ECU and you have an issue at all related to that, they'll likely void the warranty.
Speed Is Life
Default 08-22-2016, 08:02 AM
Don't make warranty claims on modified vehicles if the modification may have caused the problem.
Car: BMW X6M
Default 08-22-2016, 12:55 PM
Ok. It appears it would be obvious then that the car has been modified with the JB4. Would it be difficult to bring it back to stock if need be? Other than evaluating that, I'm in. Thanks, John
Default 08-22-2016, 01:49 PM
Pretty easy to install and remove.
SaferTransport's Avatar
SaferTransport SaferTransport is offline
Car: e92 335i Coupe
Default 08-22-2016, 07:03 PM
JB4 is well hidden inside the engine bay(ecu box). If you have any trouble and need to bring the car in for serious work, its a 20-30 minute un-install. I've brought my car in for small issues/maintenance many times without any issue. Ofcourse its best to find a cool service adviser(most of them are).
JB+RB=
number11 number11 is offline
Car: 2012 BMW X6M
Default 08-23-2016, 07:02 AM
Ordered JB4 and BCM...
I'm ready for some logging time!
turboalb's Avatar
turboalb turboalb is offline
Car: 08' 535i
Default 08-24-2016, 05:12 AM
Terry, what PDF or installation guide for we use?
08' 535i sport auto, jb4/mdh/xhp
10' x5m 11.72 1/4 record jb4 only
00' hayabusa turbo street bike
440 rwhp 1/8 5.42 141mph
07 SS trailblazer tuned/flex fuel
Default 08-24-2016, 08:19 AM
The first post has some details that are X5/X6 specific. The actual wiring is the same as the N63 JB4.
Car: 2008 E90 335xi
Default 08-24-2016, 09:08 AM
I know there are tons of applications for the JB4, but it'd be nice to have a one stop location with full docs for each car: Installation instructions, configuration information, etc.
The JB4 install instructions for my prior Bimmer, a 335xi, were very good. But I did have to dig a little for the configuration info on the 'net.
Speed Is Life
Default 08-24-2016, 10:16 AM
Each application has it's own thread with the first post having all relevant information, directions, FAQ, and firmware/settings. We fill it in as time allows.
Considering the low volume for this specific model the installation materials are not going to be as comprehensive as the other applications. At least not right away. But let me know what extra info you guys need and we'll start filling it in.
turboalb's Avatar
Car: 08' 535i
Default 08-29-2016, 11:15 AM
Menu 2 option 1, can we make it show boost all the time instead of 50% throttle?
Default 08-29-2016, 11:57 AM
We hard coded the way the boost gauge enables for now. But you can disable it by setting menu 2 to 0.
Car: 2012 BMW X6M
Default 09-01-2016, 08:21 AM
I'm working on the install right now. The instructions elude me.
Where do the purple and green loops connect to, to the vehicle connector? There is no JB4 connector like the N63 instructions indicate, so JB4 connector pin numbers don't correspond to the vehicle in my mind.
Can someone help please?
Default 09-01-2016, 08:24 AM
The fuel loops, and BCM loops, both connect to the DME connectors. Seen this video on how the connectors come apart to insert the individual wires?
http://www.n54tech.com/forums/showpo...38&postcount=1
Car: 2012 BMW X6M
Default 09-01-2016, 08:48 AM
perfect, that post got hit with 404 file not found last night...I'll take a look.
Thanks,
Shane
Default 09-01-2016, 08:55 AM
Yes just fixed that. We're slowly working on improving the materials here. I think we have some photos here too from the N63 JB4 which is the same basic install as this S63 unit other than the CANbus wires: http://www.n54tech.com/forums/showpo...92&postcount=3
Car: 2012 BMW X6M
Default 09-02-2016, 08:34 AM
Instructions worked great, easy to follow and hooked it all up.
When I started the vehicle, I get the engine malfunction, reduced power light. With my icarly, I got solenoid and fuel pressure sensor malfunctions. The steering wheel controls don't work (I have two sets of red/blue wires to tap into, tried both sets twice)
I double/triple checked the wires now, no difference in performance. It seems like the JB4 isn't turning on or getting power (tried switching power source twice, noid light says 12v source is hot)
Suggestions? The X6 has to run today.
Thank you,
Shane
Default 09-02-2016, 08:39 AM
First step would be to email in installation photos to tech support.
RSchm31 RSchm31 is offline
Car: 2012 335i (F30) 2012 X5M(E70)
Default 09-03-2016, 05:07 PM
Currently having an issue with the truck being in limp mode after install. There are two sets of instructions for the black brown purple and green wires for the BCM and FF wires. One set of instructions has the wires aligned as Black JB4 wire to Grey connector slot 40, Brown JB4 wire to Black connector slot 49, Purple JB4 to Black connector slot 45 and finally the Green JB4 wire into Grey connector slot 44. I am confused with this because the PDF on the site has it listed this way but the "Living document" says that the Brown JB4 wire to Black connector slot 17 and the Black JB4 wire to Grey connector slot 6. If we could clear it up, that would be great. Thanks.
Default 09-03-2016, 05:17 PM
There are fuel wires and BCM wires. Installation is per the guide: http://www.n54tech.com/forums/showpo...92&postcount=3
If there are other JB4 directions out there (not obsoleted stage2 directions) let me know where they are so we can delete/fix them... Nothing on the JB4 goes to gray#40 or black#49. That was the old Stage2 system.
Car: 2012 BMW X6M
Default 09-03-2016, 05:54 PM
Probably my issue too.
PDF after the pics, I did the exact same thing.
