(#126)
Mrpink Mrpink is offline
Car: M140i
Default 07-23-2017, 01:44 AM
Doesn't look like the B58 charge pipe?
Sounds like you have a fault if it won't prime, as it works for me, and all the others I know who fitted.
Use something like this for the fuel, makes it easier and get no spills,
https://www.ebay.co.uk/itm/251885553278
RMM RMM is offline
Car: 120i
Default 07-23-2017, 10:02 AM
thanks for the tip, that is a B48 charge pipe with single CM7 nozzle, how do you prime it, you just press the button in the BT APP and it squirts?
95% denatured alcohol is about 1.3 -1.4 USD / L here at the local pharmacy actually is good deal I think I will run it unless someone tells me not to, actually washer fluid is more costly at 1 USD for 50%, so it turns out to be 2 USD / l for meth in the washer fluid....
I just posted logs in support forum it looks to be working well timing for example is much improved peaks at 21 PSI and hold onto 19 . Very similar to B58, as that is all I have to go on as nobody else really posting anything for B48 on meth, however I assume they are pretty similar minus 2 cylinders, why didn't I get the 140i you ask, it cost 25k USD more here....
Default 07-23-2017, 10:19 AM
If you need tech support use the support forum, or email in if needed!
Must have meth map map7 selected before the prime button in the interface will work.
RMM RMM is offline
Car: 120i
Default 07-23-2017, 07:42 PM
Yup that was it, I didn't start to tune yet so I was still on my original map, thanks.
I played with the boost safety function by max out signal scale it works really well immediate and obvious and gives you a gauge swipe when activates, very cool.
Wickedowesix's Avatar
Car: 540i G30
Default 07-31-2017, 11:54 AM
Where did everyone tap in the FSB 12+ power wire from? Looking to see which wire you guys used (B58 cars)
Default 07-31-2017, 12:45 PM
It goes in the fuse box per the WMI installation guide.
Car: M140i
Default 07-31-2017, 10:31 PM
I connected it to the main power on the LHS. It's protected by the fuse at the end of the day. Works perfectly, and convenient as I have mounted the fsb next to the JB4
RMM RMM is offline
Car: 120i
Default 08-01-2017, 11:07 PM
http://www.n54tech.com/forums/attach...1&d=1501653913
this should be same as guide but wire is a bit update I think more clear
Snirre77's Avatar
Snirre77 Snirre77 is offline
Car: Bmw M140i
Default 10-09-2017, 01:49 AM
Hi just whant to know have anyone had errors regarding mix to rich with wmi
BazBar's Avatar
BazBar BazBar is offline
Car: UK 140i-M Sport Auto
Default 10-12-2017, 05:05 AM
Yup, i also get the error message, i have dual 7 nozzles.
I also get it when i run the car on map 4, with the car in Eco Mode...
Snirre77's Avatar
Car: Bmw M140i
Default 10-12-2017, 08:24 AM
I also have deul cm7 nozzles but mine happened in map7 with 100% meth
BazBar's Avatar
Default 10-12-2017, 09:10 AM
Yes, i get it in Map 7 just after some vigorous driving, and i also get it in map 4 eco mode when driving in traffic ?....Strange
Snirre77's Avatar
Car: Bmw M140i
Default 10-12-2017, 11:41 AM
Will try to lean out with some ethanol in the thank. Hope it works
Car: M140i
Default 12-03-2017, 03:13 AM
Anyone using the progressive WMI control yet?
I thinking of maybe dual 10’s or even 12’s for the higher volume at high rpm.
Maybe starting at 50% flow and ramping up to 100%
CobraMarty CobraMarty is offline
Car: BMW
Default 01-05-2018, 03:50 PM
It looks like the meth nozzles are placed near the throttle valve and spray and wet down the intercooler in the manifold.
Is that correct?
The meth alone will help decrease charge intake air temps and that would really make the IC more efficient in cooling the charge intake air temps.
No way to measure unless you place a temp sensor after the IC in one of the runners.
RMM RMM is offline
Car: 120i
Default 01-09-2018, 10:33 PM
regarding progressive, I tried it and it works well, I got some issues with going too rich at lower RPM off throttle causing shuddering and codes on defaults once I switched form CM7 to CM10 (I only have B48)
I tried to do 30 - 40 - 50 - 60 - 80 - 100 - 100 - 100 - 100
and it works well, no more shuddering but timing still same as before, also uses less meth
one question for the guys that know more about this if you set PWM too low like 30 for example is there a risk the pump may stall, or not turn at all?
N54_liam N54_liam is offline
Car: 135i e82 n54
Default 03-07-2018, 01:41 AM
Ok been having a read and got a few meth questions.
Do i need ***** before running meth or will it be ok for a while with the *** in place?
I clearly need ewg wires, but will i also need FF wires?
Does meth Only flow when in map 7?
Current: M140i
Previous: N54 - Forge BOV - Forge Chargepipe - Airtec Intercooler - DCI - VRSF - JB4 - LCA
Car: M140i
Default 03-07-2018, 09:01 AM
I reckon it won’t be atomising very well at that PWN with a CM10
Car: 540i G30
Default 04-10-2018, 03:03 PM
Will a mixture of e30 in the gas tank affect the boost with meth...? In other words would the boost be lower at the same additive with pump 91?
Bullitt1841's Avatar
Default 04-10-2018, 03:51 PM
On Map 7 (the meth map), boost will only lower if there is a meth flow issue or if historical timing gets bad. You can read more about it here: http://www.n54tech.com/forums/showthread.php?t=22272.
Otherwise, it's fixed based on the additive you select. Adding ethanol to the tank (or running an E30 mix) should only help timing. You should not notice any ill effects, only benefits.
Now if you run a higher concentration of ethanol in the main tank, you better be running E98 in the meth tank since methanol or a 50/50 boost juice mix will strain your stock fuel system and you will run lean at too much boost.
2017 F36 440i Gran Coupe | MPPSK | Track Handling Package | JB4 | BMS Meth Kit (Dual CM5) | BMS Intake | BMW 513M Wheels | Dinan Shockware
SOLD: 2007 E90 335i | PURE Stage 2 N54 Turbos | JB4 | FBO | 160k+ miles on the car, 120k+ miles on the JB4
dRDiesel dRDiesel is offline
Car: BMW
Default 04-10-2018, 08:20 PM
I personally think dual CM7 is WAY too large that's why you're getting the rich fault code. Has anyone tried a single CM7?
Car: 540i G30
Default 04-11-2018, 05:31 AM
Currently running 100% meth with e30 in the tank. I can't seem to boost more that 20 psi even if i go ADD 75. My timing is always great, peaks at 15* . Afr are well below 14:1.
Default 04-11-2018, 06:34 AM
You have the FF and EWG wires installed?
Car: 540i G30
Default 04-11-2018, 06:52 AM
Yes I do.
Car: 540i G30
Default 04-11-2018, 07:07 AM
Is there anyway i can verify the wires are in the correct pin outs on the jb4?
