(#376)
Default 05-25-2017, 10:15 AM
When running a PI rail on the E series N55 keep in mind you'll have a little less slack in the intake piping. With the factory intake you probably need to look in to a longer aftermarket coupler... But, if you have a BMS intake the fix is really easy. Just remove the bracket holding the tube to the airbox and replace with a zip-tie between the MAF and fuel rail. This allows the intake to site 1/2" closer to the passenger side removing any unnecessary strain on the inlet connection.
135ilove 135ilove is offline
Default 06-13-2017, 03:06 PM
I am looking for a bms controller for the n55. http://www.burgertuning.com/N54_seco...ctors_BMW.html
You can choose to just have the controller bought through this kit through the options but it is listed for the n54. Does anyone know if I just get the controller through that kit will it work on the n55?
2013 DCT Jet Black 135i
-JB4 Stage 2 ISO/w Flex Fuel Wires-Fuel it Stage 3 Bucketless LPFP-PDU Port Injection-Big Boost 6564 Bottom Mount Turbo Kit-Big Boost Chargepipe-Active Autowerke-BOV-Injen SP Intake with Blox Velocity Stack and Turbo Guard Filter-VRSF 7.5 in Stepped Race Intercooler--BMS OCC/OCV/CF-N20 TMAP-N20 Plugs-Motul 300v 5W-40-Archoil 9100-Motul Mocool-Custom 3.5 inch Straight Pipe Exhaust-Stoptech Rotors/Fluid-PFC Track Pads-VMR 710-Toyo R888r-M4 Flywheel- SSP R Clutches
Stoolz Stoolz is offline
Car: 11 135i
Default 06-13-2017, 03:33 PM
Yeah it does, the pinout is just different is all.
http://www.fuel-it.biz/port-injection-controller/
Just click the product description for a pdf on the install.
alexis485's Avatar
alexis485 alexis485 is offline
Car: 2011 BMW E92
Default 06-13-2017, 04:36 PM
I just want add that you need to replace the PMW chip from the JB4 board so, shoot an email to Steve or Terry to get the new chip.
2011 E92 N55 AT | FBO | JB4 + MHD + Connect Kit | Pure Stg 2 | Alpina B3 TCU Flash | Fuel-It Stg 3 LPFP + PI Platinum Kit + BMS PI Controller | COBB Exhaust | 100% E85 |
Coming Soon: ABR Built N55 Motor | Big Boost 3.4 Turbo Kit
keyap keyap is offline
Car: N55 135i
Default 06-23-2017, 09:51 AM
Hey guys/Terry
Where do I get the BMS N55 PI Controller from? I can only seem to find the N54 version on the BMS site - I've seen a few comments saying this will work but others saying it won't and that the controller needs to be N55 specific?
JB4 | BMS OCC | N20 TMap | Fuel-It! PI | AIC6 PI Controller | Fuel-It! Fuel Lines | Fuel-It! Stage 2 LPFP | Continental In-line E Sensor | ER Charge Pipe | Pure Stage 2 Turbo | Pure High Flow Inlet | GFB DV+ | Richter C'less D/Pipe | MFactory Pro Helical LSD (75% Bias Ratio) | eDiff Disabled Via Coding | MFactory Solid Diff Bushes | Diff Lockdown Bracket | Custom 98G0B BEF | NGK 5992s (0.020")
DD Map 7 at 20psi. Map 6 at 25psi for 'kill mode'
Default 06-23-2017, 12:56 PM
Originally Posted by keyap
Hey guys/Terry
I emailed bms the same question and was responded that it will work on n55s as well
Car: N55 135i
Default 06-24-2017, 04:44 AM
Thanks 135ilove,
Just had an email back from Terry confirming the N54 version can be used
Just wondering if anyone can help with a couple of other questions regarding how E content is measured and the use of meth with a BMS controller compared to the AIC6:-
* With the AIC6, E is measured via JB4 pin 16 using the meth field. The BMS controller uses pin 16, so the E input has to be read via pin 3 with FUA at 58 and uses the Duty C field. Does E content still get read OK via the JB4 mobile app if pin 3/duty C is used?
* As the AIC6 doesn't use pin 16, this is still available for meth. As the BMS controller does use pin 16 how do you use the BMS controller and meth?
Peter @ Pure's Avatar
Car: F20 M135i
Default 06-24-2017, 05:10 AM
Thanks 135ilove,
Pin 16 is only signal cable. The orange meth fsb wire is pump trigger cable. So the meth signal in log would be PI flow (and not meth). And meth flow you wont see anymore.
F80 M3 - 100-200: 4.9, 60-130: 5.6
F20 M135i (sold) - 100-200: 6.26
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Car: N55 135i
Default 06-24-2017, 06:49 AM
Thanks Peter Any thoughts on the JB4 Mobile app and whether it reads E content correctly if the sensor is via pin 3? Can't seem to find anything specific in the 'mobile' threads so may need to drop them an email.
Also, sorry to take a thread a little OT but, do you know anything about the M4 DMFW for the N55 DCTs (6 bolt version).
Unless I'm missing something, the latest I can see is that Pure had one and were sending specs/measurements etc to MFactory in order that they could produce some 'test' items?
It's a few weeks out of date but, I seem to remember MFactory posting that they were awaiting the above?
Don't want to take the thread of track so fee free to drop me a PM if you have any info
suchtragedy's Avatar
suchtragedy suchtragedy is offline
Car: 2013 335i
Default 09-22-2017, 02:53 PM
Do you need to reflash firmware after swapping this chip?
2013 335i F30 PWG | N55 JB4 ISO | Pure Stg 2 w/inlet | ER CP/BP | VRSF FMIC | VRSF ** | Injen CAI | BMS Meth kit | Fuel-It! Stg2 LPFP
alexis485's Avatar
Car: 2011 BMW E92
Default 09-22-2017, 06:24 PM
Yep! Just load the latest firmware.
Default 10-12-2017, 04:13 PM
@e36graduate
This is the port injection support thread. I'd recommend starting a thread in the N55 section to get your questions answered.
FYI, N55 doesn't have an LPFP sensor.
N55Montalto N55Montalto is offline
Car: 2013 135i FBO PS2
Default 10-14-2017, 09:26 AM
Seems like such an easy step but I can't find where to get db pin to slide into the harness? I thought I had one but it would only go half way. into the connector.
Where did everyone else get the DB pin to do the jb integration with the split second?
Default 10-14-2017, 10:38 AM
They are a normal d-sub pin but if you can't find one, email us and we'll send you out the proper connection that you can plug in to your Fuel-It! SS controller. If the female bullet connector has been cut off then let us know and we'll include a butt connector.
zipphreak zipphreak is offline
Car: 2015 BMW m235xi
Default 11-01-2017, 09:54 AM
Anyone run this on the M235 f22 ? I'm interested in how much clearance to the steering shaft there is ? My ER chargepipe is mm close to the steering shaft already, I'm worried with port injection this might hit.
Anyone here running this on the m235 BMW.
Paul
P.S's Avatar
P.S P.S is offline
Car: M135i xDrive
Default 11-01-2017, 10:01 AM
Paul
Not M235 but M135 F21 xDrive. I had to hammer FTP chargepipe a bit because it was rubbing the joint of steering column.
Before PI there was ~5mm clearance.
M135i xDrive EWG, JB4, Pure S2, Pure inlet, N20 tmap, c a tless, Wagner fmic, FTP chargepipe, Fuel-it PI, BMS PI controller, Fuel-it lpfp, ACF Performance back end flash. 10.9s @ 204km/h
Frikiton's Avatar
Frikiton Frikiton is offline
Car: 2016 F25 X4 M40i (N55)
Default 12-04-2017, 01:47 PM
Paul
Did you guys for EWG needed a special firmware or the latest F series EWG is fine? (Asking for a friend who's newbie hasn't signed up here yet LOL)
Car: F20 M135i
Default 12-04-2017, 01:54 PM
with latest ewg fw you should be fine.
peter@pureturbos.eu
pureturbos.eu
M-terkait's Avatar
M-terkait M-terkait is offline
M-Terkait
Car: F30 335i
Default 12-29-2017, 03:13 AM
Can PI power be connected to one of the fuses ( F-series N55) connecting it to 12V terminal causes battery drain. if so any recommended place.
PureTurbo N55
Car: N55 135i
Default 12-30-2017, 10:08 AM
Assume you mean the PI controller - On my E, I've run a separate 12V switched into the fuse box. From this, all the mods are powered and fused as required.
Have noticed though that the PI controller install guides show 12V switched for the E's and 12V for the F's?
Car: 2013 535i (N55 F10)
Default 12-30-2017, 11:27 AM
I have my JB4 and and PI on a switched source with no issues.
2013 F10 535i N55 PWG, Pure Stage 2, Wagner FMIC, ER Charge pipe, ER **, BMS Intake, JB4, Fuel-It Stage 2 LPFP, Fuel-It Platinum PI Kit, BootMod3 Flash, Remus Exhaust, Custom In-let
1995 e36 M3 - Future Track Car
durty sexn55 durty sexn55 is offline
Car: n55
Default 01-16-2018, 06:05 PM
any body here is running PI with and methanol injection kit only using mhd for n55 e series
2011 E82,n55 ,6mt
Stage 3+ Clutch and alumni fly wheel
Vrsf down pipe
Vrsf charge pipe
Vrsf fmic "5 inch
Jb4 , fuel flex wire and Bluetooth connection
New water pump and thermostat
Bms air intake
Meth kit cm10 60/40
E85 50/50
Stage 2 fuel pump
Pure stage 2
Ecs Lightweight Front and rear Brake Rotors brake pads
New o2 sensor
New transmission oil MTL red line
Motor oil MoTul 8100
