(#476)
Default 04-19-2018, 09:16 AM
Originally Posted by emiliof
Terry, i think we really need an update for the Mini side... Did you also know that the JB4 is not running good on new FML2 / FMK platform?
Lots of problem on newer Minis here in Italy, i think there should be some software incompatibility with them.
Please try to consider a little bit more this section, it seems like you really don't care about Mini side
No reports in to our tech support. If there is an issue then have them contact tech support with logs and details so we can sort it out!
Car: B46 F56S
Default 04-30-2018, 02:57 PM
Anyone on here running meth?
Probably going to order a kit this week. I was wondering what settings you run with and where the nozzle is mounted.
Thanks.
Car: B46 F56S
Default 05-02-2018, 01:00 PM
So blue wire on FSB goes to pin 14 or pin 16?
Payam @ BMS Payam @ BMS is online now
Default 05-02-2018, 01:36 PM
#3 Orange
#14 Blue
netnut netnut is offline
Car: 2015 Mini Cooper Base (B38)
Default B38 Map 1 logs - 06-06-2018, 01:50 PM
Here are a couple of map 1 logs on my 2015 Base (B38) with K&N CAI and muffler delete. Costco 92 octane.
Is there anything left on the table here?
Default 06-09-2018, 09:01 AM
Timing look OK. For fun log map2 and lets compare.
Lcwai Lcwai is offline
Car: Mini jcw f56
Default 06-13-2018, 05:37 AM
HI TERRY
JB4 CAN SUPPORT FOR MINI COUNTRYMAN S F60 MODEL OR NOT ?
Default 06-13-2018, 09:08 AM
Email us photos of engine with cover off and we can confirm.
pnice1p pnice1p is offline
Car: 2015 M3
Default FLEX FUEL HELP NEEDED. B48 Mini - 06-30-2018, 04:35 AM
I have the jb4 installed for my 2015 Mini Cooper S. I purchased the bluetooth module and the Flex Fuel connector. I spent two days researching before sending this post, the FF connector that I received has a green and black wire with pins at the end. Where do they connect into the JB4?
So what im asking is the green pin goes into slot_______
and the black pin goes into slot_______ in the AMP25?
Burger has no instructions anywhere stating that.
Herc Herc is offline
Car: F20 125i
Default 06-30-2018, 06:54 AM
2nd post in this thread
Car: 2015 M3
Default 06-30-2018, 07:00 AM
So does that mean that the male is Black. It's not clear. That's all I need to know the rest is following instructions.
Car: 2015 M3
Default 06-30-2018, 08:02 AM
Does anyone know, is it the Green that goes into DSUB #21 OR THE BLACK?? Anyone, please. I would like to button this up.
Default 06-30-2018, 09:10 AM
For the fuel pressure connector? Green goes to 21.
Car: 2015 M3
Default 06-30-2018, 09:25 AM
Thanks. Black gets spliced if 4 is occupied right?
Car: B46 F56S
Default 07-11-2018, 05:55 AM
Any idea if we can reset DME Adaptions with our JB4?
Car: B46 F56S
Default 07-11-2018, 07:39 PM
Anyone know if Map 3 is live?
I have a BMS WMI Kit but on the original post it says "Under Development".
Car: F20 125i
Default 07-12-2018, 05:20 AM
reset DME
1)JB4 must be set at map Zero (0) not 4 or any other map
2)You enter and turn the Electrics not the engine so gear in neutral and foot off the brake or clutch
3)As soon all have turn on you step on the gas pedal all the way down and you hold for 30 seconds by the clock. Monitor the time by setting your phones timer or stopwatch feature to accomplish that.
4)As soon the 30 secs have passed without releasing the gas pedal turn off the electrics. When that is accomplished release the pedal and wait for 2 mins. Dont lock the doors
In a rather quite environment and performed correctly you may hear a hard drive buzz going on within those 2 mins of waiting.
you are done!
method B if you have carly it does it
Method C ISTA i think or similar software via obd
Car: B46 F56S
Default 07-12-2018, 03:15 PM
reset DME
you are done!
Thanks for the info.
I tried the above method but didn't hear any activity. I will try it again later today.
I also have CarlyBMW but cannot find the option anywhere. Have you done it via Carly?
Car: F20 125i
Default 07-12-2018, 11:20 PM
am manual so doesnt work for me. If you have updated carly it is the latest feature should be all the way down or fully right depends your phone.
Car: B46 F56S
Default 07-17-2018, 01:05 PM
Removed my tune and back to stock map.
Does our JB4 Support auto clearing code for no ***?
Or do we need to manually clear each time?
Jay1312 Jay1312 is offline
Jay1312
Car: BMW 320i and M5
Default 07-18-2018, 05:10 AM
Anyone else noticed boost safety change from 22 to 21 on the user settings? It wouldn’t allow anything more than 21.
