Azbmw335i Azbmw335i is offline
Car: E92 335i
Exclamation Jb4 problem - 11-13-2017, 05:53 PM
Yesterday night I heard a weird noise coming from the board itself. It was a continuous beeping sound. I tried disconnecting it and plugging back in but that didnít stop it. Today I started my car and got the engine malfunction light. Put in map 0 restarted and same problem. I got 3 codes p0238 p0108 p007d. Maybe you can help me out. Definilty think the board is defective.
Default 11-13-2017, 09:45 PM
Never heard of a noise coming from the board, got a picture of the board? Any signs of damage?
Car: E92 335i
Default 11-14-2017, 04:58 PM
No damage. Website will not allow me to attach picture. Keeps getting this one code (p10f2) and itís throwing me in limp mode.
Default 11-14-2017, 05:15 PM
Then reduce the image size, we'd need that to assist you further.
Car: E92 335i
Default 11-14-2017, 09:01 PM
Here you go. I decided to take the jb4 out completely and see if the problem would occurred but it didnít. Car runs good without it. Just super slow without tune
Default 11-15-2017, 08:07 AM
I don't see anything obvious with the board. I'd re-install and verify your connections are good. Maybe a bad power or ground connection?
Car: E92 335i
Default 11-15-2017, 04:33 PM
Yeah I reinstalled it made sure everything was tight but problem came back after a few mins.. no going to sell it and rip someone off. Do y’all recycle these ?
Default 11-16-2017, 08:25 PM
The noise did?
Haven't seen a log or your settings, maybe an issue with those?
Never heard of a noise coming from the board before.
Car: E92 335i
Default 11-16-2017, 08:33 PM
The noise did?
Not the noise but car went in limp mode and engine malfunction again. I posted my logs in another thread. They said my logs looked good. Yeah it was a beeping noise. I opened the ecu box to verify it was from the board.. Might be defective wire who knows. Don’t really have the time to play with it much. Do they do exchanges or anything? Any kind of warranty
brooks1005 brooks1005 is offline
Car: 2013 BMW 335i
Default 11-17-2017, 12:24 AM
While installing a new intercooler last night, I heard the same beeping coming from the location of the JB4. It seems to happen when the hood is up.
2013 BMW 335i Coupe M-Sport, BMS Intake,FTP charge pipe, JB4 Stg 2, Active Autowerke D**npipe, Rev9
Default 11-19-2017, 11:33 PM
The JB4 does not have the ability to make a beeping sound...I'm not really sure what that is but doubt it is the JB4.
You can always send it in to be tested if you think it's bad.
Car: E92 335i
Default 11-19-2017, 11:48 PM
Call me crazy but I know 100% it was from the jb4 board. Technically speaking any electronic has ability to make sound... Sounds good thanks
das86turbo das86turbo is offline
Car: 2012 335i xDrive M
Default P007D, P0238, P0108 - 02-06-2018, 01:12 PM
I got the same codes. Did you resolve your problem?
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 02-06-2018, 08:11 PM
Really want to see someone from BMS chime in about the electronics on the boards re: beeping. Two people saying it beeped is cray.
OP, have you emailed BMS directly about this? Might get better assistance.
2009 535i Sport
548 whp/ 489 wtq
Software: JB4 G5 | MHD | Trebila Tune | XHP Stage 3
Hardware: GC Lites | Inlets | Outlet | 3" D-P's | 7" FMIC | S2 LPFP | TBI | DCI | ER CP | Forge DV's | 3.5 TMAP | RB PCV | Koni FSD
Default 02-07-2018, 09:18 AM
The board can't "beep". I'm not sure what is being heard.
