(#2701)
Default 11-14-2017, 04:58 PM
Map1 is the WG spring map. WG spring should be set for around 15psi. If you make more than that on map1 work on WG, spring, solenoid routing, lines, etc, to resolve.
Twilly Twilly is offline
Car: 07 335i 6MT
Default 11-14-2017, 06:57 PM
Thank you terry. Found a solenoid wire burnt through. Also will check my wastegate routing up. My spring pressure should be about 11.6psi. Also i think i forgot to block then atmosphere ports on the wastegate. Could that be a problem also?
Default 11-14-2017, 07:27 PM
Absolutely!
ThreeDirtyFive ThreeDirtyFive is offline
Car: BMW E92 335i
Default 11-15-2017, 10:44 AM
Also for the single turbo firmware I'm working on a new safety system for monitoring timing drops and reverting to map1 if they exceed a certain number. If you have time to help log it, drop me an email.
Hey Terry
How is the testing going ? Any time soon to be released?
Default 11-16-2017, 08:41 AM
Not gotten much feedback yet... Everyone who contacted me to test it failed to mention their cars were not running yet...
rhm135's Avatar
rhm135 rhm135 is offline
Tech
Car: 335is
Default 11-16-2017, 10:26 AM
Originally Posted by Twilly
installed acf top mount single turbo kit. Single turbo bef mhd. Is map one sill safety map? Iím having over boosting problems. Shots to 21psi on pulls. Used white and green springs in the waste gates. Please let me know if you have any suggestions will try to post a log soon
I had the same problem. I also used the 11.6lb combo. After checking my wastegate lines and testing of the solenoid with no problems found. I tested wastegate springs using a pressure pump w/gauge. I found with the 11.6lb springs the valves on my wastegates don't open until 20+ psi. I installed the black spring (8.7lb) and found they open at 13~psi using my pressure pump.
After doing some logs in map 1 with black springs installed I was staying right around 13 psi boost pressure under WOT. Problem solved! Hope this helps Twilly.
2012 335is DCT - JB4 - Fuel-it! - MHD - DOCRACE 6466
Default 11-17-2017, 01:04 PM
If I had $1 for every customer who installed 15# spring but actually hit 21#... I'd have a lot of dollars. For whatever reason, the ratings are always wrong in our application.
rhm135's Avatar
Tech
Car: 335is
Default 11-17-2017, 02:30 PM
Lol! Right! Something to do with N54 manifolds and back pressure?
Default 11-17-2017, 09:10 PM
Must be, or maybe how the WGs are setup.
chiefsotos chiefsotos is offline
Car: BMW 335 E93
Default 11-18-2017, 03:04 PM
What is the best solution for o2 sensors problem for single turbo?
I searched many threads and haven’t understand if Chris adv sensors do solve the problem, or is there any better option.
S3nder S3nder is offline
Car: 135i e82
Default 11-22-2017, 02:34 PM
Whats the problem with o2 sensor with single turbo ?
Almost all tuners use sensor BF turbo but Why it wont work after turbo ?
I welded my own manifold and but o2 sensors to ******** .... havent try it yet but will it be problem ?
Default 11-22-2017, 02:39 PM
Best bet is to run the NGK sensors and make sure they are easy to swap on your manifold, IMHO.
Car: 135i e82
Default 11-22-2017, 02:49 PM
Installing o2-s to ********, So need jacking every time I need to change
Car: BMW 335 E93
Default 11-23-2017, 03:25 AM
Terry which ngk sensors should someone buy?
Whar settings should be done with stock sensors and what with ngk at jb4 and mhd backen software?
Car: 07 335i 6MT
Default 11-28-2017, 11:08 AM
rhm 135 thanks for the feedback. tonight ill see if I have time to put the blackspring in. its just so odd that it does that.
Car: 135i e82
Default 11-28-2017, 11:13 AM
Does anybody know How post turbo o2 sensor setup works nowdays ?
I seen some threads Thats its possible but... ?
Car: 07 335i 6MT
Default 11-28-2017, 11:25 AM
im using Chris ADV sensors and all I had to do was click the option in MHD
Car: 135i e82
Default 11-28-2017, 11:28 AM
And you use your o2 sensor after turbo or In exhaust manifold ?
Car: 07 335i 6MT
Default 11-28-2017, 12:06 PM
downstream 02 sensors are oem sensors in the ********. not much use for them since I don't have kitties and I have the BMS ** fix installed.
Car: 07 335i 6MT
Default 11-29-2017, 04:27 PM
well while I was putting the black spring in I think I found another problem. I had a air port not blocked off on the wastegates. there are three air ports that need to be blocked off but my kit only gave me two plugs for each wastegate... am I missing something?
Default 11-29-2017, 04:45 PM
That would cause a major overboost, if its a vacuum port. If it's a water port no big deal.
rac rac is offline
Car: 2008 135i 6MT
Default 11-29-2017, 05:22 PM
My JB4 died so I had to remove it. The JB4 was taking care of the fact my boost solenoid harness was disconnected (wastegate deactivation 2). Now with no JB4 I have to clear the wastegate deactivation codes every time I start the car. What can I do about that in the meantime while I get a new JB4 or repair the one I have? Can I put a resistor in that circuit or is there a flash solution? I didnít see a flash toggle on the public XDF to switch these codes off, not sure what the flash only guys are doing about it.
Default 11-29-2017, 06:53 PM
How did the JB4 die?!? Email us and we can get that sorted for you.
rac rac is offline
Car: 2008 135i 6MT
Default 11-29-2017, 07:59 PM
Yeah I emailed Jon already asking if I can send it back for bench testing.
I went to start it and the LPFP was continuously turning over and the the engine cranking but not firing, also could not communicate with JB4.
Could be a few things. That same day the last time I drove it I was getting sudden AFR drops to zero so something was on its way out. In any case i will be with these annoying wastegate deactivation codes until its sorted for a few weeks or longer given Christmas is approaching - so is there anything i can do to keep the DME quite on that front?
Default 11-29-2017, 09:33 PM
Just ignore them until its resolved.
