(#426)
bobbyggx bobbyggx is offline
Car: '11 BMW F10 535i M Sport
Default 11-14-2017, 09:27 AM
Hi Terry,
I've been adjusting the ISO firmware and it seems that I cannot get it right.
Now, with suggested settings the FF is again way off from the WGDC, the car runs a bit lean (FOL = 60 would fix this most probably) and again I am not meeting the targets.
Last night I did a trial run with PID 35 and FOL 50 and more drastic settings in Duty BIAS and the results seemed fine with small over boost (which I can consider as a small feature as long as the throttle is not closing much).
Enclosed I am attaching the logs from today and last night with the different settings.
I would very much appreciate your feedback and suggestions what should be pushed within the parameters.
P.S. The car was hitting 11.8 in DME_BT which is the first time I saw such a high values as I was always thinking that my DME_BT is requesting too less.
Sicmadek Sicmadek is offline
Car: 2013 335i sportline
Default 11-14-2017, 09:54 AM
Anyone have the firmware that was posted before t12? I think it was t6
2013 335i sportline pwg 8at~jb4 iso~e40~bms oil cooler valve~bms intake~wagner c-less~ap catback~phoenix ic~gfb dv+~pure inlet pipe~er tic pipe~vrsf cp~ngk's @ .022~h&r super sports~437m
zole2112 zole2112 is offline
Car: 2013 BMW 335xi F30 N55
Default 11-14-2017, 10:14 AM
I may have it at home, I can check this afternoon if nobody else has it.
Injen CAI/ER CP/VRSF C-less DPipe/Active A FMIC/JB4 ISO_9 - Map 5/93 octane for winter/Custom tuned exhaust/stock turbo/Resonator Delete=Pops and Burbles!!
Coming Summer 2018: PI/Speedtech 7670/Dual Walbros/MHD flash and Tune by Trebila = epic Summer!
Default 11-14-2017, 10:19 AM
Default 11-14-2017, 01:03 PM
Hi Terry,
I think I made some progress with the PID/FF/FOL stuff. Please have a look at the attached logs.
I have one question regarding the pedal. I noticed that if I am not in WOT mode but pressing the pedal 85-95% the car seems to be running better and faster, at least it pulls like a trane while in WOT I don't have the same feeling.
Another interesting thing is that one of my runs the car felt weak, but looking in the logs everything seemed fine, good boost, meeting targets etc.
P.S. I've changed the 6-cyl Timing to 30, but didn't noticed any pedal aggressiveness.
Default 11-14-2017, 04:18 PM
Originally Posted by bobbyggx
Hi Terry,
Your duty dias is all over the place which is why your boost is up and down
Default 11-14-2017, 11:55 PM
What do you mean all over the place? In my latest logs my boost is going UP when I shift and then gets a peak which is handled by the throttle.
The other time, when the boost spikes is when I do WOT at around 2,5k rpms (this might explain the better acceleration with 85% of the pedal). This I am not sure how I can handle as the DB in that area is 50 and 52 with PID 20. I am open to suggestions.
cnm135i cnm135i is offline
Car: m135i
Default 11-15-2017, 12:50 AM
Hi Terry,
Hi
Please update to latest FW. I can email the T3 if you want the CEL auto-clear. You are not logging gear and 6-cyl timing. Would be great if you got that working. Next time try to do a 4th gear 2000-7000rpm shifting into 5th. From my experience setting DB to 45 from 3500rpm and down will reduce tip-in over boost. You can try that.
M135i, PWG, Pure Stg2, WMI, bootmod3 + JB4
100-200kph: 7.0sec (93 and meth)
www.youtube.com/user/npharkes
Default 11-15-2017, 04:42 AM
Update firmware as recommended because your log doesnt even show what gear youre in
Default 11-15-2017, 06:11 AM
As far as I know Terry uploaded the latest FW before shipping the JB4 to me. I will drop you a PM with my mail so you can send the FW.
All my logs start from 3rd gear I am shifting before 6k usually.
Default 11-15-2017, 06:35 AM
Originally Posted by cnm135i
Hi
Does the T6 have the auto clear, I thought it did.
Default 11-15-2017, 12:34 PM
Terry sends out f series iso boards now? I thought everyone had to cut out the diode at their own risk.
Default 11-15-2017, 03:05 PM
Of course it is the owner’s risk, I just wanted it like this.
Default 11-15-2017, 03:12 PM
We normally don't ship boards with F ISO loaded. If a request was made at order time one of the guys may have done that at the office.
Default 11-15-2017, 03:51 PM
My question is an I runnig the latest FW or I should update?
@Terry, I would appreciate your feedback on the logs with any remarks/suggestions.
Car: m135i
Default 11-15-2017, 05:56 PM
Your log says 16/7//1 = so that should be ISO_7_T1 (I assume).
16/7//3 (ISO_7_T3) is from around late May according my logs and the last revision supporting CEL auto-clear.
All following ISO_7_Tx's I have used are also called 16/7//3 in the .csv so this makes it a bit difficult to tell them from each other.
Default 11-18-2017, 01:46 PM
The firmware is uploaded and now I can see timing and gear.
With the same settings (only lowered the FF at 2.5k-3k) I am getting oveboost, thus I would have to play with the settings to match them.
Default 11-18-2017, 02:10 PM
Duty bias changes should be smoothed from one RPM break to the next, unless you want your boost contort to also resemble a staircase.
Default 11-18-2017, 02:16 PM
How can I achieve that? For sure I don’t want a staircase :D
I would reset the DB to the auggested starting point and start from there to adjust, unless of course you can suggest another approach.
P.S. From timing perspective how does it looks like?
Default 11-18-2017, 02:55 PM
It's easier to dial in dutybias when you have a long run from low RPM to high, so you can see what sort of WGDC curve your turbo is looking for. So I'd reset to the default duty bias settings and then log say 1500rpm to redline in 5th gear.
Default 11-18-2017, 03:03 PM
Will do that and teport back! Thank you!
EDIT:
Here are the results -> 5th gear, 1500rpms, DB is all the way 50, FOL 50, PID GAIN 25, FuD 174 (because of FuD settings the system is not logging gear and all cylinders, when I answer the questions I have value 174 which is again not logging the gear and the timing, but if the value is 99 everything is fine).
The real (JB4) boost seems to be fine until 4700rpms and then it starts dropping.
The next steps for me are:
1. To figure out the right FuD value; (I would appreciate some help, as when I press Bits and answer the questions I am not getting the desired results. From what I read bit6 is the one responsible for the timing, but there the question is different).
2. Adjust DB starting from 3000rpms to try to have the FF and WGDC as closer as possible; (Am I wrong or this sounds a feasible start?)
3. FOL 50 seems to be a good much in high revs, but in but 3000-5000 the car seems to be running on the lean side. Adjust to 60 may be?
4. I am thinking of raising the FUA above 30 so I would get less throttle movement. Would this be a good idea? Currently I see exactly .8psi difference all the way.
-> Looking at my log from 2000-3500 rpms there is higher than 20% throttle movement which I cannot explain. Boost (DME_BT/ECU_PSI) is .8psi off, the JB4 Boost/Target is near even a bit on the lower side, but still the throttle is closed. At 2000 rpms there is .9psi overboost (above JB4) which can explain the throttle being closed about 40%, but afterwards everything seems fine while the throttle remains half closed.
5. ... @Terry, anything else?
P.S. I would assume, now when I have the WGDC demand, it would be fine to log in 3-4th gears as in 5th I am reaching quite a high speed which is a bit illegal
Default 11-19-2017, 10:28 AM
I still haven't had a chance to add that option to this firmware, but it's on my list.
Default 11-19-2017, 10:32 AM
EDIT:
Load on this firmware is manifold boost pressure. If it matches pre-throttle pressure, the throttle movement should be ignored.
FUD bits definitions are in the first post if relevant to this firmware.
In terms of WGDC you see it ramping up around 3500rpm. Also noticed you DID NOT load the default values. You just set everything to 50. Anwyay something like this might be worth trying next:
1500: 50
2000: 50
2500: 50
3000: 50
3500: 54
4000: 58
4500: 62
5000: 66
5500: 72
6000: 76
6500: 80
7000: 84
Default 11-19-2017, 12:28 PM
I thought 50 is the default? The FF adaptations weren’t turned off in the above log. I did few logs today but without any satisfing results. I managed to map the FF/WGDC (with WG adaptations turned off from the bits) curves but I was getting underboost in high rpms. Now the FF Adaptation is around 105 and DB around 86 at 5,5k rpms.
Should the adjustment procedure include adaptations turned off or not?
Enclosed is the log and afterwards slightly adjusted settings which I never got the chance to test as it started raining.
Second log is after the FF adaptations were ON and the curve starts looking at staircase: I would assume I should drive with the FF adaptation turned on?
P.S. After the below run I turned ON the FF adaptation and it went to 105.
Default 11-19-2017, 12:56 PM
Default settings are in the first post. Your duty bias doesn't seem to be entered right either. FUA and FUD should both be 0. PID gain should be 25.
If you require CANbus on full time then you can enable that FUD option.
