Bullitt1841's Avatar
Bullitt1841 Bullitt1841 is online now
Default 2017 440 Gran Coupe at No Fly Zone CA (11/4/2017) - 11-12-2017, 11:21 AM
Just thought I'd share in the B58 section since a lot of you don't check out the N54 section much. That's typically where Terry posts these racing event results.
I had a blast and I'm really excited to own a B58. Can't wait for further progress as time passes. Car is pretty quick for only a JB4, intake, and meth (MPPSK is basically a sound only mod if you have a JB4). With a bigger turbo, this thing is going to fly!
Map 4: 132.82 MPH
Name:  2017-11-04 11_02_55 (NFZ CA - RUN 1 - CTS-V - 132.8 MPH)Map_4.jpg
Map 6 @ 17 PSI: 138.38 MPH
Map 6 @ 18 PSI: 140.27 MPH
Name:  2017-11-04 11_25_32 (NFZ CA - RUN 3 - MUSTANG - 140.3 MPH)Map_6 - 18 PSI.jpg
Map 7 @ 19 PSI: 141.15 MPH
Map 7 @ 23 PSI: 143.40 MPH
Map 7 @ 24 PSI: 144.14 MPH
Name:  2017-11-04 16_56_43 (NFZ CA - RUN 20 - SOLO - 144.14 MPH)Map_7 - 70 ADD - IAT SPOOF 70 - BEST TR.jpg
Videos:
http://www.n54tech.com/forums/showth...50277&p=567568
2017 F36 440i Gran Coupe | MPPSK | Track Handling Package | JB4 | BMS Meth Kit (Dual CM7) | BMS Intake | BMW 513M Wheels | Dinan Shockware
SOLD: 2007 E90 335i | PURE Stage 2 N54 Turbos | JB4 | FBO | 160k+ miles on the car, 120k+ miles on the JB4
Mrpink Mrpink is offline
Car: M140i
Default 11-12-2017, 12:36 PM
What boost additive is that for 24psi?
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 11-12-2017, 12:40 PM
Wow the stock turbo is holding 24 psi? Seems like you were running out of meth flow and fuel at that boost level.
Default 11-12-2017, 01:20 PM
The B58 firmware always targets 0.3 PSI higher than what you request. So when you enter a flat boost target Map 6 of 18.0 PSI, for example, the logs will show 18.3 PSI as the target.
With that said, a 70 additive shows 24.3 PSI and an 80 additive shows 24.6 PSI. I haven't tried any higher than 80, but I think that's what Terry set the limit to in the firmware so far (24-25 PSI).
Default 11-12-2017, 01:43 PM
Meth flow was well above the required 60% the whole time. I was just fighting air bubbles/leaks for a little bit. I had plenty of fueling, though. I had to keep lowering FOL because my trims were so low. 6th gear just doesn't like this much power and I'm sure the tuning will get better with time. But yes, the AFR, boost, and throttle don't look very good in 6th gear.
Yeah, I think the stock turbo does just fine holding that boost level. Keep in mind most of the testing and logs that are publicly posted are pretty old, so maybe the newer firmware is better for holding that much boost?
For anyone that's interested, I have been able to run 100% pump E85 (not measured/verified) on a 40 add (19-20 PSI) and T98. AFR's are very, very safe:
Name:  2017-11-08 21_28_26 (T98 METH TESTING - STRAIGHT E85)Map_7.jpg
Running methanol will not allow you to run as much E85 in the gas tank, but you could probably get away with a good amount.
I'm going to be doing a bunch of E85 and meth testing in the coming months. I think the external meth tank/pump is really allowing us to bypass the DME's fuel cap since it never gets reached. I know Terry has slowed down the E85 development on this platform since meth and pump gas are simply more convenient. But an E85 station just opened up down the street from me, where the closest one used to be 30 minutes away. It would be nice to be able to run E30-E60 and make lots of safe power on the B58.
Car: M140i
Default 11-13-2017, 12:42 AM
What about running straight ethanol in the external tank rather than methanol for the higher fuel energy rating, and then a can of Boostane or torco in the main tank.
That should keep the high energy rating of the petrol but increase the octane rating to that of e85, or there abouts.
I’m currently testing 20% toluene mix with 99ron in main tank, spraying straight meth and works well. Going to start upping the boost additive now.
Wickedowesix's Avatar
Wickedowesix Wickedowesix is offline
Car: 540i G30
Default 11-13-2017, 08:56 AM
I have been running e30 and 100% meth for a while now and she feels great!
JB4OFF JB4OFF is offline
Car: 340i
Default 11-13-2017, 10:45 AM
Nice runs. How are you running 100% E85? The dmebt usually goes down when I add anything over 3 gallons
Default 11-13-2017, 01:19 PM
Iím currently testing 20% toluene mix with 99ron in main tank, spraying straight meth and works well. Going to start upping the boost additive now.
Yeah, that's what I was running that day (100% T98). I had the max amount of Torco in the gas tank mixed with 91 (32 oz. Torco to 5 gallons gasoline).
This also works well: http://www.kleanstrip.com/product/gr...atured-alcohol. It's 80% - 90% ethanol and 5% methanol.
Default 11-13-2017, 01:21 PM
I was spraying T98 (98% ethanol) so that reduces the DME's fuel requirement by a lot. Even though trims are high on that Map 7 run, AFR seemed to go down like stock.
Car: M140i
Default 11-13-2017, 01:25 PM
Just ordered some ethanol to test in the external tank for spraying. Then will test with Boostane in main tank once the toluene mixture has run out. I think Boostane is similar to torco
Default 11-13-2017, 01:28 PM
I actually tested Torco and this, back to back. Sounds corny, but it performed quite a bit better than Torco: http://race-gas.com
Car: M140i
Default 11-13-2017, 01:31 PM
Have you tried Boostane yet?
Default 11-13-2017, 01:42 PM
No, I have not.
Car: M140i
Default 11-13-2017, 01:44 PM
I’ll let you know how it is and post some logs
Car: 340i
Default 11-13-2017, 01:46 PM
Interesting I’m running x98 vp in the BMS tank and I’ve noticed it seems happier. What size nozzles?
Default 11-13-2017, 01:57 PM
Good day racing. And I'm sure we'll be able to squeeze more out of it in good time.
Found my our stock turbo 340 1/2 mile results at shift sector, and its best was also 144mph. So in the ballpark: http://www.n54tech.com/forums/showthread.php?t=37385
Default 11-13-2017, 03:12 PM
Interesting Iím running x98 vp in the BMS tank and Iíve noticed it seems happier. What size nozzles?
Dual CM7.
viperstang1 viperstang1 is offline
Car: 340i 2016
Default 11-14-2017, 12:41 PM
i use boostane all the time with 100% meth...good results all the time. just adding boostane makes the car feel stronger
Car: M140i
Default 11-14-2017, 12:55 PM
What ratio are you using mate? Any chance you can post some logs
Car: 540i G30
Default 11-15-2017, 06:09 AM
Attachment 69143
Curious did you run these map settings in the half mile?
Default 11-15-2017, 07:40 AM
No, I didn't run any ethanol in the races. I might next time.
Car: 340i 2016
Default 11-15-2017, 08:28 AM
one can of boostane to full tank of 93...
Juan_BIGBOOST_TURBO's Avatar
Default 11-15-2017, 10:30 AM
I used a full 32oz Race Gas fuel concentrate can in 5 gals of 93 oct to do a 570 WHP run with X98 in the meth tank + TBI.
BigBoost Instagram: @bigboost_turbo
webpage: bigboostusa.com
Facebook: Big Boost Turbo
BigBoost's car: BMW M240i
Stage 3.2 turbo
Current B58 Horsepower record holder: 563 WHP.
Daily Driver: BMW M235i
BBT stage 3.3 turbo
Car: M140i
Default 11-16-2017, 03:56 AM
So you are using ethanol injection from external tank, and injection from main tank?
Is that the BMS dual spacer for the alcohol? How is the TBI from the main tank sprayed, is it in the charge pipe too? I havenít seen any pics so unsure how it all works.
