(#676)
BeGooD69 BeGooD69 is offline
Car: 2007 335i
Default 12-27-2017, 04:25 PM
Originally Posted by SUBSCALE
Hey, guys I recently tried to install the antilag on my car, and I was stupid enough to put the black cable on number 17 in the grey subconnector instead of the black now my car doesnít start, it only cranks I need help as soon as possible. I put the cable in the right spot now the car still doesnít start, itís not a battery thing either
Check the fuses.
SUBSCALE SUBSCALE is offline
Car: 2010 N54 335i e92
Default 12-27-2017, 04:49 PM
Originally Posted by BeGooD69
Check the fuses.
I already checked none are blown
Car: 2007 335i
Default 12-27-2017, 05:18 PM
U said.. cracks but no start.. and fuses all ok.. did u checked them all? That was my issues when cranking and no start..
Did u reinstalled the jumper where it was before u trying to install the anti lag?
Do u have any code? Erased them?
Did u tried without the jb4 at all?
Default 12-27-2017, 06:02 PM
I donít have any codes, everything is in the correct spot now I have the jumper cables on, Iím not sure if the lpfp is priming tho
Car: 2007 335i
Default 12-27-2017, 07:06 PM
U r using jb4, do u have jb4 mobile? Display the lpfp gauge, see if pressure raises.. or u can also brake the fuel rail nut to see if fuel is pressurized ..
Default 12-28-2017, 12:05 AM
I figured it out, when I pulled out the jb4 to insert the chip the 2 step relay disconnected from the power supply so I wasn’t giving power to the lpfp I think.
BrendenV BrendenV is offline
Car: 2010 BMW 335i Xdrive
Default 02-09-2018, 11:49 AM
So i just installed mine and when i select a gear, volume down, gas 100% Iím getting the IAT to drop to 20 but itís still accelerating. Is this normal?
Jameshawk101 Jameshawk101 is offline
Slo335
Car: 2009 e92 335i 6MT M-Sport
Default 02-09-2018, 11:43 PM
Do you have the correct flash?
Default 02-09-2018, 11:55 PM
Yes, it should accelerate a little still. You should see boost start to build quicker than normal.
Default 02-10-2018, 08:11 AM
I didn’t reflash. I was already flashed with IJE0S pump. Do i have to reflash?
I’m talking like it feels like it starts accelerating without boost then launches but there’s no way that even with brake boost I’d be able to hold at the same speed. I was under the impression that the anti lag pretty much disables the throttle and holds almost like cruise control until the volume button is released.
I can post a log if that helps?
Default 02-10-2018, 01:11 PM
I didnít reflash. I was already flashed with IJE0S pump. Do i have to reflash?
Iím talking like it feels like it starts accelerating without boost then launches but thereís no way that even with brake boost Iíd be able to hold at the same speed. I was under the impression that the anti lag pretty much disables the throttle and holds almost like cruise control until the volume button is released.
Logs will help!
Default 02-10-2018, 07:46 PM
Logs attached. From a stop and rolling.
N54QC N54QC is offline
Car: 07 BMW 335i
Default 02-10-2018, 09:05 PM
Mine has always accelerated a little when doing it. It will also try to push you off the line from a dig so you have to push the brake harder to try to hold the car. Wish you could use it without moving.
Default 02-11-2018, 10:57 AM
May not have the back end flash map tables set properly. But to engage from a roll select the gear you want to start in, take your foot off the gas, press the volume down, press the gas 100% (but don't hit a kick down), and timing should remain at 0 until you let go of the volume button.
Default 02-11-2018, 11:01 AM
Flash map tables set properly, can you explain this and what i need to do to fix it? Maybe just reflash the BEF? I’m on the pump flash. Just filled up with 4 gallons e85 and 10 gallons 93 so maybe I’ll try the e85 flash and see if anti lag starts working.
Default 02-11-2018, 02:27 PM
Got it. Flashed e85 map and it works now.
Martin.328 Martin.328 is offline
Car: 16 328
Default 03-05-2018, 02:59 PM
Does this work for the n20 guys too?
KevinC39 KevinC39 is offline
Car: 11 335i 6MT RWD
Default 03-05-2018, 05:35 PM
Doubt it. Last I knew there wasn't even an N55 version
2011 E90 335i RWD 6 Speed
FBO JB4 MHD
Wrecker 426 Wrecker 426 is offline
Default 03-27-2018, 02:39 PM
So spent some time reading and can't find the answer to this and want to make sure before I go changing stuff, Iv had the anti lag chip and wire since I bought my JB4 2 years ago.... Can I do the full install and still run normal with out it. That way I can just change fuel and maps on the MHD flasher use it then flash back?
07' 335xi, JB4 G5, gutted stock downs, 2nd Delete, JB4 Pump BEF, Alpina B3, VVT stage 2, Stage 2 LPFP, Phoenix Race IC, Meth, MMP AL inlets, AL Outlet
e92ace e92ace is offline
Default 04-12-2018, 09:18 AM
Is there a way to increase or decrease the amount of boost built while at a stand still for the 2 step function. can't seem to find any recent info. I'm MT and have the latest firmware and bef as of 4/1/2018. also anyone have a link to the newest jb4 steering wheel controls just want to double check im using the most current thanks
WD40 WD40 is offline
Car: BMW 335i
Default 04-14-2018, 08:12 AM
Hi, So i've read that the PUMP MHD BEF does contain the antilag tables and some people say it doesn't I have looked in TunerPRo and can see there are a number of differences in the tables but not loads. I'm assuminng i need to make the rest of the changes then reflash but want to confirm that the first post containing the tables should all be applied on the PUMP MHD BEF. am using JB4_BB2_I8A0S_PUMP.bin for the BEF.
Car: BMW 335i
Default 04-15-2018, 06:39 AM
Never mind, just duplicated the settings from OP and reflashed BEF with new settings and tested and all working as intended loving it.
Bmwe90mods's Avatar
Bmwe90mods Bmwe90mods is offline
Car: 2010 Bmw 335i Sedan
Default 04-15-2018, 02:31 PM
Hello all,
Super new at the n54 world. Had Cobb and sold it to get the JB4. Installed the JB4 w/Bluetooth a month ago. Just installed my anti lag a week ago. Having issues with needs to be next.
There’s talk about flashing, bef and tumerpro which I have no clue of any of this.
Also which map is the e85 map?
And what can I do if there is no e85 where I live what are my possibilities to get anti lag to work?
Car: All of 'em
Default 04-15-2018, 02:48 PM
Originally Posted by Bmwe90mods
Hello all,
Thereís talk about flashing, bef and tumerpro which I have no clue of any of this.
You need to flash the car in order for AntiLag to work properly. The e85 BEF map from Burger Motorsports already has the necessary changes in the flash to make the system work. You can make the same changes to the pump gas flash, but do so at your own risk. I don't know if burger motorsports 'supports' this or not, I wouldn't recommend it on stock turbos unless you are just planning on replacing them.
The car should drive fine with the antilag installed regardless of if you are flashed as long as you do not operate the volume down button to enable antilag.
Bmwe90mods's Avatar
Default 04-15-2018, 03:00 PM
This may sound totally dumb.....
Where do I find the BMS e85 bef?
Once I find the bef how do I load the bef into my JB4?
Thank you for help and patience!
