Sicmadek Sicmadek is offline
Car: 2013 335i sportline
Default Race wheels - 12-20-2016, 11:16 AM
So what are our options for a drag pack set up? Been drag racing my whole life and i have no problem a set of 17s on the car all the time with drag radials.
Newguy123's Avatar
Car: 12' 135i
Default 12-20-2016, 11:22 AM
Kosei k1. They aren't very wide at 8.5" but are super light 16.xx lbs per wheel
12' DCT 135i
#PURETURBOS
#FUELIT
Default 12-20-2016, 11:25 AM
So kosei k1 or enkei rpf1 is all?
Immaculate Immaculate is offline
Car: 11' 135i
Default 02-16-2017, 11:39 AM
I'm looking at getting a set of these to run on the drag strip here and there for the rears.
Any tires you would recommend? I've been looking at the Nitto NT555r's in 245-45-17.
Default 02-16-2017, 12:20 PM
Same exact combo i was just looking at
phil1320 phil1320 is offline
Car: 2011 335is
Default 02-16-2017, 12:57 PM
Get yourself some Apex Arc-8. They come in 9, 9.5, 10, etc so you can get the exact look and setup you want. The 9" apex arc8 is lighter than the 8.5" Kosei k1 and I haven't heard of Apex wheels cracking but I've read quite a few horror stories from k1's.
For my setup. I'm doing 17x9" apex arc-8 (I wanted 9.5" but found some used 9" for a great price) and I'm doing 275/40/17 Mickey Thompson ET Street S/S tires
2011 335is DCT | DocRace 6266 | HPF Gen 2 3.5" Exhaust | Stett Stage 2 Oil Cooler | CSF Aluminum Radiator | AD-E 1000 HP IC | Fuel-It Stage 3 Pump | AD-E PI | MFactory LSD | MFactory Axles | YCW Coilovers | SSP Spec R | M4 Flywheel
1stupidsailor 1stupidsailor is offline
Car: 2013 335i
Default 03-12-2017, 02:00 AM
I was looking at these, though not purely for a drag setup, just as a replacement to my 401's. I would like the 19x10.5" in the back to support a wider tire, but I'm guessing it would rub with like a 295/30/19 on there. They're ET22, so not sure how much room we have to play with back there. Even with the wider rim, they're still 7lbs a piece lighter than stock, gets even better once the run-flats go away.
2013 IBM 335i
Dinan Intake, JB4+MHD, ER IC, **, CP, TIC
Thisisdudewhoru Thisisdudewhoru is offline
OEM+
Car: '16 340i
Default 03-13-2017, 04:52 AM
So I know that if I have a low tire pressure, the car won't let me go in sport or sport plus. Will the car act weird with drag setup on it if I don't even have tpms sensors in them?
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake
Default 04-10-2017, 01:07 PM
My 437 reps dont have any tpms in them. Tire light stays on and i can still go into sport+ and turn dsc off.
BazBar's Avatar
BazBar BazBar is offline
Car: UK 140i-M Sport Auto
Default 09-06-2017, 05:29 AM
I know this is an old one but:
Have also got this problem, if i lower the rear tyre pressure below 23 psi on my 140i (2017) R88s tyres it put the car in nanny mode ....And i can not turn it off ?.
Has anyone got wheels that do not have the TPMS in them on 2016/17 cars, if so how have you got around this issue.
I know on my old 135i (2008) i could reset it to a lower pressure and all was fine. But this does not happen on the newer cars?.
