(#1601)
Loving_dave0 Loving_dave0 is offline
Car: Bmw f10
Default 04-08-2018, 09:49 PM
Originally Posted by Loving_dave0
Yea bro.. will update it..
bucketfoot bucketfoot is offline
Car: 2014 BMW X1 28i xDrive
Default 04-17-2018, 09:21 AM
Sorry, I'm new to the forum and it looks like I initially posted this in the wrong place.
I have a 2014 X1 and just picked up a used JB4 from a former 3-series owner.
I went to the Burger Tuning website this morning and noticed there is a separate dropdown selection for the X1/Z4. Is there really a different X1 version or will the EWG one that I got work OK (my plans are to install it this weekend)?
edm0nd edm0nd is offline
Car: 2013 328i N26
Default 04-24-2018, 05:34 PM
Originally Posted by edm0nd
I purchased a JB4 recently and then found out I needed a new board so I purchased that + the OBD2 cable.
On the OBD2 cable, what does the molex connection plug into? That is the only thing I am uncertain of at the moment. Do I also have an outdated wiring harness as well or am missing another piece/cable?
My wiring cables - https://i.imgur.com/qhHrg2W.jpg
New board + obd2 cabl - https://i.imgur.com/er9Ev5F.jpg
I drive a N26 EWG 2013 328i if that helps.
So I derped and ordered the wrong obd2 cable, what I needed was the OBD2 cable + Retrofit kit that was +$10 more but I got the regular one.
That being said, is it possible for me to wire the regular OBD2 cable directly to the brown and green wires on my harness? There are 3 wires on the OBD2 cable (I cut the molex end off) so which exact wires do I wire to green/brown?
OBD2 regular cable w molex end cut off - https://i.imgur.com/lgBTmzs.jpg
Is it not possible like that?
Do I just need to bite the bullet and order the $35 OBD2 kit?
LOL sorry if this is just a really dumb question, I'm just so close to being able to add this to my car. And also thanks to Ando at BMS support for answering my questions via email.
Aekdbrich Aekdbrich is offline
Car: 2014 328xi F30
Default 05-02-2018, 06:48 PM
Hey bro,
Did you get this fixed? I have a friend who is running into the same issue. He has a 528i and I gave him the data cable. Were you able to get the steering controls turned on?
Car: Bmw f10
Default 05-02-2018, 10:07 PM
Originally Posted by Aekdbrich
Hey bro,
Hai.. I already runnig on jb4,with the cable i manage to change the maps...but no using stering control...
nio58 nio58 is offline
Car: bmw x3 f25 lci
Default 05-07-2018, 12:17 AM
Please help me to solve the problem.
I install JB4 EWG on BMW X3 F25 LCI N20 2015. It's normally worked, and managed via data cable, but no reaction by pressing BC button. When I press and hold BC, nothing happens.
Thanks in advance.
alphax alphax is offline
Car: 328ix
Default 05-10-2018, 06:01 PM
2 Boost gauge on fuel, scaling in dash is 0 to boost safety setting
--Fuel empty mean 0psi,what does fuel full meaning?
Moderator
Default 05-10-2018, 07:15 PM
It should be scaled by your boost safety. If boost safety is 20, that means full is 20 psi, half is 10 psi, etc.
Car: 328ix
Default 05-10-2018, 08:26 PM
It's just a bit over half when full throttle.Is the boost too low?
Herc Herc is offline
Car: F20 125i
Default 05-10-2018, 10:21 PM
precise boost values can be monitored via log files or app!
Car: 328ix
Default 05-10-2018, 11:29 PM
You mean should not care about the boost gauge on fuel,should I?
Car: F20 125i
Default 05-11-2018, 03:26 AM
no if you interested for precise values. ie 19.5 or 10 rather an assumption of it may be 10 or it may be 11 etc.
Moderator
Default 05-11-2018, 09:48 AM
The boost gauge on the dash is to give you an area of boost that you're in. It is pretty accurate though. However the best way is to get a data log to verify everything is working properly.
Gruietta Gruietta is offline
Car: Bmw z4 e89 20i stage 3
Default 05-15-2018, 07:23 AM
good evening guys.
I'm new to the forum. sorry for my english.
recently owner of jb4 for my bmw z4 20i pneumatic n20 wastegate engine. gearbox zf 8 gears.
I have some upgrades already made in the car.
- increased regression
- increased intercooler
- direct intake
- no catalyst
- complete exhaust pipe 70mm.
does anyone exist who already has settings for these changes?
we're already trying something with Ando. shortly I enter log.
Moderator
Default 05-15-2018, 09:16 AM
Originally Posted by Gruietta
good evening guys.
- direct intake
- no catalyst
It's all plug and play. Install the Jb4 and enjoy on map 1. If you want to move further, it is best to post a log so we can advise you.
Default 05-15-2018, 09:25 AM
I load someone immediately, but Ando has already told me to bring boost safety to 24.
I wanted (after full setting) to install meth .. but I read that rods tend to thrown over 22 psi.. I accept advice
Default 05-15-2018, 10:25 AM
sorry guys, this log, map 5
Default 05-16-2018, 09:14 AM
Delivered boost to 24 psi security.
Load log map 2. It does less turbo pressure but pushes well .. If there are other settings to get the best I'm happy.
HIRRS-ZN HIRRS-ZN is offline
Car: F30 320i
Default Yesterday, 10:07 AM
I increased my boost safety to 32psi as I hit the limiter on 4-5th gears. With map7 I can get up to around 27psi.
Car is still running strong with no issues. 😁
BuffaloBranco BuffaloBranco is offline
Car: 320i ActiveFlex
Default Yesterday, 02:54 PM
Hi guys,
I bought a JB4 EWG with a friend. The JB4 was in his 328i, 2013, and run just petrol.
I pretend to install de JB4 in my 320i, 2013, ActiveFlex (petrol and ethanol).
Both cars are electronic wastegate.
My question is: to use de map 5, do I need to reprogram the JB4, update de firmware, reset or something like that? Or just plug it and the chip will work fine in my 320i?
I know that he was used to run map 6, who was specific for his car.
But the map 5 would by enough for me.
