zort zort is offline
Default 245/45/17 on BMW style 159 - 10-10-2017, 10:41 AM
Guys, If i have done nonsense let me know.
Running 245 / 45 /17 NT01's on the stock BMW 17 x 8" 159 rim. The tires are running 25psi cold.
The problem is that I don't have traction just for a light feathering.
Is is that I have an incorrect setup running the 245/45 on 8" s. Also the tires are not spanking brand new.
-B
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 10-23-2017, 09:01 AM
245 is probably a little tight on a 8.5" width, but doable. Might result in uneven center/outer tread wear though.
25 psi sounds low ...
if they are old they may provide less traction.
2009 535i Sport
Software: JB4 G5 | MHD | Trebila Tune | XHP Stage 3
Hardware: GC Lites | Inlets | Outlet | 3" D-P's | 7" FMIC | S2 LPFP | TBI | DCI | ER CP | Forge DV's | 3.5 TMAP | RB PCV | Koni FSD
turboalb's Avatar
turboalb turboalb is offline
Car: 08' 535i
Default 10-24-2017, 01:57 AM
245 is the correct size for that wheel, its a 8" inch wheel not a 8 1/2. Just because you put a nitto on doesnt mean they will hook, do you have a lsd? where are you trying to get traction? there are lots of variables. tire pressure depends where you are at, 25psi is probably perfect for the drag strip, but like I said it depends on track conditions.
08' 535i sport auto, jb4/mdh/xhp
10' x5m 11.72 1/4 record jb4 only
00' hayabusa turbo street bike
440 rwhp 1/8 5.42 141mph
07 SS trailblazer tuned/flex fuel
LessIsMore's Avatar
Inner Circle Member
Default 10-25-2017, 09:54 AM
Oops, you're right I mistyped. However 245 is a little wide for an 8" wheel, but doable.
2009 535i Sport
Default 10-25-2017, 10:17 AM
Thanks for the responses.
Honestly I expected to put them on and have traction at all times. After all the car is just FBO so nothing crazy. I am also trying a diff lock down and it has helped things a bit. Seems I also need to review my camber settings.
Maybe the r888 would be a bit better ? If I recall they are a replacement for the rA1 which was 40 ya vs the Nitto that is 100.
Default 02-14-2018, 09:58 AM
Hey Guys, continuing on this quest for traction I have decided to go with new tires all round. I don't care about the longevity of the summer wheels and would prefer a square setup with lots of traction and some drive ability in rain or standing puddles.
Question - would 255 be to wide for the 8" rim and should I stay with 245 / 40 ? Also will what I decide for the rear fit the front ? So would 245/40 or 255/40 fit the front ?
2007 - e90.
Car: 2003 Forester
Default 02-16-2018, 06:37 AM
255's are too wide for a 8" wheel. Had 245's on my old Talon on Evo 9 wheels and in my opinion nice and meaty looking.
Default 02-16-2018, 09:50 AM
Yes seems so I will go going 245/40 square on the 159's. Now to pick a good tire .
Any recommendations ? Just looking for something that is very very sticky but moderate in rain and puddles at normal speeds.
Car: 2003 Forester
Default 02-16-2018, 01:12 PM
Bridgestone Potenza RE-71's are the hot autocross tire around here.
Default 02-16-2018, 02:22 PM
Thanks.
