Stoolz Stoolz is offline
Car: 11 135i
Default Quarter mile times E series Dct cars - 01-12-2018, 03:35 PM
Hi guys.
Still waiting on someone to save me and clone my ecu so I can start pushing again.
Since my last time out I've added M4 flywheel and PI, looking forward to seeing an improvement, dyno shows a lot more power through the graph. (Not a huge change high boost / high high rpm tho, turbo out of puff i guess)
Tried to launch about a million times, all 2.1 or worse.
Best run was....
11.8 @ 121.7
How are you guys going?
M335's Avatar
M335 M335 is offline
Car: 2011 E90 335i
Default 01-13-2018, 10:33 PM
Do you mind to post a log from that run?
F10 N63tu Frozen Grey with full OEM M5 conversion on prototype JB4+BCM+S2 turbos+F10 stealth progressive meth| Custom inlets with CAI | Eibach springs| custom exh**st with 😼less dwnps |
E90 N55 VS2 DBB with custom inlet-short air intake | BMS JB4/MHD bef/ISO+FF wires E50 corn | 100% Meth-Injection | BMS-occ,cf,ocv, | Big Tom FMIC | Fuel-it S2 LPFP | 5" CP-E ** | BMW-pe |
Car: 11 135i
Default 01-14-2018, 12:07 AM
Sorry mate , I didn't log that night. I was targeting 24psi and running 50/50 dual cm7 meth plus E50.
Logs for this set up are pretty clean, within a couple of psi of target. Timing ok, but nowhere near as clean as with PI now.
I didn't try launch control at all as MHD kickdown delete was flashed.
JCip91 JCip91 is offline
Car: n55 135i
Default 01-14-2018, 08:07 AM
Mine is 12.8 @ 108. I am having boosting issues though so no idea what it will do when that's fixed.
TiAg n55 135i DCT - JB4 ISO - PPK Flash - BMS Intake - VSRF Charge Pipe - Wagner Tuning Performance II Intercooler - BMS D Pipe - Whiteline Inserts
Car: 11 135i
Default 01-14-2018, 01:23 PM
I think my best was 12.4 stock turbo stock fuel.
What is your boost issue?
Car: n55 135i
Default 01-14-2018, 02:10 PM
It will hit target boost at 19psi then drop to 0psi at the end of the log. It is pulling at *** inefficiency code but since I dont have a *** I am not sure if that is effecting it.
Car: 11 135i
Default 01-14-2018, 11:10 PM
That's whack?
