(#376)
Default 12-15-2017, 08:10 PM
Log it and lets evaluate. Any advice has to be based on your specific data.
sirfredi's Avatar
sirfredi sirfredi is offline
Default 01-18-2018, 03:17 AM
Correct.
I an planning to release hybrid specific RACE and PUMP back end flash maps in the coming weeks though.
I have downloaded the mhd files and there are not the hybrid specific RACE and PUMP back
Is this going to be done or was the project left?
freddyamazin freddyamazin is offline
Car: e92 335i
Default 02-02-2018, 04:28 PM
Also interested in previous post
Default 02-02-2018, 06:50 PM
Left. I don't like using lean spool mode and related on pump fuels. Use the normal PUMP BEF as your starting point for hybrids on pump.
Bomba474's Avatar
Bomba474 Bomba474 is offline
Car: 335i N54 E92
Default 02-08-2018, 10:25 PM
Dear Folks,
I had a n54 AT w hybrid turbos (compressor 39mm upgrade)
With 22 psi I got 473whp and
Do anyone know if its poasible to gain more power W SAFETY?
Which pressure is safy for this kind of turbo?
On a Costumers car w 30psi I got 573whpand 78wtq....
On links below u can find dyno test pics.
http://i259.photobucket.com/albums/h...psjii8lpl0.png
http://i259.photobucket.com/albums/h...psrngdajpp.png
335i, MHD E65 Custom flash, Intercooler, Chargerpipe, MM Performance inlets, LPFP Walbro 450, HPFP BMW review, full exhaust
mafia321's Avatar
mafia321 mafia321 is offline
Car: bmw 335
Exclamation hybrid turbo - 02-21-2018, 03:21 PM
i have hability tmap 3.5 but is necesary install mhd???
n54Jones n54Jones is offline
Car: 07 bmw 335i
Default Hybrid turbo tuning - 03-02-2018, 09:49 AM
Hey guys so my car on low rpm is surging itís really strange I need some help!
Mods are:
Vtto stage 2+ turbos
Inlets
Outlets
Stage 2 bucketless pump
Fbo
N54QC N54QC is offline
Car: 07 BMW 335i
Default 03-02-2018, 10:03 PM
Mods are:
Inlets
Outlets
Fbo
Post a log in the support section.
Con535 Con535 is offline
Car: 2010 bmw 535
Default Hybrid e85 or race? - 03-15-2018, 09:14 PM
Ruining meth and 40% e85 with pure stage 2s would backend flash be hybrid e85 or race?
Default 03-16-2018, 11:15 AM
Hybrid E85.
lightning lightning is offline
Car: BMW 1M Coupe
Default 04-08-2018, 10:53 PM
Hi Terry, i realised that the "race" backend flash for MHD is removed, and changed to E85 hybrid.
If i were to run 20% ethanol with 100% meth, what flash should i use? E85 Hybrid or Pump?
thank you!
JamesF1986 JamesF1986 is offline
Car: 2011 BMW 335is
Default 05-08-2018, 08:44 AM
What fuel? Load the race back and flash and start by logging map 3 with a 50 additive to evaluate it.
Hi Terry, I'm having my Pure Stage 2 DD turbos installed next week with larger 2 inch inlets, and stage 2 LPFP. I'm then having Wedge doing a custom 94 octane map (e85 is hard to get in Vancouver), but as I understand it, Wedge do not support JB4 interface.
My question is, what changes do i need to make to the user adjustment settings in JB4 to best utilize the Wedge tune? I'm also running your TMAP 3.5 senior, so i understand this effects the standard setup..
I've read through this thread, but it really isn't clear what changes I need to make.. Thanks for your help.
Jscottrad Jscottrad is offline
Jscottrad
Car: 2007 335i
Default Are Vargas with billet compressor considered HYBRID? - 05-21-2018, 11:47 AM
Hi, would like someone to give me an opinion of my log. I'm running Vargas turbos with the billet compressor wheels (20% more flow) PUMP BEF, JB4 on Map 2, VRSF *********, Burger air filters, and a larger intercooler (Chinese Ebay) Car drives OK but boost seems to fall off at higher RPM's. Any advice is appreciated! Scott2018-05-20 17_06_12.csv
Default 05-21-2018, 02:39 PM
Originally Posted by Jscottrad
Hi, would like someone to give me an opinion of my log. I'm running Vargas turbos with the billet compressor wheels (20% more flow) PUMP BEF, JB4 on Map 2, VRSF *********, Burger air filters, and a larger intercooler (Chinese Ebay) Car drives OK but boost seems to fall off at higher RPM's. Any advice is appreciated! ScottAttachment 74745
Post in the support section for faster response. The log looks okay, first thing is to update your value under 6 cylinder logging in the user adjustments tab.
Under Duty bias from 5000 all the way up change it to 65. Lower FF to 100 and relog.
Jscottrad
Car: 2007 335i
Default Are Vargas with billet compressor considered HYBRID? - 05-21-2018, 04:00 PM
2018-05-21 17_51_20.csv Thanks, and noted about the support section!
Default 05-21-2018, 04:07 PM
Attachment 74765 Thanks, and noted about the support section!
Awesome, much better. Maybe you can try raising it up another 5 across the board of what I told you earlier and it should hit target now. Take a look:
Jscottrad
Car: 2007 335i
Default 05-21-2018, 05:04 PM
Will do, and relog tomorrow, Thanks so much for the help! Also, I'm still using the stock intake from filters to turbo inlet, is that an issue? Scott
Default 05-21-2018, 08:43 PM
You might want to get inlets, we actually do have some inlets at special price I believe that fit your turbos. If you email Terry@burgertuning.com he can set you up!
Ripley's Avatar
Ripley Ripley is offline
Car: 335i N54
Default 06-21-2018, 06:21 PM
Hi Terry,
Can I start my settings using the PSI per RPM as shown in the first post? VTT GC 2.0 and 91 octane fuel (for the the moment). Thanks
Black Sapphire E92 335i AT: VTT GC 2.0 - VTT inlets/outlet - VRSF 7'' FMIC - VRSF 3'' d p s - JB4 G5 w/ FSB - AEM meth - Fuel-It stage 2 LPFP - BMS DCI w/ scoops - Phoenix Racing CP - TIAL BOV - NGK Iridium plugs - KW V3 - Dinan camber plates - Brembo 8 pot - Pagid RST3 - Mishimoto 25 row oil cooler - Quaife LSD - M3 rear anti sway bar - xHP stage 3
Default 06-22-2018, 03:37 PM
Originally Posted by Ripley
Hi Terry,
I would start with all default values posted on the first page. Update your BEF to the appropriate one for the fuel you are using. Get a lot on map 1 and post it up for us in the support section to evaluate for you.
e92ace e92ace is offline
Default 06-22-2018, 07:41 PM
Hybrid turbo setup no e85 what map do I use, just pump or hybrid e85?
